Modding av Sapphire R9700 pro til FireGL X1
Millman
Har tenkt å kjøpe meg et Sapphire R9700 Pro og modde det til et FireGL X1 :D
Har lest litt om dette men det er litt uklart for meg hvordan man gjør dette,og hvilke kort som støtter dette? :shrug:
http://www.xbitlabs.com/news/story.html?id=1042578447
Er det noen som har testet dette/eventuelt vet om sider man kan lese mer om dette..
Vil ha et Fire GL X1 kort :oops:
Håper noen kan svare meg på dette :yes:
Jeg kan desverre ikke svare deg på det. Men vi er mange som leser her, - hva er dette FireGL Xi - noe å trakte etter for oss andre også, - eller bare noe skit? :D
overview
Please note, FIRE GL™ X1 is available in two configurations: FIRE GL™ X1 128MB configuration, featuring AGP 3.0 8X/4X bus, and FIRE GL™ X1 256MB configuration, featuring AGP PRO50 bus. FIRE GL™ X1 256MB AGP PRO50 requires that your system have an incorporated AGP PRO50 bus. If you are uncertain whether your system has an AGP PRO50 bus, please consult your system administrator or motherboard documentation.
FIRE GL™ X1 is the most advanced workstation graphics board, featuring ATI's FGL™ 9700 Visual Processing Unit (VPU). With revolutionary new architecture and 128 or 256MB of memory, FIRE GL™ X1 delivers groundbreaking performance to power leading DCC and CAD software applications. With the addition of photo-realistic visualization and 3D asset management tools, FIRE GL™ X1, enables the collaborative workflow and accelerates the production pipeline, providing digital content creators, engineers and game developers with the power to generate stunning 3D animation, real-life visual effects and design work in real-time.
Revolutionary graphics architecture
Groundbreaking performance
Cinematic rendering and animation
Stable and reliable Windows® and Linux® support
Optimized for leading CAD and DCC software applications
Enabling collaborative workflow with 3D asset management
features
128 or 256MB DDR memory to meet the needs of the most demanding CAD/CAM engineers and professional animators
256-bit memory interface removes hardware performance bottleneck and provides end users with faster 3D graphics
Industry's first 8-pixel pipeline architecture provides twice the rendering power of any competing product
First 128-bit floating point precision frame buffer allows complex operations without loosing precision for photo-realistic renderings
Supports new AGP 8X standard, providing a two way high-speed interface between the graphics subsystem and the workstation (2.0 GB/sec)
Highest level of realism
24-bit for each color component (RGBA) enables true-life images to be displayed beyond 16.7M colors
First to fully support DirectX® 9.0
First to support DirectX® 9.0 functionality in OpenGL®
New SMARTSHADER™ 2.0 technology allows developers to create more complex visual effects
SMOOTHVISION™ 2.0 technology enhances image quality by removing jagged edges and bringing out fine texture detail, without compromising performance
Optimized Software Support
Provides stable and reliable software support for Windows® and Linux® platforms
Dual monitor support with optional HYDRAVISION™ software
Additional software support available with retail products:
RENDERMONKEY™ - ATI's shader tool developed to allow programmers to customize and accelerate shaders
Right Hemisphere's Deep Visualizer™ provides engineers, designers, artists and animators with a simple, user-friendly tool for hardware acceleration of photo-realistic shaders in leading CAD and DCC software
Right Hemisphere's Deep Exploration™, a 3D asset management tool for efficient sharing of 3D content across a wide variety of mediums
Så forskjellen ligger i at softwaren i kortet er optimisert for CAM/CAD og DCC applikasjoner. Så enkelt er det. Dette er ikke et spillekort
Dette står i artikkelen til Xbit labs:
"When we decided to run some games, the performance appeared somewhat lower than that of the regular RADEON 9700."
flotte greier. aikkert vel å bra til 3d-modellering, men spiller du spill vil du ikke dra nytte av denne moddingen ser det ut som. Men det er jo imponerene at det funker. Sier litt om hvordan de store navnene som Intel, ATI og nVidia lurer oss. Et FireGL kort til 11 000 koster like mye å produsere som et Radeon 9700 til 2000...
