ThomasBergen Skrevet 19. desember 2007 Del Skrevet 19. desember 2007 (endret) Fikk kabinettet i dag 08.02.2008. Bestillte fra USA den 30 Januar. Ble sendt den 1 februar. Pris 2400. Dette er med moms og frakt. Lian Li (PC-P60-B, PC-P60B) Black Aluminum Mid Tower Computer PC Case Features: ARMORSUIT PC-P60 features modularized internal hardware design, system can be easy readjust to suit user's need. ARMORSUIT PC-P60 features nine 5.25 space rack, there are also one modularized HDD cage, which can hold three 3.5 HDD. User can adjust the position of the HDD cage to suit their need. Silent Performace: Lian Li using 3 x12cm fans in the front to intake cool air into the system. 12cm fan features high air flow to get the best balance between Silent and Cooling. One 12cm fan on the rear and one 14cm fan on the top to exhaust the hot air out of the chassis, it is also fitted with fan guard to protect end user. Top cover with EMI – anti-vibration spring. Lian Li designer looks into detail, ARMORSUIT PC-P60 equipped anti-vibration kit on the chassis, to absorb the noise. Like the EMI spring on the top cover, it absorb the vibration, and the side panel still easy to remove and close. Door with sound insulation. The rubber strip on the front door panel, it stop the door to knock the front panel, to avoid the door scratch the front panel, also close the gap of the door and front panel. Hard disk tray with anti-vibration kit. Lian Li patented anti-vibration HDD cage, with anti-vibration kit and special HDD mounting rack. User can easily install the HDD into the cage. And the rubber rings on the HDD, absorb the vibration to stop the noise. High quality anti-vibration feet. Creative Thermal Solutions: Lian Li using 3 x12cm fans in the front to intake cool air into the system. 12cm fan features high air flow to get the best balance between Silent and Cooling. When there are intake for cool air, there is a need for air filter to catch the dust in the air, to keep the internal clean. Front mount linear fan speed controller for adjust fan speed from 800-1200RPM. User can choose the fan speed to get the best cooling or silent performance. The air filter is design to be easy to clean, and washable. And it is easy to remove, just pull it out of the front panel door, no tool required. Design for enthusiasts, PC-P60 equips two water pipe inlets. The Top cover can be open up and remove for easy hardware service and installation ARMORSUIT PC-P60 features removable motherboard tray, user can install the motherboard on a table top, easy for future upgrade and service. Power / reset button and multi-media I/O ports location on the top-front for easy access. The I/O ports has four USB ports, one ports, HD+ AC 97 Audio and e-SATA ports. No metter of where you want to place your chassis. ARMORSUIT PC-P60's front panel can switch the open direction, allow chassis to fit in different working environment. The door can be easy to be release, simply just push the release key for the door axis. ( there is a safety screw to secure the axis for transportation). Lian Li designer come out an unique door stop design, by using steel ball as door stop, to stop the door in the right position. And sounds like closing the door on a high end automotive. The chassis and front panel all fitted with locks to protect hardware Multi-media ports' connectors followed international specification standard, with one connector for easy installation Audio supports HD Audio and AC97 Audio design for batter compatibility Lian Li (PC-P60-B, PC-P60B) Black Aluminum Mid Tower Computer PC Case Model PC-P60 Case Type Super Mid Tower Dimensions 210 x 545 x 540 mm(W, H, D) Front bezel Material Aluminum Color Black Side Panel Hair-line brushed aluminum finishing Body Material Aluminum Net Weight 8kg/ 9.4kg (N.W/ G.W) 5.25 drive bay (External) 9 3.5 drive bay (External) 0 3.5 drive bay (Internal) 3 ( using 6 x 5.25) Expansion Slot 7 Motherboard E-ATX, ATX, M-ATX System Fan (Front) 3 x 12cm LED Fan @800-1200 RPM System Fan (Top) 1 x 14cm LED Fan @800-1200 RPM System Fan (Rear) 1 x 12cm Fan @1500RPM I/O Ports USB 2.0 x 4; IEEE1394 x 1; E-SATA x 1; HD+AC97 Audio Endret 8. februar 2008 av ThomasBergen Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/
tfoyen Skrevet 19. desember 2007 Del Skrevet 19. desember 2007 Dei som har lian li i norge er vel bare microplex.no og netshop.no Så vist det er viktigt for deg å få tak i det så kan du spør dei om dei kan kjøpe det inn for deg Og foresten, det var eit sjukt nice kabinettet Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10152937
Krom-stag Skrevet 19. desember 2007 Del Skrevet 19. desember 2007 Hvor får man tak i det? Dette skal jeg ha!! Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10152949
ThomasBergen Skrevet 19. desember 2007 Forfatter Del Skrevet 19. desember 2007 Takk, ja synd det var digg eg og. Kom tifeldigvis over det, mens eg surfa litt Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10152979
brukerenerslettet Skrevet 19. desember 2007 Del Skrevet 19. desember 2007 du kan få det hos google Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10152996
ThomasBergen Skrevet 19. desember 2007 Forfatter Del Skrevet 19. desember 2007 Noen som kan tenke seg en pris for et sånnt kabinett? 1500-2000k? Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10153016
gigax Skrevet 19. desember 2007 Del Skrevet 19. desember 2007 Kanskje noen kan sende mail til netshop og spørre pent om de tar inn noen? Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10153071
Krom-stag Skrevet 19. desember 2007 Del Skrevet 19. desember 2007 Kanskje noen kan sende mail til netshop og spørre pent om de tar inn noen? God ide . Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10153076
ThomasBergen Skrevet 19. desember 2007 Forfatter Del Skrevet 19. desember 2007 Da har eg sent mail til Netshop. håper på svar i morgen. Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10153128
gigax Skrevet 19. desember 2007 Del Skrevet 19. desember 2007 Det gjorde jeg også xD vell vell, har vel ikke så mye å si. Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10153134
564215 Skrevet 19. desember 2007 Del Skrevet 19. desember 2007 nice kabinett Var ikke for mye blingbling, men samtidig ikke helt tamt. Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10154755
Dusken Skrevet 20. desember 2007 Del Skrevet 20. desember 2007 Likte kabinettet svært godt, men det blir for mye lys for meg. God plass og hull til slanger. Noen som har større bilder? Vil se detaljene. Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10155890
DarkZhade Skrevet 20. desember 2007 Del Skrevet 20. desember 2007 ser ut som en bedre versjon av antec sitt nine hundred >< Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10155918
mungo Skrevet 20. desember 2007 Del Skrevet 20. desember 2007 Ser ut som om det støyer en del med tre vifter på 1200rpm og ei vifte på 1500rpm. Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10156114
gigax Skrevet 20. desember 2007 Del Skrevet 20. desember 2007 "From: [email protected] ([email protected]) Hei, Vi får nok kabinettet inn så fort det lar seg gjøre. Det samme gjelder de andre delene. Bare å følge med på webshopen over nyåret. Mvh Asbjørn Netshop support" Det er på tur inn, med andre ord "De andre delene" = noe greier jeg spurte om. Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10157689
ThomasBergen Skrevet 20. desember 2007 Forfatter Del Skrevet 20. desember 2007 Mail fra Netshop. "Heisann Thomas Jeg skal vidresende denne mailen til Microplex, da det er di som tar Lian Li inn til Norge Ha en fortsatt fin dag, og en riktig god jul. " Får vel vente til etter jul og se. Hadde tenkt å kjøpe pc etter nyttår, men vet ikke lenger, med tanke på utsettelsen av Intel 45Nm CPU Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10158332
ThomasBergen Skrevet 20. januar 2008 Forfatter Del Skrevet 20. januar 2008 Noen andre som lurer på å kjøpe dette kabinettet? Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10390940
Krom-stag Skrevet 20. januar 2008 Del Skrevet 20. januar 2008 Vis det er å få kjøpt i Norge, så ja, vist faen! Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10391060
ThomasBergen Skrevet 25. januar 2008 Forfatter Del Skrevet 25. januar 2008 (endret) Fant denne på nettet. Dette er P80 utgaven, men p60 er nesten lik, bare mindre. Video Review Endret 30. januar 2008 av ThomasBergen Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10428896
jonas_blomster Skrevet 31. januar 2008 Del Skrevet 31. januar 2008 Sinsykt stilig kabinett det der Er vel mulighet for å bruke lian li sine radiator fester i denne? De som egentlig er ment til Cube. Burde ikke være vanskelige å få det kjølig i denne ihvertfall. Men liker ikke at det kommer kabinetter som denne, har egentlig bestemt meg for å IKKE begynne med en ny mod, men når ting som dette kommer frister det litt for mye! hehe Lenke til kommentar https://www.diskusjon.no/topic/881472-lian-li-armorsuit-pc-p60-gaming-kabinett/#findComment-10466504
