Gjøre om til sonefri på helt nytt samsung anlegg. Hvordan?
  • 4 måneder senere...
Heisann.
Prøv dette:
eject any dvd's then:-
1) turn off player (at the wall) wait 30 secs til completely powered down
2) turn power back on
3) use remote to turn player on and wait for it to power up (will likely show DVD on the display)
4) Press "Enter" on the remote
5) press in sequence " 8, 4, 2, 6, 9 " on the remote
6) then press "Enter" on the remote again
dvd player should turn itself off, when you power it up again it should be region free.
hentet fritt herfra:http://www.avforums.com/forums/showthread.php?t=596009
Vi har et x250 og det funket fint her. Håper det funker for deg også.
