tjumsen Skrevet 14. desember 2007 Del Skrevet 14. desember 2007 jeg holder på med et spill i java script . og jeg lurte på korleis får jeg Session i javascriptet . her er koden til highscore scriptet mitt men jeg har ikke denne filen getsession.html noen som kan hjelpe meg med den?? <div id="theGame_score"> <div id="theGame_scoreInner"> <form method="post" action="mine_10.htm"> <table border="0"> <tr> <td colspan="2"><h3>Congratulations, you have reached the highscore list</h3></td> </tr> <tr> <td nowrap><p><label for="user_name">Your name:</td> <td><p><input type="text" name="user_name" style="width:280px"></td> </tr> <tr> <td colspan="2"><input type="submit" name="submitScore" value="Submit your score"></td> </tr> </table> <input type="hidden" name="session_ID" value=""> <input type="hidden" name="seconds" value=""> </form> <iframe src="getSession.html" name="getSession" id="getSession" frameborder="0" width="1" height="1"></iframe> </div> </div> <div id="theGame_scoreList"> <div id="theGame_scoreInner"> <h3>Highscore list</h3> <table border="0" cellpadding="1" cellspacing="1"> <tr> <th></th> <th>Name</th> <th class="right_aligned">Seconds</th> </tr> <tr id="session id"><td width="20"><p class="right_aligned">1</td><td><p>Edward </td><td><p class="right_aligned">11 </td></tr> <tr id="session id"><td width="20"><p class="right_aligned">2</td><td><p>Edward, Quite bored. </td><td><p class="right_aligned">12 </td></tr> </table> <table border="0" cellpadding="1" cellspacing="1"> <tr> <th></th> <th>Name</th> <th class="right_aligned">Seconds</th> </tr> <tr id="session id"><td width="20"><p class="right_aligned">11</td><td><p>malin </td><td><p class="right_aligned">77 </td></tr> <tr id="session id"><td width="20"><p class="right_aligned">12</td><td><p>Dan </td><td><p class="right_aligned">78 </td></tr> </table> </div> </div> Lenke til kommentar
Drømmemannen Skrevet 14. desember 2007 Del Skrevet 14. desember 2007 (endret) HTTP session er det serveren som styrer, så hvis du skal ha informasjon inn eller ut av session må javascriptet sende en request til egnet funksjonalitet på serveren (dvs ikke en statisk side). Session er brukerspesifik, og brukere har ikke tilgang til hverandres session, så hvis highscoren gjelder på tvers av brukere er det ikke session du er interessert i, men felles funksjonalitet som f.eks. lagrer verdier i en database. Endret 14. desember 2007 av Drømmemannen Lenke til kommentar
tjumsen Skrevet 21. desember 2007 Forfatter Del Skrevet 21. desember 2007 HTTP session er det serveren som styrer, så hvis du skal ha informasjon inn eller ut av session må javascriptet sende en request til egnet funksjonalitet på serveren (dvs ikke en statisk side). Session er brukerspesifik, og brukere har ikke tilgang til hverandres session, så hvis highscoren gjelder på tvers av brukere er det ikke session du er interessert i, men felles funksjonalitet som f.eks. lagrer verdier i en database. dette skal være en slik at dei kan legge inn navn og scoren sin på en liste .. kan du hjelpe meg å lagen en sann da ? Lenke til kommentar
LostOblivion Skrevet 27. desember 2007 Del Skrevet 27. desember 2007 Lære seg PHP? Mye lettere å få til. Lenke til kommentar
