LG dvd spiller, kode til Sonefri
First you have to download linked file called "LG36868.IMG"
http://rapidshare.com/files/14530611/Zoran.zip.html
1. Then you have to burn this file to a blank CD
(The file "LG36868.IMG" is NOT an image file!. Just use
Nero or any of your CD burning programs to write this
file on a CD.
2. After burning, insert the CD into the DVD player and press play
3. Then the region management menu will be shown.
4. Input “0” to make it multi-region and then press the “pause” key by Remote Control.
Dette fant jeg på nettet. Prøves på eget ansvar.
Har ikke testet det selv, men dette påstås å virke:
Download this file:
http://www.chelseaclocks.co.uk/LG/dvx-298h.zip
The zip contains one file plus a text file with instructions.
Burn the file to a blank CD, insert it in your DVD player and it gives access to the region menu. Press "0" (zero) on the remote, then press "Pause" on the remote. You're done.
Tusen takk ;) Gjorde det nettopp... Funka fint det :)
