LØST: Hva tror dere om dette vannkjølingsoppsettet?
Hei. Skal ha meg vannkjøling. Og så, for å få litt flere svar, tenkte jeg at jeg skulle lage en egen tråd om akkurat dette emnet.
Lurer på hva dere tror om dette oppsettet? Er det noe som mangler i oppsettet mitt? Vet GPU ikke er med der enda, men dem kjøper jeg når jeg vet hvilken GPU jeg skal ha. :)
Og en ting til. Er dette den riktige ThermoChill siden? Den seriøse altså? :)
http://thermochill.com/
Oppsettet. (Se spoiler)
Watercooling parts from Petra’s Tech Shop
Reservoir:
http://petrastechshop.com/ekmure.html
1 piece: 40
Fillport:
http://www.petrastechshop.com/dadendefi.html
1 piece: 12
3-pin extension:
http://www.petrastechshop.com/183pex.html
6 stk: 8
CPU-waterblock:
http://www.petrastechshop.com/dfuuncpubl1.html
1 piece: 64.99
Reservoir-holder:
http://petrastechshop.com/ekmureho.html
1 piece: 5
Radbox:
http://www.petrastechshop.com/swmcrre2raho.html
1 piece: 17.99
Pump:
http://www.petrastechshop.com/swmcin12pu.html
1 piece: 87.99
90° Elbow:
http://www.petrastechshop.com/1odbaco90el.html
10 pieces: 19.5
Tubing:
http://www.petrastechshop.com/7id5odmagepu.html
20 pieces: 10
Swiftech smartcoils:
http://www.petrastechshop.com/40swsm625f5o.html
4 pieces: 11.8
Worm-drive hose clamps:
http://www.petrastechshop.com/ststwohoclwb.html
30 pieces: 38
Thermal compound 1:
http://www.petrastechshop.com/arcomxthco.html
2 pieces: 11.98
Thermal compound 2 (CPU):
http://www.petrastechshop.com/icdi7cathco.html
1 piece: 5.99
Fans:
http://www.petrastechshop.com/12scsysstcaf3.html
4 pieces: 35.96
Fan grills:
http://www.petrastechshop.com/12figuch1.html
5 pieces: 4.95
UV reactive pentosin:
http://www.petrastechshop.com/peg11coadb4o.html
2 pieces: 9
Neoprene Rubber Edge Trim:
http://www.petrastechshop.com/neruedtrmo.html
5 pieces: 4.95
3/4" ID (1 3/8" OD) Rubber Grommet:
http://www.petrastechshop.com/3id13odrugr.html
4 pieces: 2
Fittings for the Swiftech reservoir:
http://www.petrastechshop.com/dhifig1th1od.html
2 pieces: 4.6
382 US Dollars. 2200 NOK
Watercooling parts from ThermoChill.com
Fittings for the radiator:
http://thermochill.com/acatalog/thermochill_accessories.html
2 pieces: 4 GBP
Radiator (3x120mm):
http://www.thermochill.com/pa1203.php
1 piece: 50 GBP
54 GBP. 600 NOK.
2200+600+600=3300
Her er et bilde av hvordan jeg har tenkt å montere det. Noen ulemper med denne måten? I så fall er det bare å si ifra. Setter pris på alle kommentarer. :)
EDIT: Løst. Moderator kan godt stenge tråden nå. :)
Endret av LockBreaker
Holder det ikke med en tråd om dette?
Jo. Gjør vel det. Det er bare at jeg skulle hatt svart fortest mulig og den andre tråden var litt død. :)
Men sier mange takk til de som hjelpte meg der. Fikk svar fra XtremeSystems også nå så har ikke behov for denne tråden mer. :)
Men jeg setter stor pris på all hjelpen dere har gitt meg. Uten dere hadde jeg ikke kommet så langt som jeg kanskje er kommet i dag. :)
EDIT: Moderator kan godt stenge denne tråden nå. Har fått svar på det jeg ønsket. :)
