pxK Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 på min skjerm sitter jeg på side 340 og skriver atm . så da burde det finnes en side 334 også. har sikkert med broweser oppsettet. skal Quote 2sec Hahahaha, sry at jeg ler men du er på side 256 Dagens ^^ Lenke til kommentar
whipslash Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 General * Grouped players that are apprenticed will now get their kill XP capped to the correct level. * Characters should now always get zoned back from a PvP game * Characters should now be able to move away from their spot, without the server thinking that they are hacking * Using a lower rank ability should not lock up your character anymore Quests * Players should no longer lose destiny quests if their quest log is full * Corrected some typos in various quest texts * Updated directions in the quest "A Dangerous Challenge" * The flame on the Torch of Eiglophian will now die after a while in Fields of the Dead. Playfields * Fix a lot of graphics lag issues caused by particles in Tarantia Noble, Field of the Dead and Eiglophian Mountains which should result in much lesser lag in those playfields Player Characters Necromancer * Necromancer - you no longer lose the Cannibalism spell when investing the second feat Guardian * Guardian - Fixed a problem where the third rank in Counterstrike Stance was not giving you the damage shield while in defensive stance. Bear Shaman * Bear Shaman should now correctly recieve Blood Flow (Rank 3), Claws of Stone (Rank 2), and Spirit of the Bear (Rank 2) at level 40. (Note: If you are past level 40, you will gain these spells at level 45, 50, or 55 instead.) Dark Templar *Feat - the Dread Shadow pet will successfully spawn again. NPCs * Ragall the food and drink merchant has received a fresh stock of merchandise. * Ranger archetype NPCs will no longer cause issues with the player's HP displayed incorrectly. Crafting * Bow/Crossbow now require wood * More than 50 alchemy items have been added to vendors City Building * Requirement checks and consumption of resources when building PVE city buildings should be fixed. GUI * Changed the chat colors to be more like what players are used from other games. * The guild chat text is now green * Removed the DirectX 10 option from the option panel. * Removed the 'Remove from Spellbook' functionality * OOC chat channel should no longer be inactive after teleports. QUOTE We are fixing the traders and the banks but some exploits would still be possible with the version we have now. We know how important it is to have traders and banks back in the game but the system must work absolutely correct before we put them live again. The possible exploits that would result when this is not ensured would lead to much bigger issues for all players. Thank you for your understanding. nå som det er sagt. er det flere changes som ikke står i patchnotes. deriblandt den store nerfen til necro's Lenke til kommentar
ellapella Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 flere som har problemer med å logge inn? Får ikke logget inn akurat nå. Logget ut for å ordne noe på en alt, men dessverre får jeg ikke lov til å komme inn igjen. Håper det er et forbigående problem.. hehe Får heller ikke logget inn. Står unable to connect to the character server. (Er på Ymir btw) Jaja, får vaske bilen istedet. Lenke til kommentar
agasøster Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 Hvor mange innlegg har du par side da? Lenke til kommentar
head_hunter Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 (endret) Endret 27. mai 2008 av head_hunter Lenke til kommentar
Damp Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 Jeg har problemer med å logge inn nå :/ Lenke til kommentar
Riot™ Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 103 sider her. Må innrømme at dette spillet ikke har appellert til meg noe særlig før lanseringen. Nå har jeg lyst på spillet men er kraftig blakk. Lenke til kommentar
Hestvik Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 Noen som ikke har problemer med innlogging? Kjenner at jeg gruer meg litt til jeg skal dra hjem, og muligens få en feilmelding ved innlogging. Skal iallefall huske å ta backup Lenke til kommentar
Megnus Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 Til de som har problemer med innlogging; restart maskinen så funker det ^^ Lenke til kommentar
whipslash Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 hadde kun 15 innlegg per side. når har jeg 50 Lenke til kommentar
-iL- Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 Noen som har noe formening om hva jeg kan gjøre for å få bedre FPS? Har en relativt ny maskin, ikke mere enn 4 måneder gammel. 2GB ram, Geforce 8800 GTX, Dual core 6850, får som regel ikke mere enn 20-30+ FPS. Meste jeg noen gang har hatt var 80-85+ når jeg så rett opp på ren himmel. Har ikke alt på max, kjører kun 2x AA og AF, high, men står kun på midelmådig veiw range. Yter rett og slett ræv, Crysis yter 2x bedre med alt på fult :/ Og ja, lasta ned drivere fra NVIDIA datert den 16. mai tror jeg, og så har jeg brukt rivatune, men uten hell. Er frustrerende, den eneste måten å ha stabilt ca 40FPS er å ta shader til 2.0, men da ser spillet ut som ræv... Enkelt, dytt inn 2GB ram til. Hvordan får man 4 gig til å funke på Windows XP? Har prøvd diverse ting, og vet at den klarer max 3.2 gig. Får enten ikke OSt til å starte; bluescreen, eller den starter, så bluescreen. Lenke til kommentar
The Very End Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 Noen som har noe formening om hva jeg kan gjøre for å få bedre FPS? Har en relativt ny maskin, ikke mere enn 4 måneder gammel. 2GB ram, Geforce 8800 GTX, Dual core 6850, får som regel ikke mere enn 20-30+ FPS. Meste jeg noen gang har hatt var 80-85+ når jeg så rett opp på ren himmel. Har ikke alt på max, kjører kun 2x AA og AF, high, men står kun på midelmådig veiw range. Yter rett og slett ræv, Crysis yter 2x bedre med alt på fult :/ Og ja, lasta ned drivere fra NVIDIA datert den 16. mai tror jeg, og så har jeg brukt rivatune, men uten hell. Er frustrerende, den eneste måten å ha stabilt ca 40FPS er å ta shader til 2.0, men da ser spillet ut som ræv... Enkelt, dytt inn 2GB ram til. Hvordan får man 4 gig til å funke på Windows XP? Har prøvd diverse ting, og vet at den klarer max 3.2 gig. Får enten ikke OSt til å starte; bluescreen, eller den starter, så bluescreen. Man må ha 64bits windows ettersom hva jeg forstår. Nekter å fungere med mer enn 3.9-4gb etter det jeg har forstått. Skulle likte å visst hvorfor, men det er visstnok bare slik ;p Lenke til kommentar
BrokenTomato Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 Sliter med det samme. Har noe med voltage og gjøre på hk, men jeg får også bluescreen eller problemer med oppstart da. Har også prøvd vista men samme feilen der. Lenke til kommentar
whipslash Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 Okay, as we all know. Update notes from Funcom aren't always complete. So please post here what you have seen change apart from what's described in hte Official notes. --------------------------------- Disclaimer: Havent checked it all. If it's incorrect please say so. --------------------------------- General * Various framerate improvements * HP regen seem to work now * Crashes and Lag seem better in FoTD and other zones * No reported crash at exit * Some reports of shinier avatar textures (NEW) Classes * Demonologist - Cooldowns added to Shockblast, Waves of flame, Living Firestorm, Inferno of Amber and Hellfire stream. * Necromancer - Unholy Hands - Only working, scaling spell we have gone from 0 seconds cooldown to 45 seconds - no mention in the notes. * Tempest of Set - Quicksand now has a 30 second cooldown - Idol of set is now working as intented (1 up at a time) * Ranger (NEW) - After executing the Salvo combo, arrows are being shot at a considerably lower speed, thus it's a massive nerf to burst damage. UI changes * Group members now have a much larger and visible icon (blue potion bottle) * The select instance button is much bigger and move obvious. Tradeskills and resources * Alchemist tier 2 quest unlocked Mounts * Mammoths are faster and better turn * Speed on horses were scaled down * Mammoths are now as fast as horses oppdateringer som ikke sto i patchnotes Lenke til kommentar
Gjest medlem-105082 Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 Hvorfor tar ikke de dette med da? Det sto jo masse viktige ting der, som jeg mener er mye mer interessant enn det som sto i originalen. Lenke til kommentar
Erlec Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 Jeg lurer på hvorfor vi må laste ned en 15.4gb stor patch jeg :S Tar flere timer jo. Lenke til kommentar
Eremal Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 Jeg lurer på hvorfor vi må laste ned en 15.4gb stor patch jeg :S Tar flere timer jo. Fordi dette er et featuresterkt mmo med framtidig dx10 støtte. Lenke til kommentar
head_hunter Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 Jeg lurer på hvorfor vi må laste ned en 15.4gb stor patch jeg :S Tar flere timer jo. Fordi dette er et featuresterkt mmo med framtidig dx10 støtte. Min var ikke i nerheten så stor Lenke til kommentar
head_hunter Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 (endret) hva er RP-PvP? Endret 27. mai 2008 av head_hunter Lenke til kommentar
