Nautica Skrevet 12. november 2017 Del Skrevet 12. november 2017 Det har kommet en ny firmware til Canon EOS 6D Mark II Firmware Version 1.0.3 incorporates the following fix:Corrects an erroneous display that may appear when some third-party accessories are attached to the hot shoe.Firmware Version 1.0.3 is for cameras with firmware up to Version 1.0.2. If the camera’s firmware is already Version 1.0.3, it is not necessary to update the firmware. Og til Canon Cinama EOS C200 Firmware Version 1.0.2.1.00 incorporates the following enhancements:When CN-E70-200mm T4.4 L IS KAS S is attached the following features are enabled:Autofocus using the Dual Pixel CMOS AF functionDual Pixel Focus Guide function.The joystick on the camera’s grip unit can be set to operate the zoom.Manual control of the iris with Camera’s Control dial.Control of focus, zoom and iris using the separately-sold Remote Controller RC-V100.Automatic aperture and push auto iris functions.Start/stop recording on the separately-sold lens grip ZSG-C10.Retrieval of Lens metadata, such as the model name and the focal distance will display on the camera.Peripheral illumination / chromatic aberration correction.Caution:You cannot perform the firmware update using CFast 2.0 cards. Please use a commercially available SD/SDHC/SDXC memory card that is 128MB or more for the firmware update.Firmware version 1.0.2.1.00 is for updating Cinema EOS C200 cameras running firmware version 1.0.0.1.00 – 1.0.1.1.00. If your camera’s firmware is already version 1.0.2.1.00, it is not necessary to update the firmware. Once the camera is updated to the latest version, it cannot be restored to a previous version.For further information, please refer to the latest version of the unit’s Instruction Manual that is released with the firmware update.The following things are required to perform this firmware update:An EOS C200 or EOS C200B camera bodyA computer (OS Requirements: Mac OS 10.7 – 10.13)A 128 MB or higher-capacity SD/SDHC/SDXC memory card (both commercially available)An SD card reader/writer (commercially available) or an SD card slot built into the computerA fully charged battery pack for the cameraCompact power adapter bundled with the cameraThe firmware (the downloaded file) Lenke til kommentar
Comma Chameleon Skrevet 14. november 2017 Del Skrevet 14. november 2017 Noen som tenker at det blir heftige tilbud på tripods og slikt nå til Black Friday? Har mulighet til å kjøpe en MT055CXPRO4 til 2500. Er det slå-til pris eller burde jeg vente? Lenke til kommentar
Comma Chameleon Skrevet 14. november 2017 Del Skrevet 14. november 2017 Se der ja. Må vel kanskje klare å holde ut. Hatt drittstativ lenge nå, så et par uker til må jeg vel overleve. Merker at det er uvant at det blir mørkt så utrolig kjapt for tiden. Må komme meg veldig tidlig ut for å fotografere, men det er spennende å se litt snø igjen. Blir vel lysere jo mer det snør også. Håper på masse flotte bilder i løpet av vinteren! Lenke til kommentar
Nautica Skrevet 16. november 2017 Del Skrevet 16. november 2017 Sakset ut fra denne artikkelen Natt til fredag 17. og lørdag 18. november. Nymånen gir ekstra gode lysforhold for meteorsvermen Leonidene Kan det være verdt å se mot himmelen hvis det er klarvær der du bor, og du finner et utkikkspunkt uten for mye lysforurensning Lenke til kommentar
Nautica Skrevet 16. november 2017 Del Skrevet 16. november 2017 Lyst på og gi noen en julepresang eller tre ? 1 Lenke til kommentar
TGB Skrevet 16. november 2017 Del Skrevet 16. november 2017 (endret) Snart Nobel-dagene igjen. Forundrer meg stadig over hvor ekstremt komplisert akkreditering skal være, med inndeling i ørten forskjellige søknader. Hva med en søknad og checkbox for hva man søker på? Ville gjort livet for alle parter enklere. Sitter jo å fikler i 30+ min for å få alt på plass. Endret 16. november 2017 av TGB Lenke til kommentar
fo2re Skrevet 17. november 2017 Del Skrevet 17. november 2017 Noen som har erfaring med salg av kunstverk/fotobasert med modell og hvordan man betaler en modell ?Bilde(ne) vil bli laget for salg i 1 eksemplar og solgt i Europa. Lenke til kommentar
TGB Skrevet 17. november 2017 Del Skrevet 17. november 2017 Noen som har erfaring med salg av kunstverk/fotobasert med modell og hvordan man betaler en modell ? Bilde(ne) vil bli laget for salg i 1 eksemplar og solgt i Europa. Jeg vil si sett opp en deal med en andel av salgs-summen, når verket faktisk er solgt (så slipper du de utgiftene før du faktisk har inntekt). Husk også på at å bare betale modell kan sees på som lønn om det er over en viss sum, og da er du virkelig på glattisen relatert krav og regler. Om modell er næringsdrivende blir dette mye enklere. Lenke til kommentar
Snikpellik Skrevet 17. november 2017 Del Skrevet 17. november 2017 Det enkleste er å bruke modeller gjennom byrå, som sikrer at modellens rettigheter og lønn blir godt ivaretatt. Virker som dette bildet allerede er tatt, og da er jeg helt med på det TGB sier om andel av salgssummen. Pass på å skrive en modellkontrakt, og avtal skriftlig med kunde sånn at alt er på det rene bruksmessig Lenke til kommentar
fo2re Skrevet 17. november 2017 Del Skrevet 17. november 2017 Takk for svar, bildene er ikke tatt, og vil avklare alt på forhånd og lager selvsagt kontrakt som dekker alt.Lite interessant at kommer noen kavende i ettertid at "angrer" på et bilde som i teorien henger på en vegg ett-eller-annet-sted.Dette er også nytt for kunstneren, men vi er 100 % enig uten å blunke at modellen skal ha betalt så lenge dette er et bilde som vil gi en viss inntjening. Lenke til kommentar
Snikpellik Skrevet 17. november 2017 Del Skrevet 17. november 2017 Om jeg gjør noe som ikke er en betalt jobb i utgangspunktet, for eksempel et personlig prosjekt, er første bud at alle de andre jeg eventuelt har involvert skal betales før meg. Det synes jeg er en fin tankegang. Lenke til kommentar
Inc Skrevet 17. november 2017 Del Skrevet 17. november 2017 (endret) Ja... har vært litt av fotoen kan du si.. Men jakter lysterk fotosensor til droner. Noen med erfaring på det området? Kjenner til de som sitter i DJI, Phantom , X5 etc, men ser etter alternativerEdit: og helst ikke i prisklasse 3000$ Endret 17. november 2017 av Inc Lenke til kommentar
awesnes Skrevet 18. november 2017 Del Skrevet 18. november 2017 På utkikk etter ny pc (laptop) for tiden. Ønsker 17" skjerm, ssd+vanlig harddisk og minst 16 gb minne. Pris 12 000 +/-. Bruk: Bilderedigering (PS) og evt litt enkel videoredigering. Kommer stort sett opp bare spill-pcer under søket, det er vel kanskje ikke det beste til mitt bruk? Men kom over denne her hos Dell. Noen formeninger om den? (Vil undersøke hvor mye det evt vil koste å oppgradere til 32GB Ram) http://www.dell.com/no/p/inspiron-17-5770-laptop/pd?oc=cn77004&model_id=inspiron-17-5770-laptop Og ja, jeg venter selvsagt på Black Friday for å se om det er noen tilbud da. Lenke til kommentar
se# Skrevet 18. november 2017 Del Skrevet 18. november 2017 (endret) På utkikk etter ny pc (laptop) for tiden. .... Spill-PC kan godt være et godt utgangpunkt selv for bruken du skisserer. De har gjerne bra ytelse, men skjermen kan være et svakt punkt da oppfriskningshastighet gjerne er høyere prioritert enn gode farger. PC'en du linker til ser ut til å være et bra alternativ og ganske mye for pengene med både SSD og stor snurredisk. IPS-skjerm er gjerne bedre enn TN-skjerm når det gjelder farger, men IPS er ingen garanti for en veldig god skjerm. 4GHz prosessor høres jo fint ut, men det er maks turbofrekvens og dette er prosessor med relativt lav TDP og 1.8GHz basis-frekvens. Uansett rimelig bra prosessor. 17-tommer skjerm er fint hvis du skal frakte PCen mye rundt og jobbe på skjermen (bortsett fra at PCen blir stor og tung da), men personlig synes jeg 15-tommer er like bra hvis PCen skal stå mest et sted hvor man kan ha ekstern skjerm i tillegg. Endret 18. november 2017 av se# Lenke til kommentar
Nautica Skrevet 19. november 2017 Del Skrevet 19. november 2017 (endret) Kjøpte selv en Dell XPS 17" i 2012, fant ut at det var rimeligere og kjøpe med 1TB snurredisk og kjøpe/sette inn en SSD selv. Har i etterkant installert W10, og faktisk så er jeg litt overrasket at Dell fortsatt oppgraderer maskinen og alle drivere automatisk, kjøpte dog med 2års serviceavtale den gangen men kan hende de har glemt å annullere den selv om den står med 0 dager på kontoen min. Endret 19. november 2017 av Nautica Lenke til kommentar
johome Skrevet 19. november 2017 Del Skrevet 19. november 2017 Morsomme meningsutvekslinger på Youtube ..... JPEG vs RAW ......Tony Northrup vs Jared Polin Lenke til kommentar
se# Skrevet 19. november 2017 Del Skrevet 19. november 2017 Morsomme meningsutvekslinger på Youtube ..... JPEG vs RAW ......Tony Northrup vs Jared Polin Jeg ville heller sagt pinlige. Lenke til kommentar
Comma Chameleon Skrevet 19. november 2017 Del Skrevet 19. november 2017 Uansett om hva man mener om raw vs jpeg så virker det som det er Jared som lager drama i alle fall. YouTube-drama er veldig lønnsomt viser det seg. Lenke til kommentar
