Hva skjuler det seg bak din Ctrl+v?
Top Secret
Most of us think of classified information in terms of security clearance levels. Countless
films and television programs show government employees who can't access the information they need because they don't have the right clearance. While it's true that there are levels of security classification, it's not true that the system is simply a vertical series of security classifications. Even if you have top secret security clearance, you can't necessarily access everything at the top secret level (or even lower levels). This is because information and projects are compartmentalized. In other words, if you are cleared for top secret information in a project on stealth technology, it doesn't necessarily mean you can access information in a project about proton laser beams. Security clearance is issued on a need-to-know basis, and if you don't need to know what the engineers in the laser department are doing to complete your work on stealth technology, you can bet you won't be able to find out about it
Endret av Mr. A
Du har satt opp en helt basic ubuntu-installasjon, og prøver å koble til SSH. For å være sikker.. Du har installert en SSH-server på ubuntu-installasjonen? Hvis ikke, kjør kommandoen
sudo aptitude install openssh
i terminalen.
Den vil være satt opp til å ta i mot trafikk på port 22 som default. Hvis du skal ha det til port 80, som du hadde forwardet fra modemet til maskinen, må du endre dette i setup-filen.
Den kan du endre ved å skr
