Natrich Skrevet 21. mars 2009 Rapporter Del Skrevet 21. mars 2009 Damn, det var mye på Ctrl+v ** Executing... ** Command: "c:\programfiler\steam\steamapps\compaq344\sourcesdk\bin\ep1\bin\vbsp.exe" ** Parameters: -game "c:\programfiler\steam\steamapps\compaq344\counter-strike source\cstrike" "C:\Programfiler\Steam\steamapps\compaq344\sourcesdk_content\cstrike\mapsrc\prisonbreak" Valve Software - vbsp.exe (Dec 11 2006) 1 threads materialPath: c:\programfiler\steam\steamapps\compaq344\counter-strike source\cstrike\materials Loading C:\Programfiler\Steam\steamapps\compaq344\sourcesdk_content\cstrike\mapsrc\prisonbreak.vmf fixing up env_cubemap materials on brush sides... ProcessBlock_Thread: 0...1...2...3...4...5...6...7...8...9...10 (0) **** leaked **** Entity infodecal (0.00 506.00 1104.10) leaked! Processing areas...done (0) Building Faces...done (0) FixTjuncs... PruneNodes... WriteBSP... done (1) Creating default cubemaps for env_cubemap using skybox materials: skybox/sky_day01_01*.vmt Run buildcubemaps in the engine to get the correct cube maps. No such variable "$hdrbasetexture" for material "skybox/sky_day01_01rt" Can't load skybox file skybox/sky_day01_01 to build the default cubemap! Finding displacement neighbors... Finding lightmap sample positions... Displacement Alpha : 0...1...2...3...4...5...6...7...8...9...10 Building Physics collision data... done (0) (59507 bytes) Placing detail props : 0...1...2...3...4...5...6...7...8...9...10 Compacting texture/material tables... Reduced 176 texinfos to 113 Reduced 23 texdatas to 23 (514 bytes to 514) Writing C:\Programfiler\Steam\steamapps\compaq344\sourcesdk_content\cstrike\mapsrc\prisonbreak.bsp 1 second elapsed ** Executing... ** Command: "c:\programfiler\steam\steamapps\compaq344\sourcesdk\bin\ep1\bin\vvis.exe" ** Parameters: -game "c:\programfiler\steam\steamapps\compaq344\counter-strike source\cstrike" "C:\Programfiler\Steam\steamapps\compaq344\sourcesdk_content\cstrike\mapsrc\prisonbreak" Valve Software - vvis.exe (Nov 8 2007) 1 threads reading c:\programfiler\steam\steamapps\compaq344\sourcesdk_content\cstrike\mapsrc\prisonbreak.bsp reading c:\programfiler\steam\steamapps\compaq344\sourcesdk_content\cstrike\mapsrc\prisonbreak.prt LoadPortals: couldn't read c:\programfiler\steam\steamapps\compaq344\sourcesdk_content\cstrike\mapsrc\prisonbreak.prt ** Executing... ** Command: "c:\programfiler\steam\steamapps\compaq344\sourcesdk\bin\ep1\bin\vrad.exe" ** Parameters: -game "c:\programfiler\steam\steamapps\compaq344\counter-strike source\cstrike" "C:\Programfiler\Steam\steamapps\compaq344\sourcesdk_content\cstrike\mapsrc\prisonbreak" Valve Software - vrad.exe SSE (Nov 8 2007) ----- Radiosity Simulator ---- 1 threads [Reading texlights from 'lights.rad'] [1 texlights parsed from 'lights.rad'] Loading c:\programfiler\steam\steamapps\compaq344\sourcesdk_content\cstrike\mapsrc\prisonbreak.bsp No vis information, direct lighting only. 1107 faces 175673 square feet [25297032.00 square inches] 0 displacements 0 square feet [0.00 square inches] 0 direct lights BuildFacelights: 0...1...2...3...4...5...6...7...8...9...10 (0) Build Patch/Sample Hash Table(s).....Done<0.0236 sec> FinalLightFace: 0...1...2...3...4...5...6...7...8...9...10 (0) FinalLightFace Done 0 of 0 (0% of) surface lights went in leaf ambient cubes. ComputePerLeafAmbientLighting: 0...1...2...3...4...5...6...7...8...9...10 Ready to Finish Object names Objects/Maxobjs Memory / Maxmem Fullness ------------ --------------- --------------- -------- models 31/1024 1488/49152 ( 3.0%) brushes 140/8192 1680/98304 ( 1.7%) brushsides 841/65536 6728/524288 ( 1.3%) planes 734/65536 14680/1310720 ( 1.1%) vertexes 1839/65536 22068/786432 ( 2.8%) nodes 773/65536 24736/2097152 ( 1.2%) texinfos 113/12288 8136/884736 ( 0.9%) texdata 23/2048 736/65536 ( 1.1%) dispinfos 0/0 0/0 ( 0.0%) disp_verts 0/0 0/0 ( 0.0%) disp_tris 0/0 0/0 ( 0.0%) disp_lmsamples 0/0 0/0 ( 0.0%) faces 1107/65536 61992/3670016 ( 1.7%) hdr faces 0/65536 0/3670016 ( 0.0%) origfaces 583/65536 32648/3670016 ( 0.9%) leaves 805/65536 25760/2097152 ( 1.2%) leaffaces 1178/65536 2356/131072 ( 1.8%) leafbrushes 376/65536 752/131072 ( 0.6%) areas 2/256 16/2048 ( 0.8%) surfedges 7350/512000 29400/2048000 ( 1.4%) edges 3997/256000 15988/1024000 ( 1.6%) LDR worldlights 0/8192 0/720896 ( 0.0%) HDR worldlights 0/8192 0/720896 ( 0.0%) waterstrips 48/32768 480/327680 ( 0.1%) waterverts 0/65536 0/786432 ( 0.0%) waterindices 648/65536 1296/131072 ( 1.0%) cubemapsamples 0/1024 0/16384 ( 0.0%) overlays 0/512 0/180224 ( 0.0%) LDR lightdata [variable] 483292/0 ( 0.0%) HDR lightdata [variable] 0/0 ( 0.0%) visdata [variable] 0/16777216 ( 0.0%) entdata [variable] 13210/393216 ( 3.4%) LDR leaf ambient 805/65536 19320/1572864 ( 1.2%) HDR leaf ambient 0/65536 0/1572864 ( 0.0%) occluders 0/0 0/0 ( 0.0%) occluder polygons 0/0 0/0 ( 0.0%) occluder vert ind 0/0 0/0 ( 0.0%) detail props [variable] 1/12 ( 8.3%) static props [variable] 1/12 ( 8.3%) pakfile [variable] 10016/0 ( 0.0%) Level flags = 0 Win32 Specific Data: physics [variable] 59507/4194304 ( 1.4%) ==== Total Win32 BSP file data space used: 836287 bytes ==== Total triangle count: 2804 Writing c:\programfiler\steam\steamapps\compaq344\sourcesdk_content\cstrike\mapsrc\prisonbreak.bsp 1 second elapsed ** Executing... ** Command: Copy File ** Parameters: "C:\Programfiler\Steam\steamapps\compaq344\sourcesdk_content\cstrike\mapsrc\prisonbreak.bsp" "c:\programfiler\steam\steamapps\compaq344\counter-strike source\cstrike\maps\prisonbreak.bsp" Lenke til kommentar
fugletiteren Skrevet 21. mars 2009 Rapporter Del Skrevet 21. mars 2009 (endret) ●●●●●● det var bak min ctrl + v Endret 21. mars 2009 av fugletiteren Lenke til kommentar
Captn Jack Yarr'ow ! Skrevet 21. mars 2009 Rapporter Del Skrevet 21. mars 2009 Ctrl+V = -Why Don't You Find Out for You- <-- The Killers sang Lenke til kommentar
solaN - Skrevet 21. mars 2009 Rapporter Del Skrevet 21. mars 2009 connect 213.173.230.10:30830; password snapwar Der var visst connecten til css servern min Lenke til kommentar
Natrich Skrevet 21. mars 2009 Rapporter Del Skrevet 21. mars 2009 85.131.247.73:27015 Lenke til kommentar
Tunky Skrevet 21. mars 2009 Rapporter Del Skrevet 21. mars 2009 http://www.youtube.com/watch?v=CfnizRqgh5Y Lenke til kommentar
Inaktivbruker_101125 Skrevet 22. mars 2009 Rapporter Del Skrevet 22. mars 2009 http://en.wikipedia.org/wiki/Soldering_gun Lenke til kommentar
MPC Skrevet 22. mars 2009 Rapporter Del Skrevet 22. mars 2009 http://en.wikipedia.org/wiki/Peter_Wyngarde Lenke til kommentar
hYLeAPe Skrevet 22. mars 2009 Rapporter Del Skrevet 22. mars 2009 Damage Given to "ProLine` SisaO`" - 80 in 9 hits Lenke til kommentar
Programvare Skrevet 22. mars 2009 Rapporter Del Skrevet 22. mars 2009 http://gamer.no/article.php?articleId=691 Lenke til kommentar
Turbo sindre Skrevet 22. mars 2009 Rapporter Del Skrevet 22. mars 2009 Sad But True Lenke til kommentar
3.14 Skrevet 22. mars 2009 Rapporter Del Skrevet 22. mars 2009 CONNECT 213.173.230.10:27080; PASSWORD mod Lenke til kommentar
