Hva skjuler det seg bak din Ctrl+v?
//BEGIN CODE
#include <SoftwareSerial.h>
#define servoPin 4 // control pin for servo motor (White or yellow wire of servo)
#define minPulse 500 // minimum servo position (Open position)
#define maxPulse 2200 // maximum servo position (Closed position)
#define rxPin 8 // SOUT pin of RFID module
#define txPin 9
#define enable 2 // /ENABLE pin of RFID module
#define LED1 13 // LED output pin
#define LED2 12 // other LED output pin for two-way LED (yellow)
#define switchPin 7
boolean open = true; // default start up is to assume the lock is open
int val = 0;
char code[10];
int bytesread = 0;
int pulse, switchVal;
char tag1[11] = "0800335036"; // this is size 11 because it is a NULL terminating string
char tag2[11] = "0800330A99";
char tag3[11] = "0F03028B4F";
void LEDControl(int state){
switch (state){
case 1:
digitalWrite(LED1,HIGH);
digitalWrite(LED2,LOW);
break;
case 2:
digitalWrite(LED2,HIGH);
digitalWrite(LED1,LOW);
break;
case 3:
for(int y=0;y<5;y++){
delay(250);
delay(250);
boolean checkTag(char *tag){
for (int x=0;x<10;x++){
if( tag[x] != code[x]){
return false;
return true;
boolean findGoodTag(){
if (checkTag(tag1)){ return true;}
else if (checkTag(tag2)){ return true;}
else if (checkTag(tag3)){ return true;}
// Add more lines right here like the one above if you have more tags
else{
Serial.print("Bad tag: ");
Serial.println(code);
LEDControl(3);
return false;
void moveServo(){
if (open){
pulse = minPulse;
open = false;
LEDControl(1);
else if (!open){
pulse = maxPulse;
open = true;
LEDControl(2);
for (int x =1;x<150;x++){
delay (10); // don't know why this works, but it does
digitalWrite(servoPin, HIGH); // start the pulse
delayMicroseconds(pulse); // pulse width
digitalWrite(servoPin, LOW); // stop the pulse
void setup() {
pinMode(servoPin, OUTPUT); // Set servo pin as an output pin
pinMode(LED1,OUTPUT); // Set LED pin as output
pinMode(LED2,OUTPUT); // Set LED pin as output
Serial.begin(9600);
Serial.println("Begin");
pinMode(enable,OUTPUT); // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
digitalWrite(enable, LOW); // Activate the RFID reader
pinMode(switchPin, INPUT);
void loop() {
SoftwareSerial RFID = SoftwareSerial(rxPin,txPin);
RFID.begin(2400);
switchVal = digitalRead(switchPin);
if((val = RFID.read()) == 10)
{ // check for header
if(switchVal == HIGH){
Serial.println("Button");
moveServo();
bytesread = 0;
while(bytesread<10)
{ // read 10 digit code
val = RFID.read();
if((val == 10)||(val == 13))
{ // if header or stop bytes before the 10 digit reading
break; // stop reading
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
if((bytesread == 10) && (findGoodTag()))
{ // if 10 digit read is complete
digitalWrite(enable, HIGH); // dectivate the RFID reader
moveServo();
delay(500);
(Arduino kode for en RFID dør åpner)
CypheroN
I dag, 23:11
Innlegg #2
Bruker
Gruppe: Medlemmer
Ble medlem: 05/02-2007
Medlem nr.: 121390
--- Si din mening her ---
Don't be so gloomy. After all it's not that awful. Like the fella says, in Italy for 30 years under the Borgias they had warfare, terror, murder, and bloodshed, but they produced Michelangelo, Leonardo da Vinci, and the Renaissance. In Switzerland they had brotherly love - they had 500 years of democracy and peace, and what did that produce? The cuckoo clock.
Telle sauer
En bonde passa den digre saueflokken sin, mens den gikk spredt utover på beitet. Da dukker det plutselig opp en tøff ny BMW 5-serie på veien nedenfor. En fyr i Broni-dress og Gucci-sko, med Ray Ban solbriller og et YSL-slips stikker hodet ut av bilvinduet og roper til bonden:
- Hvis jeg kan si nøyaktig antall sauer du har gående på beitet her, får jeg ta med meg en av sauene dine da? Bonden ser på fyren - for en jypling! Og han ser på den godt spredte saueflokken, og svarer:
- Ja, det er greit for meg!
Fyren kjører BMW'n inntil kanten, åpner en Dell notebook på panseret, kopler siste skrik i Nokia mobil til og surfer til ei NASA-side på internett og kaller opp et GPS-satelitt-navigasjonssystem, henter den eksakte posisjonen deres i terrenget og mater den inn til en annen NASA-satelitt som skanner beiteområdet med ultrahøy-oppløsningskamera. Så åpner han det digitale bildet i Adobe Photoshop og eksporterer det til et nettsted: Image Processing Facility i Hamburg. I løpet av sekunder får han en e-post i retur på en Palm Pilot - der det står "picture prosessed and data stored". Så logger han inn på en MS-SQL database via ODBC og kopler opp et Excel regneark med flere hundre avanserte formler. Etterpå laster han alle dataene ned gjennom e-posten til en Xircom og på et øyeblikk får han respons. Til sist skriver han ut en fire fargers, 150-siders rapport på sin hitech-miniatyr HP Colour LaserJet og kaster et blikk på den siste sida:
- Du har nøyaktig 1586 dyr, sier han.
- Det stemmer det, så det er greit at du tar med deg en sau, sier bonden.
Så ser han på mens typen velger ett av dyra, og bykser og kaver med å få det ned i bagasjerommet på BMW'n. Så sier han:
- Du, hvis jeg kan si nøyaktig hva du jobber med - gir du meg tilbake den sauen da?
Den unge fyren tygger litt på det, men sier:
- Ok, ja hvorfor ikke?
- Du er konsulent, sier bonden.
- Jøss, det stemmer - hvordan kunne du gjette det?
- Det er ikke gjetting! Du kom her uten at noen hadde tilkalt deg, så skulle du ha betalt for et svar jeg kunne fra før, til og med på et spørsmål jeg aldri har stilt! Dessuten har du null og niks peiling på noe som helst i denne bransjen! Så da er du kanskje så snill og lukke opp bagasjelokket og gi meg igjen bikkja mi?
Telle sauer
HAHAHAHAHAHAHAH :rofl:
min ctrl+v:
http://www.ikea.com/no/no/catalog/products/40134045
Endret av Mikkel™
