Blåskjerm problemer id 10016
Får blåskjerm i ny og ne og har på en måte funnet hvordan jeg skal fikse det. Har WinXP pro
Type in “Network Service” in the “Enter the object names to select” box.
Click on the “Ok” button
Her går det ikke å legge til "Network Service", den godtar ikke det. Har funnet denne beskrivelsen mange plasser på nettet sp tror ikke de har skrevet noe feil.
Noen som kjenner til dette?
Event Type:	Error
Event Source:	DCOM
Event Category:	None
Event ID:	10016
Date:		6/17/2005
Time:		11:38:21 AM
User:		NT AUTHORITY\NETWORK SERVICE
Computer:	ZEPPELIN
Description:
The application-specific permission settings do not grant Local Activation
permission for the COM Server application with CLSID
{BA126AD1-2166-11D1-B1D0-00805FC1270E}
to the user NT AUTHORITY\NETWORK SERVICE SID (S-1-5-20).  This security
permission can be modified using the Component Services administrative tool.
To fix this I had to do the following
Start > Administrative Tools > Component Services
In Component Services
Expand:
Component Services > Computers > My Computer > DCOM Config
Select “netman” from the list in the right window.
Right click “netman” select “properties”
In the “Netman Properties” window select the “Security” tab.
In the “Security” tab look for “Launch and Activation Permissions”. Select
Customize then click on the “Edit” Button.
In the “Launch Permissions” window click on the “Add” button.
Click on the “Ok” button.
Select the “Network Service” in the Launch Permission “Security” Tab, Group
or user names area and give it (allow rights) for “Local Launch” and “Local
Activation”
Click “Ok”
Click “Ok”
Close Component Services.
Check the event view to make sure the errors stop occurring.
