Hvilken kjendis vil du bli strandet med på en øde øy?
Melisma
Fiktive personer? Hva er det du prøver å si, finnes ikke Jessica Biel????
Joda, men hvorfor i det hele tatt vurdere henne når Scarlett Johansson er minst like virkelig?
HALLO!!! Du har jo Lauren Graham i avartaren din...
Hva skal man med Scarlett når man kan brøle "whos your santa" fra toppen av en palme midtveis i akten ?
Av en eller annen grunn tenker alle på en varm sydhavsøy når noen sier øde øy. Kunne like godt hvert en slik øy man hadde havnet på:
Jeg ville valgt Lilith :list_item:
Kabbalistisk grunnlag:
Yet another version claims that Lilith was not created by God, but emerged as a divine entity that was born spontaneously, either out of the Great Supernal Abyss or...
An alternative story links Lilith with the creation of luminaries. The "first light", which is the light of Mercy (one of the Sefirot), appeared on the first day of creation when God said "Let there be light" This light became hidden and the Holiness became surrounded by a husk of evil.” A husk (q'lippa) was created around the brain" and this husk spread and brought out another husk, which was Lilith.
Lilith is listed as one of the Qliphoth, corresponding to the Sephirah Malkuth in the Kabbalistic Tree of Life. The demon Lilith, the evil woman, is described as a beautiful woman, who transforms into a black, monkey-like demon, and it is associated with the power of seduction.
The Qliphah is the unbalanced power of a Sephirah. Malkuth is the lowest Sephirah, the realm of the earth, into which all the divine energy flows, and in which the divine plan is worked out. However, its unbalanced form as Lilith, the seductress, is obvious. The material world, and all of its pleasures, is the ultimate seductress, and can lead to materialism unbalanced by the spirituality of the higher spheres. This ultimately leads to a descent into animal consciousness. The balance must therefore be found between Malkuth and Kether, to find order and harmony, without giving into Lilith, materialism, or Thaumiel, Satan, spiritual pride and egotism
:whistle:
Edit: .. og nei hun er ikke fiktiv for min del.
Endret av Ba'al-Sebul
