Hjelp til små endringer i et galleriscript
I spoileren nedenfor så finner man koden jeg bruker for å vise galleriethjemmesiden min.
Det er to ting som plager meg:
  1. Foran tittelen på hvert enkelt galleri når man går inn på galleriet så står det :/"mappenavn", dette vil jeg gjerne ha vekk (For et eksempel: http://vindstille.net/galleri?dir=/Cuba+06)
  2. Når man holder over en thumbnail så ser man at adressen til bilde er http://vindstille.net/galleri?dir=%2FCuba+...p;q=node%2F1119, men når jeg trykker på hvert enkelt bilde så ser jeg at den siste delen (&q=node%2F1119) ikke er nødvendig, hvordan fjerner jeg den i koden?
Det hadde vært fint om jeg kunne fått litt hjelp til dette, jeg har dessverre ikke skjønt hvordan jeg skal ordne opp i dette selv.
<?php
* galerie.php - a simple gallery script
* Copyright (C) 2004  Daniel Wacker <[email protected]>
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
* This script provides a simple gallery of all images that are located
* in the script's directory and subdirectories.
* Requirements
* - PHP >= 4.1.0
* - GD Library ( >= 2.0.1 for good thumbnails)
* - JPEG software
* - PHP >= 4.3.0 or GD < 1.6 for GIF support
* - libpng for PNG support
* Installation
* Simply put this script in a folder of your web server and call it in a
* web browser. Be sure that the script has permission to read the image
* files and to create and write into the thumbnail folder.
* Attention:
* This script tries to generate jpeg thumbnail files in a subfolder of the
* gallery folder(s). The filenames look like "originalfilename.thumb.jpg".
/* Select your charset
$charset = 'ISO-8859-1';
/* How many images per page?
$maxpics = 15;
/* Create thumbnails in this subfolder
$thumbdir = 'thumbs';
/* Size of created thumbnails
$thumbsize = 150;
/* Wether to show file names (true or false)
$filenames = false;
/* Wether to show subdirectores (true or false)
$subdirs = true;
/* Wether to show a title (true or false)
$title = true;
/* Set the gallery root relative to the script's directory.
* If you include() this script, set the path relative to
* the directory of the script, that does the include().
$picdir = 'files/bilder/';
/* Set this to true if you include() this script.
$included = true;
/* Set this to true, if you include() this script and want the images
* to be shown inline.
$inline = true;
/* Set the thumbnail background color, if you include() this script.
$bg = 'FFFFFF';
$words = array(
'gallery' => 'gallery',
'error' => 'Error',
'php_error' => 'PHP >= 4.1 is required.',
'gd_error' => 'GD Library is required. See http://www.boutell.com/gd/.',
'jpg_error' => 'JPEG software is required. See ftp://ftp.uu.net/graphics/jpeg/.',
'mkdir_error' => 'Write permission is required in this folder.',
'opendir_error' => 'The directory "%1" can not be read.'
isset($_SERVER) || ($error = error('php'));
function_exists('imagecreate') || ($error = error('gd'));
function_exists('imagejpeg') || ($error = error('jpg'));
if (function_exists('ini_set')) @ini_set('memory_limit', -1);
$jpg = '\.jpg$|\.jpeg$'; $gif = '\.gif$'; $png = '\.png$';
$fontsize = 2;
function word ($word) {
global $words;
return html($words[$word]);
function html ($word) {
global $charset;
return htmlentities($word, ENT_COMPAT, $charset);
function error ($word, $arg = '') {
global $words;
return html(str_replace('%1', $arg, $words[$word .'_error']));
if (!$included) {
echo('<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
 "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="content-type" content="text/html; charset=' . $charset . '" />
<style type="text/css">
body { font-family: sans-serif }
hr { border-style: none; height: 1px; background-color: silver; color: silver }
p { margin: 0px; padding: 0px }
#pagenumbers { text-align: center; margin: 0px 1em 0px 1em }
img { margin: 10px; border: none }
a { text-decoration: none }
if ($filenames) {
 echo('div a p { font-size: small }
a:hover p { text-decoration: underline }
div { width: ' . ($thumbsize + 20) . 'px; text-align: center; float: left; margin: 1em }
echo("</style>\n");
$delim = DIRECTORY_SEPARATOR;
if (array_key_exists('dir', $_REQUEST) && $subdirs) $dir = $_REQUEST['dir'];
else $dir = '';
if (!empty($_SERVER['PATH_TRANSLATED'])) $d = dirname($_SERVER['PATH_TRANSLATED']);
elseif (!empty($_SERVER['SCRIPT_FILENAME'])) $d = dirname($_SERVER['SCRIPT_FILENAME']);
else $d = getcwd();
$delim = (substr($d, 1, 1) == ':') ? '\\' : '/';
$rp = function_exists('realpath');
if ($rp) $root = realpath($d . $delim . $picdir);
else $root = $d . $delim . $picdir;
if ($rp) $realdir = realpath($root . $dir);
else $realdir = $root . $dir;
if (substr($realdir, 0, strlen($root)) != $root) { $realdir = $root; $dir = ''; }
$dirname = substr($realdir, strlen($root));
$dirnamehttp = $picdir . $dir;
if ($delim == '\\') $dirnamehttp = strtr($dirnamehttp, '\\', '/');
if (substr($dirnamehttp, 0, 2) == './') $dirnamehttp = substr($dirnamehttp, 2);
if (empty($dirnamehttp)) $dirnamehttp = '.';
$ti = ($subdirs && !empty($dirname)) ? ": $dirname" : '';
if (!$included) {
if (isset($error)) echo("<title>$error</title>");
else echo('<title>' . word('gallery') . html($ti) . "</title>\n");
echo("</head>\n<body>\n");
if (($d = @opendir($realdir)) === false) $error = error('opendir', array($realdir));
if (isset($error)) echo("<p style=\"color: red\">$error</p>\n"); else {
if ($title) echo('<h1>' . word('gallery') . html($ti) . "</h1>\n<hr />\n");
$dirs = $pics = array();
$query = $jpg;
if (function_exists('imagecreatefromgif')) $query .= "|$gif";
if (function_exists('imagecreatefrompng')) $query .= "|$png";
while (($filename = readdir($d)) !== false) {
 if ($filename == $thumbdir
  || ($filename == '..' && $dirname == '')
  || ($filename != '..' && substr($filename, 0, 1) == '.')) continue;
 $file = $realdir . $delim . $filename;
 if (is_dir($file)) $dirs[] = $filename;
 elseif (eregi($query, $file)) $pics[] = $filename;
closedir($d);
sort($dirs);
sort($pics);
$urlsuffix = '';
foreach ($_GET as $v => $r) {
 if (!in_array($v, array('dir', 'pic', 'offset'))) $urlsuffix .= "&$v=" . urlencode($r);
if ($included && $inline && array_key_exists('pic', $_REQUEST)) {
 $pic = $_REQUEST['pic'];
 echo("<div id=\"picture\">\n");
 echo('<img src="' . html("$dirnamehttp/{$pics[$pic]}") . '" alt="' . html(basename($pics[$pic])) . '"');
 list($width, $height, $type, $attr) = @getimagesize($pic);
 if (!empty($width)) echo(" style=\"width: {$width}px; height: {$height}px\"");
 echo(" />\n");
 $url = ($dirname  == '') ? '?' : '?dir=' . urlencode($dirname) . '&';
 echo("<hr />\n");
 if ($pic > 0)
 echo('<a href="' . html($url) . 'pic=' . ($pic - 1) . html($urlsuffix) . '">[<]</a> ');
 if ($pic >= $maxpics)
 $u = "{$url}offset=" . (floor($pic / $maxpics) * $maxpics) . $urlsuffix;
 else {
  if (array_key_exists('dir', $_REQUEST)) {
$u = substr($url, 0, strlen($url) - 1) . $urlsuffix;
  } else {
$u = ereg_replace('^([^?]+).*$', '\1', $_SERVER['REQUEST_URI']);
if (!empty($urlsuffix)) {
 if (strstr($u, '?') === false) $u .= '?' . substr($urlsuffix, 1);
 else $u .= $urlsuffix;
 echo('<a href="' . html($u) . '">[-]</a>');
 if ($pic + 1 < sizeof($pics))
 echo(' <a href="' . html($url) . 'pic=' . ($pic + 1) . html($urlsuffix) . '">[>]</a>');
 echo("\n</div>\n");
} else {
 if (sizeof($dirs) > 0 && $subdirs) {
  echo("<ul id=\"directories\">\n");
  foreach ($dirs as $filename) {
if ($rp) $target = substr(realpath($realdir . $delim . $filename), strlen($root));
else $target = substr($realdir . $delim . $filename, strlen($root));
if ($delim == '\\') $target = strtr($target, '\\', '/');
if ($target == '') {
 $url = ereg_replace('^([^?]+).*$', '\1', $_SERVER['REQUEST_URI']);
  if (strstr($url, '?') === false) $url .= '?' . substr($urlsuffix, 1);
  else $url .= $urlsuffix;
} else $url = '?dir=' . urlencode($target) . $urlsuffix;
echo('<li><a href="' . html($url) . '">' . html($filename) . "</a></li>\n");
  echo("</ul>\n<hr />\n");
 if (($num = sizeof($pics)) > 0) {
  if (array_key_exists('offset', $_REQUEST)) $offset = $_REQUEST['offset'];
  else $offset = 0;
  if ($num > $maxpics) {
echo("<p id=\"pagenumbers\">\n");
for ($i = 0; $i < $num; $i += $maxpics) {
 $e = $i + $maxpics - 1;
 if ($e > $num - 1) $e = $num - 1;
 if ($i != $e) $b = ($i + 1) . '-' . ($e + 1);
 else $b = $i + 1;
 if ($i == $offset) echo("<b>$b</b>");
 else {
  echo("<a href=\"{$url}offset=$i" . html($urlsuffix) . "\">$b</a>");
 if ($e != $num - 1) echo(' |');
 echo("\n");
echo("</p>\n<hr />\n");
  echo("<p id=\"pictures\">\n");
  for ($i = $offset; $i < $offset + $maxpics; $i++) {
if ($i >= $num) break;
$filename = $pics[$i];
if (!is_readable($file)) continue;
if (!is_dir($realdir . $delim . $thumbdir)) {
 $u = umask(0);
 if (!@mkdir($realdir . $delim . $thumbdir, 0777)) {
  echo('<p style="color: red; text-align: center">' . word('mkdir_error') . '</span>');
  break;
 umask($u);
$thumb = $realdir . $delim . $thumbdir . $delim . $filename . '.thumb.jpg';
if (!is_file($thumb)) {
 if (eregi($jpg, $file))
 $original = @imagecreatefromjpeg($file);
 elseif (eregi($gif, $file))
 $original = @imagecreatefromgif($file);
 elseif (eregi($png, $file))
 $original = @imagecreatefrompng($file);
 else continue;
 if ($original) {
  if (function_exists('getimagesize'))
  list($width, $height, $type, $attr) = getimagesize($file);
  else continue;
  if ($width >= $height && $width > $thumbsize) {
   $smallwidth = $thumbsize;
   $smallheight = floor($height / ($width / $smallwidth));
   $ofx = 0; $ofy = floor(($thumbsize - $smallheight) / 2);
  } elseif ($width <= $height && $height > $thumbsize) {
   $smallheight = $thumbsize;
   $smallwidth = floor($width / ($height / $smallheight));
   $ofx = floor(($thumbsize - $smallwidth) / 2); $ofy = 0;
  } else {
   $smallheight = $height;
   $smallwidth = $width;
 if (function_exists('imagecreatetruecolor'))
$small = imagecreatetruecolor($thumbsize, $thumbsize);
 else $small = imagecreate($thumbsize, $thumbsize);
 sscanf($bg, "%2x%2x%2x", $red, $green, $blue);
 $b = imagecolorallocate($small, $red, $green, $blue);
 imagefill($small, 0, 0, $b);
 if ($original) {
  if (function_exists('imagecopyresampled'))
imagecopyresampled($small, $original, $ofx, $ofy, 0, 0, $smallwidth, $smallheight, $width, $height);
  else
imagecopyresized($small, $original, $ofx, $ofy, 0, 0, $smallwidth, $smallheight, $width, $height);
 } else {
  $black = imagecolorallocate($small, 0, 0, 0);
  $fw = imagefontwidth($fontsize);
  $fh = imagefontheight($fontsize);
  $htw = ($fw * strlen($filename)) / 2;
  $hts = $thumbsize / 2;
  imagestring($small, $fontsize, $hts - $htw, $hts - ($fh / 2), $filename, $black);
imagerectangle($small, $hts - $htw - $fw - 1, $hts - $fh, $hts + $htw + $fw - 1, $hts + $fh, $black);
 imagejpeg($small, $thumb);
if ($filenames) echo('<div>');
if ($included && $inline) {
echo('<a href="?');
if (array_key_exists('dir', $_REQUEST)) echo('dir=' . urlencode($_REQUEST['dir']) . '&');
echo('pic=' . $i . html($urlsuffix));
} else echo('<a href="' . html("$dirnamehttp/$filename"));
echo('"><img src="' . html("$dirnamehttp/$thumbdir/$filename.thumb.jpg"));
echo('" alt="' . html($filename) . '" style="');
echo("width: {$thumbsize}px; height: {$thumbsize}px\" />");
if ($filenames) echo('<p>' . html($filename) . '</p>');
echo('</a>');
if ($filenames) echo("</div>\n"); else echo("\n");
  echo("</p>\n");
if (!$included) echo("</body>\n</html>");
Denne posten hører hjemme i PHP forumet
Bortsett fra det med q=node så er dette svarert;
Fjern innholdet av alt=""
F.eks til kun word('gallery') ??
Word som det her siktes til ser ut til å være en funksjon, bør det ikke heller være i funksjonen endringen bør gjøres? siden det jeg vil fjerne er ":/" før navnet på galleriet?
Word() retunerer bare en kode fri for html..
Så hva er dette? og hvordan fjerner jeg eventuelt ":/" ut av denne
global $words;
global $charset;
global $words;
global $words;
global $charset;
global $words;
Det spørs helt hva word() blir matet med..
