skrola Skrevet 26. desember 2007 Del Skrevet 26. desember 2007 Har lasta ned et par axxo filmer som jeg skulle ha brent ut på dvd, har gjort de om til dvd format med "xtodvdconvert". Men når jeg skal brenne de med Nero kommer følgende feil melding opp: "Burn process failed at 8x (11,080 KB/s)" Her er feilloggen: Windows XP 5.1 IA32 WinAspi: - NT-SPTI used Nero Version: 8.2.8.0 Internal Version: 8, 2, 8, 0 (Nero Express) Recorder: <_NEC DVD+-RW ND-6500A> Version: 203D - HA 1 TA 0 - 8.2.8.0 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : default CD-ROM: <DP3751O JLU444E >Version: 1.0 - HA 1 TA 1 - 8.2.8.0 Adapter driver: <SCSI> HA 1 === Scsi-Device-Map === DiskPeripheral : FUJITSU MHU2100AT atapi Port 0 ID 0 DMA: On CdRomPeripheral : _NEC DVD+-RW ND-6500A atapi Port 1 ID 0 DMA: On CdRomPeripheral : DP3751O JLU444E 1.0 au82lxui Port 2 ID 0 DMA: Off === CDRom-Device-Map === _NEC DVD+-RW ND-6500A D: CdRom0 DP3751O JLU444E E: CdRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte BUFE : 0 Physical memory : 2047MB (2096360kB) Free physical memory: 1411MB (1445884kB) Memory in use : 31 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 25.12.2007 UDF/ISO compilation 5:42:36 PM #1 Text 0 File SCSIPTICommands.cpp, Line 450 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 5:42:36 PM #2 Phase 112 File dlgbrnst.cpp, Line 1767 DVD-Video files reallocation started 5:42:36 PM #3 Phase 114 File dlgbrnst.cpp, Line 1767 DVD-Video files reallocation completed (no file modified) 5:42:36 PM #4 Text 0 File Isodoc.cpp, Line 6655 UDF document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO Mode : 1 UDF Mode : UDF/ISO bridge UDF Options : automatic UDF Revision : 1.02 UDF Partition Type : physical ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : FALSE Allow pathdepth more than 8 directories : FALSE Allow more than 255 characters in path : FALSE Write ISO9660 ;1 file extensions : TRUE 5:42:36 PM #5 Phase 111 File dlgbrnst.cpp, Line 1767 DVD-Video files sorted 5:42:36 PM #6 ISO9660GEN -11 File Geniso.cpp, Line 3349 First writeable address = 0 (0x00000000) 5:42:36 PM #7 ISO9660GEN -11 File Geniso.cpp, Line 3349 First writeable address = 0 (0x00000000) 5:42:37 PM #8 SPTI -1080 File SCSIPassThrough.cpp, Line 197 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1080) CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00 Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x3A Sense Qual: 0x00 Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 3A Buffer x04b10040: Len x20 5:42:37 PM #9 SPTI -1080 File SCSIPassThrough.cpp, Line 197 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1080) CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00 Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x3A Sense Qual: 0x00 Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 3A Buffer x04b10040: Len x20 5:42:37 PM #10 SPTI -1080 File SCSIPassThrough.cpp, Line 197 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1080) CDB Data: 0x52 01 00 00 00 FF 00 00 20 00 00 00 Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x3A Sense Qual: 0x00 Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 3A Buffer x04b10040: Len x20 5:42:37 PM #11 SPTI -1080 File SCSIPassThrough.cpp, Line 197 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1080) CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00 Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x3A Sense Qual: 0x00 Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 3A Buffer x04b10040: Len x20 5:42:37 PM #12 SPTI -1080 File SCSIPassThrough.cpp, Line 197 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1080) CDB Data: 0x52 01 00 00 00 FF 00 00 20 00 00 00 Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x3A Sense Qual: 0x00 Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 3A Buffer x04b10040: Len x20 5:42:37 PM #13 Text 0 File Burncd.cpp, Line 3502 Turn on Disc-At-Once, using DVD media 5:42:38 PM #14 SPTI -1080 File SCSIPassThrough.cpp, Line 197 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1080) CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00 Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x3A Sense Qual: 0x00 Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 3A Buffer x04b10040: Len x20 5:42:38 PM #15 SPTI -1080 File SCSIPassThrough.cpp, Line 197 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1080) CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00 Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x3A Sense Qual: 0x00 Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 3A Buffer x04b10040: Len x20 5:42:38 PM #16 SPTI -1080 File SCSIPassThrough.cpp, Line 197 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1080) CDB Data: 0x52 01 00 00 00 FF 00 00 20 00 00 00 Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x3A Sense Qual: 0x00 Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 3A Buffer x04b10040: Len x20 5:42:38 PM #17 SPTI -1080 File SCSIPassThrough.cpp, Line 197 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1080) CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00 Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x3A Sense Qual: 0x00 Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 3A Buffer x04b10040: Len x20 5:42:38 PM #18 SPTI -1080 File SCSIPassThrough.cpp, Line 197 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1080) CDB Data: 0x52 01 00 00 00 FF 00 00 20 00 00 00 Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x3A Sense Qual: 0x00 Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 3A Buffer x04b10040: Len x20 5:42:55 PM #19 Text 0 File FilesystemSettingsValidator.cpp, Line 142 FS Settings: using validator 'CUDFSettingsValidatorDVD' ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical' Changing UDF revision from '1.02' to '1.02' 5:42:55 PM #20 ISO9660GEN -11 File Geniso.cpp, Line 3349 First writeable address = 0 (0x00000000) 5:42:55 PM #21 ISO9660GEN -11 File Geniso.cpp, Line 3349 First writeable address = 0 (0x00000000) 5:42:57 PM #22 Text 0 File DlgWaitCD.cpp, Line 307 Last possible write address on media: 2298495 (510:46.45, 4489MB) Last address to be written: 1878975 (417:33.00, 3669MB) 5:42:57 PM #23 Text 0 File DlgWaitCD.cpp, Line 319 Write in overburning mode: NO (enabled: CD) 5:42:57 PM #24 Text 0 File DlgWaitCD.cpp, Line 2957 Recorder: _NEC DVD+-RW ND-6500A, Media type: DVD-R Disc Manufacturer ID: <RITEKF> <1> Disc Application Code: 64, Disc Physical Code: 193 5:42:57 PM #25 Text 0 File DlgWaitCD.cpp, Line 493 >>> Protocol of DlgWaitCD activities: <<< ========================================= Insert empty disc to write to. (Medium in drive: Unknown. Medium required by compilation: DVD R/RW, DVD+R DL.) 5:42:57 PM #26 Text 0 File ThreadedTransferInterface.cpp, Line 762 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 1878976 (1878976) = #1878976/417:33.1 relocatable, disc pos for caching/writing not required/ required -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1878976 blocks [D: _NEC DVD+-RW ND-6500A] -------------------------------------------------------------- 5:42:57 PM #27 Text 0 File ThreadedTransferInterface.cpp, Line 964 Prepare [D: _NEC DVD+-RW ND-6500A] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: Idx 0 Idx 1 Next Trk 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3848142848, ISRC "" DAO layout: =========== ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 1 | 0x41 | 1878976 | 0 | 0x00 1878976 | lead-out | 1 | 0x41 | 0 | 0 | 0x00 5:43:05 PM #28 Text 0 File SCSIPTICommands.cpp, Line 240 SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME 5:43:05 PM #29 Text 0 File Burncd.cpp, Line 4288 Caching options: cache CDRom or Network-Yes, small files-No (<64KB) 5:43:05 PM #30 Phase 24 File dlgbrnst.cpp, Line 1767 Caching of files started 5:43:05 PM #31 Text 0 File Burncd.cpp, Line 4407 Cache writing successful. 5:43:05 PM #32 Phase 25 File dlgbrnst.cpp, Line 1767 Caching of files completed 5:43:05 PM #33 Phase 36 File dlgbrnst.cpp, Line 1767 Burn process started at 8x (11,080 KB/s) 5:43:05 PM #34 Text 0 File ThreadedTransferInterface.cpp, Line 2681 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 5:43:05 PM #35 Text 0 File DVDR.cpp, Line 3273 Recording mode: Sequential Recording Mode 5:43:05 PM #36 Text 0 File DVDR.cpp, Line 3427 Start write address at LBA 0 DVD high compatibility mode: Yes 5:43:05 PM #37 Text 0 File Cdrdrv.cpp, Line 10140 ---- Disc Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33) Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) Outer Limit of Data Recordable Area: 26127F h Data in Burst Cutting Area (BCA) does not exist Revision number of maximum recording speed: 6.0 Revision number of minimum recording speed: - Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - - Class: 0, Extended part version: 33 Start PSN of the Extra Border Zone: 2FE10 h Start PSN of Physical format information blocks in Extra Border Zone: 2FFA0 h Media Specific [16..783]: 00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!.... 00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 01 40 C1 FD 9E D8 52 00 - 02 87 0D 13 87 88 90 00 [email protected]......... 03 52 49 54 45 4B 46 00 - 04 31 00 00 00 00 00 00 .RITEKF..1...... 05 88 80 00 00 00 02 00 - 06 09 0F 15 87 88 90 00 ................ 07 A8 82 00 20 00 00 00 - 08 06 16 10 14 0F 0B 00 ................ 09 94 07 0D 0B 88 88 00 - 0A 80 00 00 00 00 10 00 ................ 0B 09 1E 17 A7 89 85 00 - 0C B7 89 02 00 20 02 00 ................ 0D 00 00 D0 00 00 00 00 - 0E 0C 2B 39 33 29 1C 00 ..........+93).. 0F 50 1D 2B 0F 97 B5 00 - 10 88 80 00 00 00 00 00 .P.+............ 11 00 00 00 00 00 00 00 - 12 0C 32 45 41 2D 27 00 ..........2EA-'. 13 50 23 2F 0F 97 B5 00 - 14 88 80 00 00 00 00 00 .P#/............ 15 00 00 00 00 00 00 00 - 16 0A 4A 4F 4B 23 29 00 ..........JOK#). 17 80 1B 27 10 68 B5 00 - 18 88 88 00 08 00 08 00 ...'.h.......... 19 00 00 00 00 00 00 00 - 1A 08 59 55 52 2D 2B 00 ..........YUR-+. 1B 60 1F 29 0B A9 B5 00 - 1C 88 80 00 00 00 00 00 .`.)............ 1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 5:43:05 PM #38 SPTI -1046 File SCSIPassThrough.cpp, Line 197 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046) CDB Data: 0x53 00 00 00 00 00 1C AB C0 00 00 00 Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x30 Sense Qual: 0x05 Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 05 5:43:05 PM #39 Text 0 File DVDR.cpp, Line 3565 Reserved Track size: 1878976 (1CABC0h, 3669MB) -> return code -1046 5:43:05 PM #40 CDR -1046 File ThreadedTransferInterface.cpp, Line 1688 Illegal disc D: _NEC DVD+-RW ND-6500A 5:43:05 PM #41 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1688 Could not perform start of Disc-at-once 5:43:05 PM #42 Text 0 File ThreadedTransfer.cpp, Line 269 Pipe memory size 83836800 5:43:05 PM #43 Phase 38 File dlgbrnst.cpp, Line 1767 Burn process failed at 8x (11,080 KB/s) 5:43:05 PM #44 Text 0 File SCSIPTICommands.cpp, Line 287 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 5:43:09 PM #45 Text 0 File Cdrdrv.cpp, Line 11391 DriveLocker: UnLockVolume completed 5:43:09 PM #46 Text 0 File SCSIPTICommands.cpp, Line 450 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Existing drivers: Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) ----------- Noen som kan hjelpe? Lenke til kommentar
bluefire Skrevet 26. desember 2007 Del Skrevet 26. desember 2007 Nå har ikke jeg tatt meg tid til å feilsøke loggen. Men hvis det er divX videofiler, vil nok ikke alle versjoner av nero brenne den. Last ned et annet brenneprogram . For eksempel Burn4Free er et fint, gratis brenneprogram som brenner alt Lenke til kommentar
