norwegian_viking Skrevet 11. februar 2003 Del Skrevet 11. februar 2003 http://80.213.15.82 Kan en eller annen gå inn på den adressen? Nettopp fått installert Apache server, men mistenker at ingen utenfor nettverket ikke får gått inn på den. :-? Lenke til kommentar
[muffin] Skrevet 11. februar 2003 Del Skrevet 11. februar 2003 connection refused Lenke til kommentar
RS2000 Skrevet 11. februar 2003 Del Skrevet 11. februar 2003 The page cannot be displayed The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings. -------------------------------------------------------------------------------- Please try the following: Click the Refresh button, or try again later. If you typed the page address in the Address bar, make sure that it is spelled correctly. To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP). If your Network Administrator has enabled it, Microsoft Windows can examine your network and automatically discover network connection settings. If you would like Windows to try and discover them, click Detect Network Settings Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed. If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0. Click the Back button to try another link. Cannot find server or DNS Error Internet Explorer Lenke til kommentar
CreAtiv3 Skrevet 11. februar 2003 Del Skrevet 11. februar 2003 Internet levrandør har du? Lenke til kommentar
norwegian_viking Skrevet 11. februar 2003 Forfatter Del Skrevet 11. februar 2003 Er det noen apache guruer som vet hvorfor det bare er nettverket som kan gå inn på serveren? Kjører versjon 2.0.44 på windows. Alt av firewall er for øyeblikket slått av. Takker for all hjelp Lenke til kommentar
norwegian_viking Skrevet 11. februar 2003 Forfatter Del Skrevet 11. februar 2003 Telenor Lenke til kommentar
muffe Skrevet 11. februar 2003 Del Skrevet 11. februar 2003 Du må forwarde port 80 i routeren din. Lenke til kommentar
norwegian_viking Skrevet 11. februar 2003 Forfatter Del Skrevet 11. februar 2003 Har ikke router, bare vanlig adsl modem. Lenke til kommentar
