s1gnal Skrevet 13. april 2008 Rapporter Del Skrevet 13. april 2008 Jeg gikk fra 120 til 40 ping til Blizzard WoW serverene med noen enkle registry endringer. Aner ikke om det vil hjelpe for dere i spillet, men kanskje vært et forsøk. Her er det jeg gjorde: Windows XP, Switch off Nagle's Algorithm by default: http://technet2.microsoft.com/windowsserve...3.mspx?mfr=true Type "regedit" in windows "run.." dialog to bring up registry menu Then find: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSMQ\Parameters Right-click in the right hand pane and add a new DWORD value, name it TCPNoDelay, then right click the entry and click Modify and assign a value of 1. Click Ok and close the registry editor, then reboot your PC. Please note, this disables Nagle for ALL connections, not just WoW. This is bad for bulk data transfer, which means that download speeds probably will suffer and you should remove this registry key after playing. The hack should only be done on the WoW connection, not globally on your system, which is why I report this here. ---- Windows XP and Windows Vista: 1 - TcpAckFrequency - NOTE if you are running Windows Vista this setting may not have any effect - a hotfix is needed which i'm tracking down. This works fine under Windows XP Type "regedit" in windows "run.." dialog to bring up registry menu Then find: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\ There will be multiple NIC interfaces listed in there, find the one you use to connect to the internet, there will be several interfaces listed (they have long names like {7DBA6DCA-FFE8-4002-A28F-4D2B57AE8383}. Click each one, the right one will have lots of settings in it and you will see your machines IP address listed there somewhere. Right-click in the right hand pane and add a new DWORD value, name it TcpAckFrequency, then right click the entry and click Modify and assign a value of 1. You can change it back to 2 (default) at a later stage if it affects your other TCP application performance. it tells windows how many TCP packets to wait before sending ACK. if the value is 1, windows will send ACK every time it receives a TCP package. Håper det funker som en midlertidig løsning! Lenke til kommentar
Glenn Skrevet 1. mai 2008 Forfatter Rapporter Del Skrevet 1. mai 2008 Takker for tipset, men dette hjelper nok ikke i dette tilfellet, da dette ikke er noe med programvaren, men heller nettverksrelatert. Noen som har noen nyheter fra Tele2? Er de fortsatt like vanskelige? Lenke til kommentar
2cLoseUp Skrevet 14. juni 2008 Rapporter Del Skrevet 14. juni 2008 Har snakket med Tele2 som sier at de ikke kan gjøre noe med problemet. Derfor skiftet jeg til Telenor Turbo 16000/600. Tipper Tele2 kommer til å miste mange kunder pga dette. Lenke til kommentar
reybr Skrevet 16. juni 2008 Rapporter Del Skrevet 16. juni 2008 Som Glenn skrev i den andre tråden angående dette problemet, har Tele2 nå mulighet til å endre på dette. Prøv kundesenteret til Tele2 en gang til, så har du ihvertfall lavere ping til du bytter til Telenor Lenke til kommentar
