Webkafeen
Dette har jeg skrevet i den lille .htm fila mi (den er includa inn på ei større side:
<h7>(c) nanbjor.tk.  <a href="rights2.php" id="h6">All rights reserved </a> André Nanbjør.<br>
<a href="mailto: [email protected]" id="h6">[email protected]</a></h7>
Valideringa på w3school sier:
Line 36, column 3: element "H7" undefined
You have used the element named above in your document, but the document type you are using does not define an element of that name. This error is often caused by incorrect use of the "Strict" document type with a document that uses frames (e.g. you must use the "Frameset" document type to get the "<frameset>" element), or by using vendor proprietary extensions such as "<spacer>" or "<marquee>" (this is usually fixed by using CSS to achieve the desired effect instead).
Line 36, column 47: ID "H6" already defined
...nbjor.tk.  <a href="rights2.php" id="h6">All rights reserved </a> André Nanb
An "id" is a unique identifier. Each time this attribute is used in a document it must have a different value. If you are using this attribute as a hock for style sheets it may be more appropriate to use classes (which group elements) than id (which are used to identify exactly one element).
Line 16, column 26: ID "H6" first defined here
<a href="version.php" id="h6">Version 7.1.0</a></div>
Line 37, column 48: ID "H6" already defined
...ilto: [email protected]" id="h6">[email protected]</a></h7></
Hvorfor er ikke det lov? jeg vil jo ha samme oppsettet på begge linkene?
Hele CSS:
/* CSS Document */
body
background-image: url("Bilder/nanbjor.tk.gif");
background-repeat: no-repeat;
h4
font-family: Arial, Verdana, Tahoma;
font-size: 12px;
font-variant: normal;
color: #0000CC;
letter-spacing: 1px;
word-spacing: 5px;
line-height: 20px;
h5
font-size: 8px;
color: #000000;
h7
font-size: 10px;
color: #000000;
#banner
position: absolute;
top: 17px;
left: 196px;
z-index: 1;
height: 82px;
width: 504px;
#main
position: absolute;
top: 167px;
left: 198px;
z-index: 2;
height: 365px;
width: 530px;
overflow: auto;
padding-right: 10px;
#version
position: absolute;
top: 79px;
left: 629px;
z-index: 4;
height: 20px;
width: 69px;
#meny
position: absolute;
top: 155px;
left: 12px;
z-index: 3;
height: 367px;
width: 187px;
margin-left: 10px;
margin-right: 10px;
margin-top: 10px;
margin-right: 10px;
#lineup
background-image: url("Bilder/lineup.gif");
position: absolute;
top: 131px;
left: 160px;
z-index: 5;
height: 400px;
width: 49px;
#ikon
position: absolute;
top: 18px;
left: 24px;
z-index: 6;
width: 15px;
height: 70px;
#rights
position: absolute;
top: 542px;
left: 198px;
z-index: 7;
width: 500px;
height: 40px;
text-align: center;
img.strek
width: 20px;
height: 400px;
#n
width: 80px;
height: 80px;
p.smallcaps
font-size: 14px;
font-variant: small-caps;
color: #D64312;
word-spacing: 5px;
line-height: 20px;
border: none;
padding: none;
a:link
font-size: 12px;
color: #990000;
text-decoration: none;
a:visited
font-size: 12px;
color: #990000;
a:hover
font-size: 12px;
color: #D64312;
a:active
font-size: 12px;
color: #D64312;
a:link.h6
font-size: 10px;
color: #990000;
a:visited.h6
font-size: 10px;
color: #990000;
a:hover.h6
font-size: 10px;
color: #D64312;
a:active.h6
font-size: 10px;
color: #D64312;
Hvorfor får jeg ikke lov til å bruke h6?
På forhånd takk :)
Får fortsatt feil på h6 greia... (se css fil 3 innlegg over)
...ilto: [email protected]" id="h6">[email protected]</a></h3></
Jeg vil jo ha likt oppsett på begge disse to linkene (som er forskjellige fra de vanlige linkene) slik at jeg får to forskjellige linkoppsett. Men må jeg lage to like oppsett i css og linke hver link til hver av disse? Det er jo teit! Håper jeg har misforstått...
Endret av w3p
Med mindre du kan dokumentere at laptop ikke gir stråling..
En laptop (som nesten alt annet) gir seff fra seg elektromagnetisk stråling, men den skjermes en hel del av kabinettet. Sitter man med jalla-lappis som er bygd i plastikk, sliter man mer enn hvis man betaler litt ekstra for en skikkelig en, bygd i alu eller titan. Var vel Acer ferrari som hadde titan elns. i kabinettet.
Det er det som teller.
Hvis man vil være en virkelighetsfjern skapning med "IAMSOGREAT" låst fast i hjernen, så...
@toss: Nei, jeg tror ikke det er så lurt, men her er en guide på hvordan man endrer stilark med php. Guide av Lokaltog
Seff kan man bruke PHP til å generere stilark. Husk at en CSS-fil ikke må ha .css som filendelse også. Man kan vel fint bruke link href="stil.php" uten at det ødelegger noe særlig. Hvis det ikke vil gå, er det kort prosess å bruke .htaccess til å la PHP parse alle CSS-filer i mappen.
Det man da kan ende opp med er at brukeren selv kan modifisere absolutt alt i stilarket, noe som kan bli seriøst fett. Planlegger å bruke en slik løsning på min egen side om ikke så lenge.
Warning: chmod(): Operation not permitted in blablabla/news/inc/plugins.php on line 182
Får opp denne meldingen i AJ-Fork når jeg bl.a. redigerer nyheter. Det var ikke slik før, og jeg har ikke forandra noe på chmoden til denne filen/mappen. Det virker å redigere nyheten, men får denne meldingen øverst likevel. Har prøvd å chmode filen og mappen den ligger i til 777, men meldingen forsvinner ikke :dontgetit:
