Haventh Skrevet 3. januar 2008 Del Skrevet 3. januar 2008 Fyrte opp gentoo 32bit livecd. Startet installasjonen. Naar den installerte system verktoyene saa fikk den en installation failure etterhvert. Har sett litt paa loggen selv men blir ikke noe serlig klokere. Noen som kan tyde det for meg? Ogsaa hva jeg kan gjore for aa fikse det. GLI: January 03 2008 17:21:49 - Gentoo Linux Installer version 0.5.4 GLI: January 03 2008 17:25:30 - Gentoo Linux Installer version 0.5.4 GLI: January 03 2008 18:23:46 - Gentoo Linux Installer version 0.5.4 GLI: January 03 2008 18:26:28 - Mounted mountpoint: / GLI: January 03 2008 18:26:28 - Created mountpoint /windows GLI: January 03 2008 18:26:30 - Mounted mountpoint: /windows GLI: January 03 2008 18:50:04 - Stage3 was generated successfully GLI: January 03 2008 18:50:06 - Chroot environment ready. GLI: January 03 2008 18:53:14 - Portage tree install was custom. GLI: January 03 2008 20:14:12 - Edited Config file /mnt/gentoo/etc/make.conf GLI: January 03 2008 20:14:12 - Edited Config file /mnt/gentoo/etc/make.conf GLI: January 03 2008 20:14:12 - Edited Config file /mnt/gentoo/etc/make.conf GLI: January 03 2008 20:14:12 - Edited Config file /mnt/gentoo/etc/make.conf GLI: January 03 2008 20:14:12 - Edited Config file /mnt/gentoo/etc/make.conf GLI: January 03 2008 20:14:12 - Make.conf configured GLI: January 03 2008 20:15:15 - Root Password set on the new system. GLI: January 03 2008 20:15:19 - Edited Config file /mnt/gentoo/etc/conf.d/clock GLI: January 03 2008 20:15:19 - Timezone set. GLI: January 03 2008 20:15:45 - Starting emerge_kernel, package is livecd-kernel GLI: January 03 2008 20:17:41 - Edited Config file /mnt/gentoo/etc/conf.d/hostname GLI: January 03 2008 20:17:41 - Edited Config file /mnt/gentoo/etc/conf.d/domainname GLI: January 03 2008 20:17:41 - ERROR! Failure adding domainname to runlevel default because it was not found! GLI: January 03 2008 20:17:41 - ERROR! Could not add domainname to runlevel default. returned a bad status code. GLI: January 03 2008 20:17:41 - Edited Config file /mnt/gentoo/etc/hosts GLI: January 03 2008 20:17:41 - Added net.eth0 to runlevel default GLI: January 03 2008 20:17:41 - Edited Config file /mnt/gentoo/etc/conf.d/net GLI: January 03 2008 20:18:52 - dhcpcd emerged. GLI: January 03 2008 20:21:32 - Added syslog-ng to runlevel default GLI: January 03 2008 20:21:32 - Logging daemon installed: syslog-ng GLI: January 03 2008 20:22:38 - Added vixie-cron to runlevel default GLI: January 03 2008 20:22:38 - Cron daemon installed and configured: vixie-cron GLI: January 03 2008 21:40:03 - Exception received during 'Installing filesystem tools': EmergePackageError :FATAL: emerge: Could not emerge x11-apps/xinit-1.0.2-r6! GLI: January 03 2008 21:40:03 - Traceback (most recent call last): GLI: January 03 2008 21:40:03 - File "/opt/installer/GLIClientController.py", line 122, in run func() GLI: January 03 2008 21:40:03 - File "/opt/installer/GLIArchitectureTemplate.py", line 1031, in install_filesystem_tools exitstatus = self._portage.emerge(package, self._install_profile.get_grp_install()) GLI: January 03 2008 21:40:03 - File "/opt/installer/GLIPortage.py", line 302, in emerge raise GLIException("EmergePackageError", "fatal", "emerge", "Could not emerge " + pkg + "!") GLI: January 03 2008 21:40:03 - GLIException: EmergePackageError :FATAL: emerge: Could not emerge x11-apps/xinit-1.0.2-r6! Takker for alle svar. Lenke til kommentar
MarkT Skrevet 3. januar 2008 Del Skrevet 3. januar 2008 Gentoo er kjent for å være problematisk fra Live-cd, du har bedre sjangse for å lykkes ved å bruke terminalen for å installere, det skal ligge et ikon på skrivebordet for det. Ellers bør du prøve å finne en ren-installasjonscd å prøve det. Lenke til kommentar
arnizzz Skrevet 4. januar 2008 Del Skrevet 4. januar 2008 Gentoo er kjent for å være problematisk fra Live-cd, du har bedre sjangse for å lykkes ved å bruke terminalen for å installere, det skal ligge et ikon på skrivebordet for det. Ellers bør du prøve å finne en ren-installasjonscd å prøve det. Second. Har kjørt grafisk installasjon noen ganger. Og det fungerer ofte, men slett ikke alltid. Installer fra CLI Som pluss blir man bedre kjent med systemet. Lenke til kommentar
Haventh Skrevet 4. januar 2008 Forfatter Del Skrevet 4. januar 2008 Takk for den sjappe responsen. Jeg startet tidlig i dag med å installere gentoo fra minimal 2007.0 cden. For øyblikket så driver jeg med make.conf, men venter på et svar i gentoo forumet. Lenke til kommentar
arnizzz Skrevet 4. januar 2008 Del Skrevet 4. januar 2008 Takk for den sjappe responsen. Jeg startet tidlig i dag med å installere gentoo fra minimal 2007.0 cden. For øyblikket så driver jeg med make.conf, men venter på et svar i gentoo forumet. sjekk gentoo-wikien for safe cflags. Lenke til kommentar
Håvard Skrevet 4. januar 2008 Del Skrevet 4. januar 2008 Hvor lang tid pleier en Gentoo-installasjon å ta? Hvis man skal ha med Xorg, og Gnome... Har en relativt brukbar prosessor: Intel Centrino Duo 1.8 GHz Lenke til kommentar
