Klarer ikke å mounte usb-disk i Sabayon
Beatnut
Hei.
Jeg klarer ikke å mounte min 250 Gb Freecom USb-disk (FAT32) i Sabayon 3.4f.
Med dmesg får jeg følgende meldinger:
[   71.642253] usb 1-6: configuration #1 chosen from 1 choice
[   71.642470] scsi2 : SCSI emulation for USB Mass Storage devices
[   71.642481] Device driver host2 lacks bus and class support for being resumed
[   71.642544] usb-storage: device found at 4
[   71.642546] usb-storage: waiting for device to settle before scanning
[   71.642594] Device driver usbdev1.4_ep01 lacks bus and class support for bein
g resumed.
[   71.642637] Device driver usbdev1.4_ep82 lacks bus and class support for bein
g resumed.
[   71.951565] usb 3-1: new low speed USB device using uhci_hcd and address 2
[   72.139756] Device driver usbdev3.2_ep00 lacks bus and class support for bein
g resumed.
[   72.139763] usb 3-1: configuration #1 chosen from 1 choice
[   72.186758] input: HID 04d9:0499 as /class/input/input6
[   72.186861] input: USB HID v1.10 Mouse [HID 04d9:0499] on usb-0000:00:1d.1-1
[   72.186906] Device driver usbdev3.2_ep81 lacks bus and class support for bein
g resumed.
[   72.466615] usb 1-1.1: new full speed USB device using ehci_hcd and address 5
[   72.562300] Device driver usbdev1.5_ep00 lacks bus and class support for bein
g resumed.
[   72.562307] usb 1-1.1: configuration #1 chosen from 1 choice
[   72.562536] Device driver usbdev1.5_ep81 lacks bus and class support for bein
g resumed.
[   72.562578] Device driver usbdev1.5_ep82 lacks bus and class support for bein
g resumed.
[   72.562619] Device driver usbdev1.5_ep02 lacks bus and class support for bein
g resumed.
[   72.562707] Device driver usbdev1.5_ep83 lacks bus and class support for bein
g resumed.
[   72.562747] Device driver usbdev1.5_ep03 lacks bus and class support for bein
g resumed.
[   72.562831] Device driver usbdev1.5_ep84 lacks bus and class support for bein
g resumed.
[   72.562873] Device driver usbdev1.5_ep04 lacks bus and class support for bein
g resumed.
[   72.740027] usb 1-1.2: new full speed USB device using ehci_hcd and address 6
[   72.825590] Device driver usbdev1.6_ep00 lacks bus and class support for bein
g resumed.
[   72.825597] usb 1-1.2: configuration #1 chosen from 1 choice
[   72.825842] Device driver usbdev1.6_ep81 lacks bus and class support for bein
g resumed.
[   72.825882] Device driver usbdev1.6_ep02 lacks bus and class support for bein
g resumed.
[   77.631021] usb-storage: device scan complete
[   77.631038] Device driver target2:0:0 lacks bus and class support for being r
esumed.
Har prøvd litt forskjellig som dere ser her:
kristian@localhost ~ $ su
Passord:
localhost kristian # mount -t /dev/sda3 /mnt/usbdisk
Usage: mount -V				 : print version
   mount -h				 : print this help
   mount					: list mounted filesystems
   mount -l				 : idem, including volume labels
So far the informational part. Next the mounting.
The command is `mount [-t fstype] something somewhere'.
Details found in /etc/fstab may be omitted.
   mount -a [-t|-O] ...	 : mount all stuff from /etc/fstab
   mount device			 : mount device at the known place
   mount directory		  : mount known device here
   mount -t type dev dir	: ordinary mount command
Note that one does not really mount a device, one mounts
a filesystem (of the given type) found on the device.
One can also mount an already visible directory tree elsewhere:
   mount --bind olddir newdir
or move a subtree:
   mount --move olddir newdir
A device can be given by name, say /dev/hda1 or /dev/cdrom,
or by label, using  -L label  or by uuid, using  -U uuid .
Other options: [-nfFrsvw] [-o options] [-p passwdfd].
For many more details, say  man 8 mount .
localhost kristian # mount /dev/sda3 /mnt/usbdisk
mount: mount point /mnt/usbdisk does not exist
mount: /dev/sda3 already mounted or /mnt/usbdisk busy
localhost kristian # mount /dev/usb4 /mnt/usbdisk
mount: /dev/usb4 is not a block device
localhost kristian # mount /dev/sdb /mnt/usbdisk
mount: /dev/sdb: can't read superblock
Som vist over stod det at mnt/usbdisk ikke fantes, men det fikset jeg altså på før jeg prøvde å mounte den en gang til.
Noen som har noen tips videre? Jeg sjekket i Portato om jeg kunne finne noe med usbdev i tilfelle driver manglet eller noe, men det ble ikke funnet noe. Hverken installert eller ikke.
Edit: Har først prøvd å finne noe på Sabayon sin egne wiki-sider uten hell.
Endret av Beatnut
