Minneutvidelse Compal CL56
vannreven
Har en straks 3 år gammel Compal CL56. Har 1 GB internminne. Vurderer å utvide til 2 GB. Er dette mulig med denne maskinen? Er det kurant å få tak i egnede minnebrikker 2 stk 1 GB?
Her er utskrift fra PC Wizard:
General Information :
NorthBridge : Intel i855PM
SouthBridge : 82801DBM (ICH4-M) LPC Interface Bridge
NorthBridge Information :
Architecture : HUB
Manufacturer : Intel (Compal Electronics Inc)
Revision : B1
Bus Speed : 99.7 MHz
FSB Frequency : 398.7 MHz (QDR)
FSB max. Support : 400 MHz
RAM max. Support : DDR (266 MHz)
Memory Information :
Type : DDR-SDRAM PC2700
Frequency : 166.1 MHz
DRAM/FSB Ratio : 5/3
Activated Channels : Single
ECC Diagnostic : JaMode
CAS Latency (tCL) : 2 clocks
RAS to CAS (tRCD) : 3 clocks
RAS Precharge (tRP) : 3 clocks
Cycle Time (tRAS) : 7 clocks
Read Delay (tRD) : 4 clocks
Bus Information :
Version : 2.0
Transfert Rate supported : 1x, 2x, 4x
Transfert Rate : 4x
Aperture Size : 64 MB
Side Band supported : Yes
Side Band enabled : Yes
AGP enabled : Yes
Hub Interface Information :
Version : 1.00
Time Slice : 0
Width : 8-bit
Full Duplex : Yes
Frequency : 4x (264 MHz)
Multiplier : 1/1x
Device Capabilities (PCI) :
I/O Access : No
Memory Access : Yes
Bus Master Capable : Yes
Special Cycle Recognition : No
Memory Write & Invalidate : No
VGA Palette Snoop : No
Parity Error Response : No
Cycle Wait : No
System Error Line : No
Fast Back-to-Back : No
Detects Parity Errors : No
User Defined Format : No
PCI 66Mhz Bus Support : No
New Capability List : Yes
PCI Support : Vendor-Dependant
PCI Support : AGP
DRAM SLOT 0 (RAS 0, RAS 1) : 512 (Double Bank)
DRAM SLOT 1 (RAS 2, RAS 3) : 512 (Double Bank)
Information SPD EEPROM (DRAM SLOT 0) :
Manufacturer : Kingston
Part Number : K
Serial Number : 04FFFF04
Type : DDR-SDRAM PC-3200 (200 MHz) - [DDR-400]
Size : 512 MB (2 rows, 4 banks)
Module Buffered : No
Module Registered : No
Module SLi Ready (EPP) : No
Width : 64-bit
Error Correction Capability : No
Max. Burst Length : 8
Refresh : Reduced (.5x)7.8 µs, Self Refresh
Voltage : SSTL 2.5v
Prefetch Buffer : 2-bit
Manufacture : Week 1 of 2004
Supported Frequencies : 133 MHz, 166 MHz, 200 MHz
CAS Latency (tCL) : 2 clocks @133 MHz, 2.5 clocks @166 MHz, 3 clocks @200 MHz
RAS to CAS (tRCD) : 2 clocks @133 MHz, 3 clocks @166 MHz, 3 clocks @200 MHz
RAS Precharge (tRP) : 2 clocks @133 MHz, 3 clocks @166 MHz, 3 clocks @200 MHz
Cycle Time (tRAS) : 6 clocks @133 MHz, 7 clocks @166 MHz, 8 clocks @200 MHz
Information SPD EEPROM (DRAM SLOT 1) :
Part Number : K
Serial Number : 12FFFF06
Width : 64-bit
Voltage : SSTL 2.5v
Manufacture : Week 3 of 2005
Memory Controller Information :
Memory Controller : System Memory
Number of connectors : 2
Max. Module Size : 1024 KB
