HOHOHOHO222 Skrevet 24. juli 2008 Rapporter Del Skrevet 24. juli 2008 (endret) Endret 24. juli 2008 av PortioN Lenke til kommentar
loathsome Skrevet 24. juli 2008 Rapporter Del Skrevet 24. juli 2008 <?php session_start(); ob_start();header('content-type: text/html; charset=utf-8'); // eocms uses UTF-8!date_default_timezone_set('Europe/Paris'); // set timezone default// eocms core file$core_require = array('functions','variables');foreach($core_require as $foreach){ require_once 'core/'.$foreach.'.eocms.php';}require_once 'core/functions.eocms.php';// Secure user session$db = simplexml_load_file('core/db/cmsusers.xml');if(isset($_SESSION["eo"])){ foreach($db->user as $out){ if($out->username == $_SESSION["eo"]){ if($_COOKIE["eo_sha1pw"] == sha1($out->password)){ $sessiontrue = 1; }}} if(!$sessiontrue) { // if invalid user header('location:index.php?eomodule=log&out&toID=7'); }}// LICENSE CHECKif(!file_exists('core/db/license.dll')){die('EOCMS FATAL: No license file found');}$license = simplexml_load_file('core/db/license.dll');$check_validity = (crypt($license->key, $license->algorithm) == $license->algorithm);$check_expired = ($license->exp > time());// if it is invalidif(!$check_validity){if(isset($_SESSION["eo"])&&$_GET["eomodule"] !== "license"&&$_GET["eomodule"] !== "log"){header('location: ?eomodule=license');}}// if it has expiredif(!$check_expired){if(isset($_SESSION["eo"])&&$_GET["eomodule"] !== "license"&&$_GET["eomodule"] !== "log"){header('location: ?eomodule=license');}}// Expire login $time = 15*60; // fifteen minutes * 60 secondsif(isset($_SESSION["active"])&&(isset($_SESSION["eo"]))){$seconds = $_SESSION["active"] - time() + $time; if($seconds <= 0){ // expire session header('location:index.php?eomodule=log&out&toID=6'); } else { $_SESSION["active"] = time(); // comment away for evaluation }}else { $_SESSION["active"] = time();} /* if(isset($_SESSION["eo"])){ $seconds = $_SESSION["active"] - time() + $time; echo '<p style="font-size:80%;"> Evaluation version of eocms - You have '.$seconds.' seconds left before expiration</p>'; }*/?> Lenke til kommentar
KolonP Skrevet 24. juli 2008 Rapporter Del Skrevet 24. juli 2008 http://www.eiendomsmeglervest.no/Pages/BoligSoek.aspx Lenke til kommentar
Wubbable Skrevet 24. juli 2008 Rapporter Del Skrevet 24. juli 2008 Dim SHA As New System.Security.Cryptography.SHA512Managed SHA.ComputeHash(System.Text.Encoding.UTF8.GetBytes("password")) For i As Integer = 0 To 500000 : SHA.ComputeHash(SHA.Hash) : Next Dim SB() As Byte = SHA.Hash Dim TD As New System.Security.Cryptography.TripleDESCryptoServiceProvider TD.BlockSize = 64 ReDim Preserve SB(23) TD.Key = SB ReDim Preserve SB(7) TD.IV = SB Dim MemorySTR As New IO.MemoryStream Dim CryptoSTR As New CryptoStream(MemorySTR, TD.CreateEncryptor, CryptoStreamMode.Write) Dim b() As Byte = System.Text.Encoding.UTF8.GetBytes("12345678") CryptoSTR.Write(b, 0, b.Length) CryptoSTR.FlushFinalBlock() MemorySTR.Position = 0 ReDim b(MemorySTR.Length - 1) MemorySTR.Read(b, 0, MemorySTR.Length) Dim s As String = System.Text.Encoding.UTF8.GetChars(b) Lenke til kommentar
L4r5 Skrevet 24. juli 2008 Rapporter Del Skrevet 24. juli 2008 http://www.imdb.com/title/tt0062886/ Lenke til kommentar
chberge Skrevet 24. juli 2008 Rapporter Del Skrevet 24. juli 2008 www.betamagasinet.no Lenke til kommentar
JR Ewing Skrevet 24. juli 2008 Rapporter Del Skrevet 24. juli 2008 http://www.nhhi.org/quiz.xls Lenke til kommentar
Programvare Skrevet 24. juli 2008 Rapporter Del Skrevet 24. juli 2008 Y FAEN I HELVETE, TIDENES BESTE OPPLEVELSE, STO HELT FORAN OG SKREIK MEG HES OG KLARER NESTEN IKKE Å HØRE NÅR FOLK SNAKKER TIL MEG! Lenke til kommentar
Camlon Skrevet 24. juli 2008 Rapporter Del Skrevet 24. juli 2008 (endret) Javel. Skrev du det der på et annet fora, eller noe? Nå har jeg: MiKTeX 2.7 Setup Endret 24. juli 2008 av Camlon Lenke til kommentar
Hammarhaus Skrevet 25. juli 2008 Rapporter Del Skrevet 25. juli 2008 http://38.118.213.189/7wao0q3bb1+/pub2/Tra...er_setup.exe/X6 Lenke til kommentar
KolonP Skrevet 25. juli 2008 Rapporter Del Skrevet 25. juli 2008 http://webtv.tv2.no/webtv/?treeId=5600005 Lenke til kommentar
Programvare Skrevet 25. juli 2008 Rapporter Del Skrevet 25. juli 2008 setter på plan 9 på pc-en straks Lenke til kommentar
Programvare Skrevet 25. juli 2008 Rapporter Del Skrevet 25. juli 2008 og nå sitter jeg på Lenke til kommentar
Hammarhaus Skrevet 25. juli 2008 Rapporter Del Skrevet 25. juli 2008 Hør itj en gang Lenke til kommentar
