Den nye Forumkaféen
Prøv å skru ned frameraten da (husker ikke hvordan man gjør det :p)
her er configfila:
litt usikker på hva jeg skal stille på
Klikk for å se/fjerne innholdet nedenfor
# This is the configurationfile for DOSBox 0.72.
# Lines starting with a # are commentlines.
# They are used to (briefly) document the effect of each option.
[sdl]
# fullscreen -- Start dosbox directly in fullscreen.
# fulldouble -- Use double buffering in fullscreen.
# fullresolution -- What resolution to use for fullscreen: original or fixed size (e.g. 1024x768).
# windowresolution -- Scale the window to this size IF the output device supports hardware scaling.
# output -- What to use for output: surface,overlay,opengl,openglnb,ddraw.
# autolock -- Mouse will automatically lock, if you click on the screen.
# sensitiviy -- Mouse sensitivity.
# waitonerror -- Wait before closing the console if dosbox has an error.
# priority -- Priority levels for dosbox: lowest,lower,normal,higher,highest,pause (when not focussed).
#			 Second entry behind the comma is for when dosbox is not focused/minimized.
# mapperfile -- File used to load/save the key/event mappings from.
# usescancodes -- Avoid usage of symkeys, might not work on all operating systems.
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=true
[dosbox]
# language -- Select another language file.
# memsize -- Amount of memory DOSBox has in megabytes.
# machine -- The type of machine tries to emulate:hercules,cga,tandy,pcjr,vga.
# captures -- Directory where things like wave,midi,screenshot get captured.
language=
machine=vga
captures=capture
memsize=16
[render]
# frameskip -- How many frames DOSBox skips before drawing one.
# aspect -- Do aspect correction, if your output method doesn't support scaling this can slow things down!.
# scaler -- Scaler used to enlarge/enhance low resolution modes.
#		   Supported are none,normal2x,normal3x,advmame2x,advmame3x,hq2x,hq3x,
#						 2xsai,super2xsai,supereagle,advinterp2x,advinterp3x,
#						 tv2x,tv3x,rgb2x,rgb3x,scan2x,scan3x.
#		   If forced is appended (like scaler=hq2x forced), the scaler will be used
#		   even if the result might not be desired.
frameskip=0
aspect=false
scaler=normal2x
[cpu]
# core -- CPU Core used in emulation: normal,simple,dynamic,auto.
#		 auto switches from normal to dynamic if appropriate.
# cycles -- Amount of instructions DOSBox tries to emulate each millisecond.
#		   Setting this value too high results in sound dropouts and lags.
#		   You can also let DOSBox guess the correct value by setting it to max.
#		   The default setting (auto) switches to max if appropriate.
# cycleup   -- Amount of cycles to increase/decrease with keycombo.
# cycledown	Setting it lower than 100 will be a percentage.
core=auto
cycles=auto
cycleup=500
cycledown=20
[mixer]
# nosound -- Enable silent mode, sound is still emulated though.
# rate -- Mixer sample rate, setting any devices higher than this will
#		 probably lower their sound quality.
# blocksize -- Mixer block size, larger blocks might help sound stuttering
#			  but sound will also be more lagged.
# prebuffer -- How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
# mpu401	  -- Type of MPU-401 to emulate: none, uart or intelligent.
# device	  -- Device that will receive the MIDI data from MPU-401.
#				This can be default,alsa,oss,win32,coreaudio,none.
# config	  -- Special configuration options for the device. In Windows put
#				the id of the device you want to use. See README for details.
mpu401=intelligent
device=default
config=
[sblaster]
# sbtype -- Type of sblaster to emulate:none,sb1,sb2,sbpro1,sbpro2,sb16.
# sbbase,irq,dma,hdma -- The IO/IRQ/DMA/High DMA address of the soundblaster.
# mixer -- Allow the soundblaster mixer to modify the DOSBox mixer.
# oplmode -- Type of OPL emulation: auto,cms,opl2,dualopl2,opl3.
#			On auto the mode is determined by sblaster type.
#			All OPL modes are 'Adlib', except for CMS.
# oplrate -- Sample rate of OPL music emulation.
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
# gus -- Enable the Gravis Ultrasound emulation.
# gusbase,irq1,irq2,dma1,dma2 -- The IO/IRQ/DMA addresses of the
#			Gravis Ultrasound. (Same IRQ's and DMA's are OK.)
# gusrate -- Sample rate of Ultrasound emulation.
# ultradir -- Path to Ultrasound directory.  In this directory
#			 there should be a MIDI directory that contains
#			 the patch files for GUS playback.  Patch sets used
#			 with Timidity should work fine.
gus=true
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
# pcspeaker -- Enable PC-Speaker emulation.
# pcrate -- Sample rate of the PC-Speaker sound generation.
# tandy -- Enable Tandy Sound System emulation (off,on,auto).
#		  For auto Tandysound emulation is present only if machine is set to tandy.
# tandyrate -- Sample rate of the Tandy 3-Voice generation.
# disney -- Enable Disney Sound Source emulation. Covox Voice Master and Speech Thing compatible.
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=true
[joystick]
# joysticktype -- Type of joystick to emulate: auto (default), none,
#				 2axis (supports two joysticks,
#				 4axis (supports one joystick, first joystick used),
#				 4axis_2 (supports one joystick, second joystick used),
#				 fcs (Thrustmaster), ch (CH Flightstick).
#				 none disables joystick emulation.
#				 auto chooses emulation depending on real joystick(s).
# timed -- enable timed intervals for axis. (false is old style behaviour).
# autofire -- continuously fires as long as you keep the button pressed.
# swap34 -- swap the 3rd and the 4th axis. can be useful for certain joysticks.
# buttonwrap -- enable button wrapping at the number of emulated buttons.
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=true
[serial]
# serial1-4 -- set type of device connected to com port.
#			  Can be disabled, dummy, modem, nullmodem, directserial.
#			  Additional parameters must be in the same line in the form of
#			  parameter:value. Parameter for all types is irq.
#			  for directserial: realport (required), rxdelay (optional).
#			  for modem: listenport (optional).
#			  for nullmodem: server, rxdelay, txdelay, telnet, usedtr,
#							 transparent, port, inhsocket (all optional).
#			  Example: serial1=modem listenport:5000
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
# xms -- Enable XMS support.
# ems -- Enable EMS support.
# umb -- Enable UMB support.
# keyboardlayout -- Language code of the keyboard layout (or none).
xms=true
ems=true
umb=true
keyboardlayout=none
[ipx]
# ipx -- Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
# Lines in this section will be run at startup.
Noen ide?
Hvilket spill btw?:)
One must fall 2097
Uff, stress.
Begynner jeg først å barbere et sted på kroppen, blir jeg hekta og tar resten også.
Da blir det shaved nedentil, mage, bryst, hals, hake og kinn.
Akkurat det er jeg IKKE gira på ><
edit: Nei, nå er jeg lei av å stå bøyd over tastatur og få nakken i rar posisjon for å se skjermene.
Natta DNFK ^^
Endret av Datasmurf
Tror jeg skal dit en tur for å besøke folka vertfall. Men er ikke sikker.
Mamma maser om at jeg må begrense bruken av headsett ><...
Ja, dra deg på TG08! Besøk er kos =D
edit: Leggetid på Jonas nå. Natta forumtroll!
Endret av clvn
Gjest
