Gjest Slettet+32asd4f Skrevet 5. juni 2008 Rapporter Del Skrevet 5. juni 2008 (endret) Lian LI replacement for Xbox 360 case said to be "just weeks away" Endret 5. juni 2008 av Slettet+32asd4f Lenke til kommentar
Nüü Skrevet 5. juni 2008 Rapporter Del Skrevet 5. juni 2008 Hva skal vi med den? DEN ER GIGANTISK! Lenke til kommentar
Lakus Skrevet 5. juni 2008 Forfatter Rapporter Del Skrevet 5. juni 2008 Vi skal bruke den til å kjøle Xboxen og få den til å passe bedre inn i TV benken. Lenke til kommentar
Lakus Skrevet 23. juni 2008 Forfatter Rapporter Del Skrevet 23. juni 2008 Lian-Li PC-XB01 Xbox 360 Modding Case Details We received more information and pictures of the Lian-Li PC-XB01 Xbox 360 replacement case: Hva som skjedde med den kassen som skulle visstnok ligne en DVD spiller vet jeg ikke, men det jeg vet er at perforeringen foran på denne gjør den "mindre" vakker. Jeg får se hvordan den er på noen "real life" bilder før jeg orker å kjøpe den. XB01 was first shown at the 2008 CES show in USA, and this concept got a lot of feedback and user suggestions. At the 2008 Computex in Taipei, the final vision of the PC-XB01 Xbox 360 modding case was ready for shipping. Xbox360 is a superb video game console and Lian Li wants to make it even better. Lian Li designers designed the case around the Xbox360 main board, and created the XB01 for Xbox 360 owners who want an Xbox 360 with better cooling performance and that works silently. Not only does it work silently and with better cooling, it is all aluminum, in metallic finishing. Rounded edge, in brushed aluminum with anodized finishing, it can be place up-right or flat-down on the table top. The high quality finishing will fit in most user's living environments. XB01 will help Xbox 360 to have better cooling performance, and running silently. User don't need to worry about overheating problems anymore. Some Features: * There is a 120mm exhaust fan at the rear of the XB01 to replace the original 2x70mm cooling fan, the 120mm fan can move the heat faster at lower speed, and with less noise. * XB01 has a 12cm fan, with high airflow but it only needs to run at 1500RPM to cool down the Xbox 360 effectively. * The Xbox 360 DVD-drive has been relocated to the side, allowing maximum opening for the graphics chipset heatsink and it will also allow users to change the heatsink. * There are sound insulation foam sheets around the DVD drive to reduce the noise. * Huge aluminum airduct that covers the Xbox 360 heatsinks, the cold air will pass through the cooler to remove the heat. * There are water tube openings at the rear of the case, allowing users to upgrade their Xbox 360 to liquid cooling solutions. * The XB01 includes two fan converters for the different versions of the Xbox 360. * There are aluminum flippers to cover and protect the front connectors. Ikke særlig bra gjennomført skal man se på Lian Li's andre kabinetter. Lenke til kommentar
Bebeluv Skrevet 23. juni 2008 Rapporter Del Skrevet 23. juni 2008 Trur Lian Li kan holde seg til pc kabinett. Dessuten unødvendig stor. Lenke til kommentar
( ´Д`) VIP QUALITY!! Skrevet 11. juli 2008 Rapporter Del Skrevet 11. juli 2008 Vi skal bruke den til å kjøle Xboxen og få den til å passe bedre inn i TV benken. Det er morsomt at du sier det, for et slikt kabinett ville nemlig ikke ha fått plass i mitt TV-bord, som jeg vil regne som ganske typisk, størrelsesmessig. Jeg var nysgjerrig først, men nå syns jeg det bare ser for dumt ut. Lenke til kommentar
Kenny Bones Skrevet 11. juli 2008 Rapporter Del Skrevet 11. juli 2008 De har garantert kunne endret størrelsen til det mye mindre dersom de absolutt har villet gjort det. Sjekk hvor mye ekstra luft som er der. Lenke til kommentar
( ´Д`) VIP QUALITY!! Skrevet 11. juli 2008 Rapporter Del Skrevet 11. juli 2008 De gjør det bare enkelt m.t.p. drevet; jeg skulle mye heller ha sett noen 'smarte' løsninger. Lenke til kommentar
-Mr.T- Skrevet 11. juli 2008 Rapporter Del Skrevet 11. juli 2008 Denne er rett og slett stygg, gigantisk, og upraktisk. Kan ikke skjønne at noen skulle kunne tenke seg å bytte ut originalkabinettet med noe så sært... (min mening) Lenke til kommentar
Lakus Skrevet 11. juli 2008 Forfatter Rapporter Del Skrevet 11. juli 2008 Vi skal bruke den til å kjøle Xboxen og få den til å passe bedre inn i TV benken. Det er morsomt at du sier det, for et slikt kabinett ville nemlig ikke ha fått plass i mitt TV-bord, som jeg vil regne som ganske typisk, størrelsesmessig. Jeg var nysgjerrig først, men nå syns jeg det bare ser for dumt ut. Når jeg skrev det innlegget tenkte jeg at de faktisk skulle gjør det mindre, som de sa. Det skjedde ikke... Lenke til kommentar
Jikla Skrevet 14. august 2008 Rapporter Del Skrevet 14. august 2008 har veldig lyst på dette kabinettet pga støy nivået på xboxen. Og kabinettet ble sluppet ut i dag \o/. http://gaming.hexus.net/content/item.php?item=14977 Bare venter på at noen moddere kan fikse det for meg, liker ikke å tukle med sånnt alene :/ Lenke til kommentar
Mala Skrevet 14. august 2008 Rapporter Del Skrevet 14. august 2008 Jaja...så var eg i gang igjen. La like så godt inn ein bestilling på denne her eg ettersom eg skulle bestille ein PSU til lillebror Har to bokser, der den eine allerede har blitt åpnet for viftemod..se om eg slenger inn innmaten fra den i dette Lial Li styret. Lenke til kommentar
Jikla Skrevet 14. august 2008 Rapporter Del Skrevet 14. august 2008 Jaja...så var eg i gang igjen. La like så godt inn ein bestilling på denne her eg ettersom eg skulle bestille ein PSU til lillebror Har to bokser, der den eine allerede har blitt åpnet for viftemod..se om eg slenger inn innmaten fra den i dette Lial Li styret. I så fall kunne du vell hjulpet meg litt over PM osv dersom jeg sitter fast med hva jeg skal gjøre osv. Er litt skeptisk på å flytte på innmaten i xboxen :S Lenke til kommentar
Mala Skrevet 14. august 2008 Rapporter Del Skrevet 14. august 2008 (endret) Skulle vel la seg gjøre Er faktisk ganske enkelt å operere innvendig i boksen. Men vi få se åssen overføringen av innmaten går EDIT: Hadde vert artig å hørt eit lydopptak av boksen i bruk. Er vel ikkje så mange som har skaffet seg den enda men.. Endret 14. august 2008 av Mala Lenke til kommentar
Bebeluv Skrevet 14. august 2008 Rapporter Del Skrevet 14. august 2008 Åssen kan du kjøpe noe sånt Mala? forferdelig stor og ikke veldig pen Lenke til kommentar
Jikla Skrevet 14. august 2008 Rapporter Del Skrevet 14. august 2008 synnst ikke xboxen er noe særlig pen i forhold heller. Og det hadde vert greit med lite støy i forhold til å ha tvn på høg volume styrke i alle fall :/ Ødelegger jo hørselen Lenke til kommentar
Bjonski Skrevet 14. august 2008 Rapporter Del Skrevet 14. august 2008 Det kabinettet der ser værre ut enn det nåværende. Elsker utseende til 360. Lenke til kommentar
Mala Skrevet 14. august 2008 Rapporter Del Skrevet 14. august 2008 Åssen kan du kjøpe noe sånt Mala? forferdelig stor og ikke veldig pen Kall deT eit tvilsomt spontankjøp.. Nei men er artig å få noe å dille med i det minste. Lenke til kommentar
Isbilen Skrevet 14. august 2008 Rapporter Del Skrevet 14. august 2008 (endret) God ide, men det er vel DVD-spilleren som forårsaker mesteparten av bråket fra 360-en? Og går det ikke rykter om at neste revisjon endelig få bukt med levenet? Ellers så jo denne fet ut. 360-en er omtrent like lekker som en såpekopp. Grei å ha med i dusjen, men fullt synlig i stua? Best å slippe. Endret 14. august 2008 av Isbilen Lenke til kommentar
Mala Skrevet 14. august 2008 Rapporter Del Skrevet 14. august 2008 (endret) DVD-drevet vil nok aldri blir roligere under bruk. Men ved neste store oppdatering vil vi jo kunne legge inn spillene på HDD, og dermed er jo problemet allerede løst for de som har plass og ønsker det. EDIT: Ved orginal stand selvfølgelig. Endret 14. august 2008 av Mala Lenke til kommentar
