Den nye Forumkaféen
Gjest Slettet+5132
Du hadde likt det, jeg lover! Hadde selvfølgelig inkludert hodebunnsmassasje, håndmassasje og gode kremer!
Det bør inkludere mer enn kremer og sånt dill, ellers gidder jeg ikke.
Jeg ble tydeligvis inspirert av å lese her rett før jeg la meg, hadde en interresant drøm som innebar dusjing. Men du var (desverre? ) ikke med. :p Typisk å bli vekt når man har de beste drømmene. :(
Kom over en morsom forklaring på dette med drømmer, usikker på hvor faktabasert den er:
Ooh ooh! I know this one!
Or rather, I've had a pretty plausible explanation laid out to me by a neurologist back when I was in med school. Basically, the reasoning was that THE ENTIRE NARRATIVE OF THE DREAM IS CREATED IN THE FEW SECONDS WHILE YOU'RE WAKING UP.
The stimulus for this theory came from a researcher who was awoken from a dream. In the dream, he was a government fugitive, in France, during a Les-Mis style french revolutionary dream setting. He was captured, tossed in jail, had those horrible dream attempts-at-escape where he couldn't move fast enough, and was taken to the guillotine. Just as the guillotine hit his neck, he woke up...
... to find that a book from the shelf over his bed had fallen off and struck him in the neck.
So. Either he lived through the craziest coincidental neck strike ever, or his dream self is psychic and spent 20 minutes leading up to the book drop building a coherent narrative...
...OR, your brain, while asleep, is firing off random signals and scenes. Running through the events of the day, etc. Not building any sort of dream narrative, because you're unconscious and don't need one.
But when you wake up, brain needs to kick in to gear. This includes the part of your brain responsible for assembling your recent memories. So it just takes whatever's flying around in your memory processing unit and cobbles together a storyline right as you wake up. That's why it's often such a surreal memory.
This happens to us even when we're awake. Our brains are not a tape recorder, our memories are not a perfect copy of what just happened. They're our brains best effort at sorting out reality.
That's why chronic alcoholics with Korsakoff syndrome start "confabulating." Their memory processing areas are so fucked from booze that they can't really lay down proper memories anymore. But when someone asks them "why are you holding an oven mitt" they make up a story that they actually believe, because they can't remember picking it up while searching for a vodka bottle. Confabulation is different from lying, because they really BELIEVE the story their brain made up. Just like dreaming.
Gjest Slettet+5132
Jeg visste du drømte sånn. Det var derfor jeg sendte deg melding.
Det var ikke du som vekte meg da :p
L4r5 steller hjemme aleine en hel helg
Dag 1:
Udyret returnerte ikke til vanlig tid. Det ryktes at det kommer til å være vekk helt til søndag.
Jeg spiste popcorn til frokost. Dosetet har stått oppe helt siden i morges. Tåneglene mine blei klippet på stua UTEN at jeg plukka opp bitene etterpå. Etterpå skal jeg steke pizza og drikke øl. Kanskje ta en blås også.
Saken oppdateres fortløpende
Siden sist har jeg:
- tissa i kjøkkenvasken så jeg slapp å gå ut på do.
- Spist smågodt enda det ikke er lørdag.
- Drukket øl.
- Kjøpt usunn baconcheeseburger på kebabsjappa rett ved her.
- Røyka.
- Tatt på meg selv.
Dag 2:
Ryktene ser ut til å stemme. Heller ikke i dag har udyret returnert.
Jeg sov til klokka halv to. Har ikke spist noe annet enn seigmenn enda. Det var ingenting fristende som tar under to minutter å lage.Vurderer å gå på butikken etter flere øl. Rotet på stuebordet har vokst. Merkelig. Det pleier å bli borte av seg selv. Skulle tatt medisinene mine, men gidder ikke gå og hente dem inne på rommet.
Akkurat nå ser jeg på porno på TVen i stua.
Jeg slapp ørkenrottene løs på stuegulvet og nå finner jeg bare den ene. Pytt sann. Den andre dukker nok opp.
Endret av L4r5
  • Liker 3
I natt har du blåst opp en ballong, tegnet et ansikt på den og snakker til den mens du går rundt naken.
Og så kommer Anfall hjem mens går rundt naken i stua med pornofilm på TV'n, en blodig dildo og snakker med ballonghodet, og du bare..øh..jeg kan forklare.
Endret av Bytex
Hahaha!
Jeg er kjempe flink til å massere! Og jeg kan lakke tåneglene dine :p
Gjest
