Den nye Forumkaféen
Tja. Er du personlig overbevist kristen? Hvis ikke, forklar hvorfor du feirer jul. Eller enda bedre, om du er det må du og gjøre det.
Åh åh åh. Nå har du satt igang ateistmaskinene. Nå kommer de snart trampende en etter en og beskylder deg for å være en tulling som tror jula har noe med kristendom og du blir lasset på med blablabla jol og blabla feiring og blabla religion suger.
a julebrus a day. keeps the doctor away :)
A julebrus a day keeps the stomach at bay ;) .
Researchers have discovered a new way to make a type of synthetic diamond - from tequila.
Researchers at the University of Nueva Leon near Monterrey in Mexico found that when the Mexican spirit is heated under pressure, it produces diamond structures, which are able to conduct electricity. The crystals, used to make diamond film, have previously been made from a number of different chemicals, often including nitrogen.
However, the experiment is believed to be the first time that researchers have proved that any type of alcohol can be used to produce synthetic diamond.
Diamond film is tougher than silicon, so it could be useful for devices that must operate at high temperatures or under other harsh conditions.
However, diamond films are expensive and difficult to make. Now, researchers from Mexico have shown that the crystals can be created by heating the country’s national drink.
For the experiment, the researchers heated 80% proof ‘tequila blanco’, which has a short aging process and is bottled soon after distillation, in a low-pressure chamber. The drink formed into crystals which tests later confirmed had a diamond structure and were able to conduct electricity.
http://www.impactlab.com/2008/06/19/scient...s-from-tequila/
GIEF1!!!!
Personlig er jeg ateist selv. Og jeg vet både julas opphav, den kristne julas opphav, og sist men ikke minst, den julen vi feirer nå er jeg en av alt for få som har godtatt og tatt inn over meg.
For sent, gitt.
Men du nevnte kristendom og jul i samme setning, du må på korset kvinne!
For sent, gitt.
Antyder du til meg?
Ah, godt å sove fra halv tre til halv elleve.
Maks vrak i ryggen etter i dag, men det var verdt det.
Er faen så digg å filme, jeg elsker det :D
Drømmer om å starte eget selskap med noen av folka fra skolen når vi har fått tatt bachelorene våre.
Og endelig har filmene mine kommet :D
Alle unntatt den første, skal jeg klage til Play eller Posten?
edit:
Programvare, ditto.
Og nytter ikke å komme med ideer om å gjøre noe nytt, som å reise bort eller noe sånt, det blånekter jeg og minstesøss på.
Jula skal feires hjemme på Orkanger og vi skal spise det samme vi alltid har spist, gjøre det vi alltid har gjort og jeg skal være nisse.
Alt annet blir feil.
Endret av Datasmurf
*Tvilhode på fredagen*
Vil ikke at det blir lørdag...lørdag etterfulges nemlig av søndag, som etterfulges av MANDAG! :(
Herregud, har den tankegangen selv. Må lære meg å leve i nuet.
Kjøpte en julenissesjokolade i butikken i dag, og spiller "nå er det jul igjen" jevnlig. Kapitalistjula er i gang!
Endret av Quicko
Når en helligdag aksepteres av en regjering så er det en sekulær dag, og må feires uavhengig av religion. Jeg vil ikke gi gaver, men jeg må. =D
Jeg kjenner en del folk som er i Jehovas Vitne (vet ikke hva som er forskjellen på det og andre kristne)... de feirer ikke jul i det hele tatt
Endret av The_Unforgiven
Gjest
