Må jeg ha X38 kort for det nye 8800GTS 512mb?
Sjefen2
Hei,
Jeg lurte på å kjøpe meg ett nytt hovedkort sammen med det nye 8800GTS kortet som kom ut nå.
Ser blant annet Komplett har dette fra XFX. Jeg lurte i utgangspunktet på å kjøpe et ABIT IP35 PRO kort,
men får jeg da utnyttet dette nye 8800 GTS kortet?
Kanskje er dette svaret til det du lurer på ....
Ref Fudzilla: http://www.fudzilla.com/index.php?option=c...80&Itemid=1
New Forceware 169.21 is out
Written by Fuad Abazovic
Wednesday, 12 December 2007 10:12
Supports G92 GTS and improve performance in Crysis
Nvidia has a new driver out, it supports the 8800GTS 512 GPU and it is the new recommended driver for the last DirectX 9, 10 and OpenGL.
It is out for XP 32 and 64 bit, Vista 64 and 32 and it is the new driver recommended for Crysis. A few people on some forums have tested it in Crysis and they were disappointed to learn that there were no significant framerate improvements.
It also includes numerous game and application compatibility fixes and you better get it, but beware it is not WHQL certified.
You can get it here.
