Webkafeen
Kan være noen småbugs i det. Hvis noen ser noen så skrik ut. Annbefaler at du legger det i selve forummappa de og heller includer det til hovedsiden.
___________________________________________________________
<?php
// Endre her
$forummappe = "forum";
$count = 5;
$serverPath = "config.php"; //Må endres!
// Id'er som ikke skal vises. Passer bra hvis man har moderatorforum, stengte tråder etc.
$id1 = "0";
$id2 = "0";
$id3 = "0";
$ikon = "$forummappe/templates/subSilver/images/folder.gif";
//slutt å endre.
include_once("$serverPath");
$db = @mysql_connect("$dbhost", "$dbuser", "$dbpasswd") or die("Kunne ikke koble til forumet");
@mysql_select_db("$dbname", $db) or die("Kunne ikke koble til");
// Ikke rør NOE under her
$result = mysql_query("SELECT
phpbb_topics.topic_title as topic_title,
phpbb_topics.topic_time as topic_time,
phpbb_topics.topic_views as topic_views,
phpbb_topics.topic_replies as topic_replies,
phpbb_topics.forum_id as forum_id,
phpbb_topics.topic_poster as topic_poster,
phpbb_topics.topic_id as topic_id,
phpbb_users.username as username,
phpbb_posts.topic_id as post_id
FROM phpbb_topics, phpbb_users, phpbb_posts
WHERE phpbb_posts.topic_id = phpbb_topics.topic_id AND phpbb_posts.poster_id = phpbb_users.user_id
AND phpbb_topics.forum_id <> '$id1' AND phpbb_topics.forum_id <> '$id2' AND phpbb_topics.forum_id <> '$id3'
ORDER BY topic_last_post_id DESC LIMIT $count");
while ($row = mysql_fetch_array($result))
echo "
 <img src='" . $ikon . "' alt='[*]'" . $row['topic_title'] . "' title='[*]'>
 <a href='$forummappe/viewtopic.php?topic=" . $row['topic_id'] . "&forum=" . $row['forum_id'] . "'>" . $row['topic_title'] . "</a>
 <br>
Edit:
$forummappe [Dette mappen forumet ditt ligger i heter. Har du ikke endre navnet er det nok phpBB2]
$count [bestem hvor mange poster som skal vises]
$serverPath [Denne skal linke til config.php som ligger i forummappa de. Legger du scriptet i forummappa trenger du ikke endre.
$id1, $id2, $id3 [Dette er vis det er forum-id'er du ikke vil vise. (Private forum osv.) Du finner id'ene i phpMyAdmin]
$ikon [Dette er et bilde som kan vises forran postene]
Endret av ett
Noen som kan hjelpe meg med buggene jeg har på siden min: www.juventusnorge.1go.dk
Problemet mitt kan rettes med faux collumns, men det skjønner jeg ikke noe av. Noen som kan gi meg et hint ved å se på css min?
www.juventusnorge.1go.dk/css/layout.css
Takker for svar.
Edit: Problemet ligger i at borderen i menyen ikke strekker seg ned til footeren.
Søk på faux columns her på forumet, og du vil få haugevis av treff!
Faux Columns forklart veldig fort: Du bruker et bakgrunnsbilde med to kolonner. Dette legger du som bakgrunn i en div, også legger du to div'er til over, med float: left; og right; som da tilsvarer menyen din og innholdsfeltet ditt.
Er egentlig ikke noe vanskeligere enn det, håper du skjønte noe av det :)
har egentlig litt problemer med å forstå det fortsatt.
Det jeg skal gjøre:
<div class="wraper">
<div id="nyheter"></div>
<div id="meny"></div>
</div>
css:
div.wraper {
    background: url(http://www.juventusnorge.1go.dk/images/background.png);
    background-repeat: repeat-y 50% 0;
div#nyheter {
  float: left;
div#meny {
  float: right;
Virker ikke logisk. :hmm:
Endret av ett
