Hva skjuler det seg bak din Ctrl+v?
World of Warcraft
The CAS system was unable to initialize: tact::ClientHandler::Create failed: E_FAILURE
[20180422T18:59:58] {1bbc} INF: HTTP: shutdown requested
[20180422T18:59:58] {1bbc} INF: HTTP: shutting down
[20180422T18:59:58] {1bbc} INF: HTTP: shutdown complete
[20180422T18:59:58] {5838} INF: HTTP: shutdown requested
[20180422T18:59:58] {5838} ERR: network dispatcher: action posted after shutdown
[20180422T18:59:58] {5838} INF: NGDP initialization - (archive: true, cache: true, Async: true)
[20180422T18:59:58] {5f44} INF: adding network address 80.239.148.217:80 for server //blzddist1-a.akamaihd.net
[20180422T18:59:58] {5f44} INF: adding network address 80.239.148.201:80 for server //blzddist1-a.akamaihd.net
[20180422T18:59:58] {5f44} INF: adding network address 93.184.221.199:80 for server //edgecast.blizzard.com
[20180422T18:59:58] {5f44} INF: adding network address 8.250.241.254:80 for server //level3.blizzard.com
[20180422T18:59:58] {5f44} INF: adding network address 8.247.217.254:80 for server //level3.blizzard.com
[20180422T18:59:58] {5f44} INF: adding network address 8.254.252.240:80 for server //level3.blizzard.com
[20180422T18:59:58] {5f44} INF: adding network address 8.247.217.126:80 for server //level3.blizzard.com
[20180422T18:59:58] {5f44} INF: adding network address 67.26.1.254:80 for server //level3.blizzard.com
[20180422T18:59:58] {5f44} INF: NameResolutionComplete numServers 3 numHosts 8
[20180422T18:59:59] {5838} INF: Initialization step - FETCHING_CDN_CONFIG
[20180422T18:59:59] {5838} INF: Initialization step - FETCHING_BUILD_CONFIG
[20180422T18:59:59] {5838} INF: Initialization step - FETCHING_PATCH_CONFIG
[20180422T19:00:15] {5838} ERR: read fail #4096 @[46|229220275]: Permission denied
[20180422T19:00:15] {5838} ERR: failed to load the E-Key/E-Spec page 3400, span={offset=62294823,size=4096}, read=4096, expected=4096: E_IO_ERROR
[20180422T19:00:15] {5838} ERR: failed to load ESpec page table
[20180422T19:00:15] {5838} WRN: failed attempt to created the encoding handler (attempt #1)
[20180422T19:00:30] {5838} ERR: read fail #4096 @[46|229220275]: Permission denied
[20180422T19:00:30] {5838} ERR: failed to load the E-Key/E-Spec page 3400, span={offset=62294823,size=4096}, read=4096, expected=4096: E_IO_ERROR
[20180422T19:00:30] {5838} ERR: failed to load ESpec page table
[20180422T19:00:30] {5838} WRN: failed attempt to created the encoding handler (attempt #2)
[20180422T19:00:46] {5838} ERR: read fail #4096 @[46|229220275]: Permission denied
[20180422T19:00:46] {5838} ERR: failed to load the E-Key/E-Spec page 3400, span={offset=62294823,size=4096}, read=4096, expected=4096: E_IO_ERROR
[20180422T19:00:46] {5838} ERR: failed to load ESpec page table
[20180422T19:00:46] {5838} WRN: failed attempt to created the encoding handler (attempt #3)
[20180422T19:01:02] {5838} ERR: read fail #4096 @[46|229220275]: Permission denied
[20180422T19:01:02] {5838} ERR: failed to load the E-Key/E-Spec page 3400, span={offset=62294823,size=4096}, read=4096, expected=4096: E_IO_ERROR
[20180422T19:01:02] {5838} ERR: failed to load ESpec page table
[20180422T19:01:02] {5838} WRN: failed attempt to created the encoding handler (attempt #4)
[20180422T19:01:18] {5838} ERR: read fail #4096 @[46|229220275]: Permission denied
[20180422T19:01:18] {5838} ERR: failed to load the E-Key/E-Spec page 3400, span={offset=62294823,size=4096}, read=4096, expected=4096: E_IO_ERROR
[20180422T19:01:18] {5838} ERR: failed to load ESpec page table
[20180422T19:01:18] {5838} WRN: failed attempt to created the encoding handler (attempt #5)
[20180422T19:01:18] {5838} ERR: failed to create encoding handler for encoding table '7614b754412a0884a3d96e0777a417e6'/'7e6b70f446ea1de9e9d1be1c00854cd8'
[20180422T19:01:18] {5838} ERR: failed to create access component: E_FAILURE
[20180422T19:01:19] {5f44} INF: HTTP: shutdown requested
[20180422T19:01:19] {5f44} INF: HTTP: shutting down
[20180422T19:01:19] {5f44} INF: HTTP: shutdown complete
[20180422T19:01:19] {5838} INF: HTTP: shutdown requested
[20180422T19:01:19] {5838} ERR: network dispatcher: action posted after shutdown
OK
