Hva skjuler det seg bak din Ctrl+v?
Instructions to Install
Download the latest ROM zip and GApps from the download tabs above.
Connect your Optimus G into USB Storage mode to the PC via USB data cable.
Drag the downloaded two zips to the root of your storage (and not in any folder).
Power off the device, press Volume Up + Home + Power buttons altogether until you see the Recovery screen
You are now in Recovery mode.
If you are flashing this ROM for the first time (coming from another ROM): wipe /data (factory reset) /cache, dalvik-cache and /system
If you are updating this ROM (coming from previously installed version of this ROM): wipe /cache and dalvik-cache
"Install zip from sdcard" > "choose zip from sdcard" > select the ROM zip and press "Yes" to flash.
Follow the above step again to flash the GApps.
When all is done, select "reboot system now".
Want to report a bug? Read this first!
The below stated format shall be strictly followed to report any bug related to this specific ROM. Make sure that you have not overclocked over the provided CPU frequency and also that you are not running any custom kernels. Such bugs will be subjected to ignorance
Bug submission should majorly be done at the Bug Tracker.
Quote:
Bug Description: Describe the bug in English and as in-depth as possible.
How to reproduce the bug: Describe the instructions to reproduce your bug, so that I can confirm that its universal
Logcat: A logcat is considered very necessary during a bug report and will help me solve the bug at a fast rate. So, provide a logcat to your bug if possible.
