Chatte-tråd for oss på Akam!
Lightroom 7 blir sannsynligvis annonsert i Oktober
https://photorumors.com/2017/09/21/adobe-lightroom-7-rumored-to-be-announced-in-october/
Fra en som har testet betaversjonen :
Since two days I am investigating the improvements of the new and still unreleased LR 7 (still beta). Please note that it is a beta and EVERYTHING I write here is subject to change.
Let me stress that for the desktop classic LR the developers have expressly stated that performance is the most important agenda within their list of improvements. Even re-stated it like 5 times
On side note: bear in mind that in my workflow I am strictly following every possible advice on speeding LR there is. Things like BIG cache setting in LR, RAM, SSD, CPU with 4 cores, DNG conversion... etc. are part of my everyday workflow. That is why I am mentioning my take based on that workflow.
Additionally - what seems to be good or bad on my system, might not turns out to be OK on your system and vice versa. Each detail in your software & hardware configurations might (and usually does) turn out to make big impact on any aspect related to any specific program (LR in this case).
So far local adjustments performance seems tremendously improved.
The problem before: If in your work you are a perfectionist like me you would have met the issue of progressive slowing down with the increase of local adjustments and heals whenever they are made. It would go to that point that after the 5th image with a dozen of heals the next image would not load for less than 10 seconds.
This seems to be now remedied. Will have to further push it with a bigger series with more heals and local adj. per picture.
Sjefen var salig enig i at jeg tok for dårlige bilder.
Så nå har jeg fått ett D500.
Det er et hardt liv.
Da er D500 testet. Fokussystemet er fullt kapabelt for å få stillestående pensjonister i en trapp skarpe. Så vet vi det.
D500, 18-35@18mm, f/2.8, ISO3200, 1/50s
Endret av Simon Aldra
  • Liker 4
Gjest Slettet+5132
Lurer vel egentlig på om de kommer til å bruke dybdesensoren i iPhoneX til kantdeteksjon (vil fungere på objekterr som er nærme, eg ved et portrett), som igjen kan brukes som informasjon til støyfjerningsalgoritmene. Nå skal det sies at TV-minimeringsalgoritmer allerede bevarer kanter til en viss grad, men de kan alltids bli bedre.
Nå er vel eksempelbildene over kun gjort av et papirbilde, så der ville de ikke fått noen gevinst av dybdesensoren uansett :p
Helt enig! Har aldri kjøpt kamerautstyr nytt og tror ei heller jeg blir å gjøre det. Folk er så flinke å ta vare på utstyret at det er alltid best (for meg) å kjøpe brukt.
Om ikke nytt kamera på en eller annen måte optimaliserer workflowen min; så ser jeg ingen poeng med å kjøpe nytt - vanligvis er det såpass mange forbedringer at det for meg gir nytteverdi å henge på siste generasjon utstyr. Noen ganger må man kjøpe nytt fordi det gamle begynner å bli utslitt selvsagt.
