autoplay funker ikke ? .swf
Heisann.
Jobben har mottat ny web, men en Flash into fungerer ikke som vi vil, autostart funksjonen funker ikke.
Nå er det så at jeg jobber pÅ IT, men Flash koding er overhode ikke min sak, men lurer på om noen kan hjelpe meg her med ett spark i ræva for å få den igang :p
Level #0:
Variable _level0.$version = "WIN 9,0,45,0"
Variable _level0.statusField = "1 of 13"
Movie Clip: Target="_level0.instance1"
Variable _level0.instance1.delay = 2
Variable _level0.instance1.updateFrame = [function 'updateFrame']
Variable _level0.instance1.updateStatus = [function 'updateStatus']
Variable _level0.instance1.autoplayInit = [function 'autoplayInit']
Variable _level0.instance1.autoplay = [function 'autoplay']
Variable _level0.instance1.hideControls = [function 'hideControls']
Variable _level0.instance1.newFrame = NaN
Variable _level0.instance1.autoplayStatus = 0
Movie Clip: Target="_level0.instance1.prevBtn"
Movie Clip: Target="_level0.instance1.nextBtn"
Button: Target="_level0.instance1.nextBtn.instance3"
Variable _level0.instance1.nextBtn.instance3.scale9Grid = [getter/setter] undefined
Variable _level0.instance1.nextBtn.instance3.filters = [getter/setter] [object #6, class 'Array'] []
Variable _level0.instance1.nextBtn.instance3.cacheAsBitmap = [getter/setter] false
Variable _level0.instance1.nextBtn.instance3.blendMode = [getter/setter] "normal"
Variable _level0.instance1.nextBtn.instance3.tabIndex = [getter/setter] undefined
Movie Clip: Target="_level0.instance1.autoplay"
Button: Target="_level0.instance1.autoplay.instance4"
Variable _level0.instance1.autoplay.instance4.scale9Grid = [getter/setter] undefined
Variable _level0.instance1.autoplay.instance4.filters = [getter/setter] [object #7, class 'Array'] []
Variable _level0.instance1.autoplay.instance4.cacheAsBitmap = [getter/setter] false
Variable _level0.instance1.autoplay.instance4.blendMode = [getter/setter] "normal"
Variable _level0.instance1.autoplay.instance4.tabIndex = [getter/setter] undefined
  • 3 måneder senere...
Mener å ha hørt at på grunn av en ny lov/beslutning så skal Flash ha en "click-to-activate"-funksjon, det vil si at videoer på YouTube, og annet innhold, ikke kan starte før man trykker på flash-området.
Kan hende det er denne "oppgraderingen" som er skyld i dette, men det kan jo også være noe annet.
Endret av BorN
