Chatte-tråd for oss på Akam!
Hmm har forstått det sånn at vist bildet blir publisert på Fjaseboka fraskriver den som legger ut/tatt bilde seg alle retter, har slutta å legge ut bilder på Fjaseboka pga det!? :hmm:
Er vel slik at facebook har da rettighetene til å bruke bildet selv, mens andre mennesker ikke har rett til å bruke bildet uten tillatelse?
Fra facebook
We are not claiming and have never claimed ownership of material that users upload. The new Terms were clarified to be more consistent with the behavior of the site. That is, if you send a message to another user (or post to their wall, etc...), that content might not be removed by Facebook if you delete your account (but can be deleted by your friend). Furthermore, it is important to note that this license is made subject to the user's privacy settings. So any limitations that a user puts on display of the relevant content (e.g. To specific friends) are respected by Facebook. Also, the license only allows us to use the info "in connection with the Facebook Service or the promotion thereof." Users generally expect and understand this behavior as it has been a common practice for web services since the advent of webmail. For example, if you send a message to a friend on a webmail service, that service will not delete that message from your friend's inbox if you delete your account.
You may remove your User Content from the Site at any time. If you choose to remove your User Content, the license granted above will automatically expire, however you acknowledge that the Company may retain archived copies of your User Content.
When you publish content or information using the "everyone" setting, it means that you are allowing everyone, including people off of Facebook, to access and use that information, and to associate it with you (i.e., your name and profile picture)....
Gjest Slettet+3124
Vi er ikke i april engang, og du klager over at det kommer mer snø? :p
Her på Jæren så er det vanligvis nesten sommer på denne tiden av året.. :p Så ja, jeg er lei vinteren og spesielt snøen.. :)
Gjest Slettet+3124
Ja..!! Det er godt å komme seg vekk i fra Østlandet og -20 & 2 meter snø.. til Jæren hvor det er vanlig med -3 i perioder og veldig lite snø. Nå skal det også sies at det var kaldt her i vinter også.. hadde en periode på 4 - 5 uker hvor vi hadde ned mot 18 - 20 minus. :) Men som jeg har forstått det så er dette ikke normalen.. :)
Gjest Slettet+3124
Litt mere om telefoner, jeg har en HTC Legend, Samsung Galaxy S & en iPhone 3G. Og dette blir litt som med nettlesere, hvilken skal jeg bruke? Alle er gode, men på litt forskjellig måte, og dermed klarer jeg ikke å bestemme meg for hvilken mobil jeg skal bruke. :p iPhoenen har versjon 4.2.1, Samsung Galaxy S har versjon 2.2.1, mens HTC Legend har versjon 2.2.
Tja.. hva sier folket? :)
Gjest Slettet+3124
Jeg synes ikke du trenger 3 telefoner så du kan jo bruke htc og sende en av de andre til meg:-)
Hehe.. jeg har faktisk lekt med tanken med å kvitte meg med telefoner, så slipper jeg "problemet" mitt.. :) Men da kjenner jeg meg rett, så blir det kjøpt en nye mobil om ikke alt for lenge.. og da er jeg tilbake til "problemet" igjen... :p
Eg har ikkje lagt biletet ut på facebook. Det er i tilfelle den avbilda personen som har gjort, noko han heller ikkje hadde lov til, men det er ein annan sak.
HVIS det i det heile er facebook biletet stammar frå.
Svarte. Var ved den lokale fossen i dag og skulle ta noen bilder. Drar frem kameraet fra sekken og skal snu solblenderen riktig vei, glemmer å ta av meg hanskene og solblenderen glipper ut av det svake fingergrepet mitt. Lager en lyd når det treffer steinen ved siden av meg og skyter fart rett uti fossen mens jeg bare kan stå og se på. Kløne!
Sjekker på fotovideo at en ny koster 400,- (er til Canon 70-200mm F4 L USM).
Men fant en på ebay nå til ca 33,-.
Er vel ikke akkurat original, men tenker jeg prøver den. Er den shappy så kjøper jeg heller en original senere.
Satan det var surt.
Edit: Hva tror dere om denne? http://www.dealextreme.com/p/bg-e9-compatible-vertical-external-battery-grip-for-canon-60d-55698
Endret av Alt-Ctrl
