Sharing i wmp11 - 360 finner ikke PC
øyvind78
Hei
Har brukt WMP11 til å share video å vise på 360'en. Dette var lekende enkelt å sette opp. Problemet dukket imidlertid opp i går kveld når jeg skiftet nettverkskort i PC-en. Etter det kan ikke boksen finne PC-en. Når jeg går i media sharing i WMP11 finner den boksen, og jeg får satt opp sharing, men boksen finner altså ingenting.
Har prøvd å deaktivere brannmuren uten hell. Har også aktivert og brukt det gamle nettverkskortet igjen uten at det hjelper.
Har sett endel andre som har samme problemet (PC finner boks, men ikke motsatt), men har ikke sett noen som har en løsning som fungerer.
Håper noen kan hjelpe.
Hei
Fant omsider svaret selv på et annet forum. Klipper inn posten under. Denne løsningen fungerte utmerket.
Løsning:
Ok this is not an issue with a firewall, it took me 3 calls and about 12
transfers to get an answer. For phone help dial 1800-4MY-XBOX then get to
live console help and ask to speak to the hardware department. Describe
issue, most likely will get transferred a couple times till you end up back
at the hardware depart, let them know its a pc failed message. They can walk
you through it.
Its basically a DRM (data rights management) problem. Steps to fix are as
followed:
Click start, go to run
type services.msc
go to Windows Media Player Network Sharing Service
double click it and hit stop
then you will need to be able to see all hidden files and folders:
Open my computer window, and click on the tools tab at the top and select
folder options, and click the view tab
Scroll down make sure show hidden files and folders is shown
then scroll further down and uncheck hide protected operating system
files(recommended)
then you must delete the DRM files in Windows Media center folder:
Click on My Computer, choose your harddrive (usually C:) click on documents
and settings folder, then All Users Folder, and you should see DRM folder
Double click DRM folder
Control and a to select all the files, then shift delete (to skip sending to
the recycle bin), then hit yes, now close this window
Go back to run, type services.msc and highlight Windows Media Player Network
Sharing Services and right click and select start, this should fix the
problem varify you are still sharing the connection via windows media player,
library tab, share media option, and that it still sees your xbox,
restart xbox: go to media tab and select music, choose computer it should
now search and (yes finally) find your computer
