Den nye Forumkaféen
Sleeping on your back:
The pros: This position is great for balancing out your body weight and keeping your internal organs aligned. Just be sure to keep a pillow under your knees to help maintain proper alignment of your back.
The cons: Not the best position for snorers, since this may make their snoring worse!
Sleeping on your side:
The pros: Lying on your side in the fetal position with your knees bent and a pillow between your legs is said to take stress off your back. What's important is that you use a pillow that will keep your head in a neutral position so that your head won't drop and affect your posture. And did you know that sleeping on your left side reduces heartburn pain and is best when you're pregnant since it increases blood and nutrient flow to your baby?!
The cons: You're in luck — there aren't really any since this position follows the natural curvature of the spine.
Sleeping on your stomach:
The pros: If you have lower back pain, occasionally sleeping on your stomach can relieve pressure on your disc spaces. I know if I've been leaning over all day, falling asleep like this feels fantastic since it resembles the cobra yoga position (lots of pillows required!). And it's been rumored that sleeping on your stomach can lower your blood pressure as well, but we're waiting for some more concrete evidence on this.
The cons: I saved the worst for last. Sleeping on your stomach is a big no-no. According to Terri Trespicio, senior editor of Body+Soul magazine, "sleeping on your stomach flattens the natural curve in the lower back and keeps your head turned to one side all night, which distorts the alignment of the spine in your neck." This position can also exert unnecessary pressure on your nerves which will cause pins and needles when you wake up. And your breasts won't like this position, either!
kilde.
Artikkelen omhandler kvinner, men ryggen er noe mannfolk også har.
Gjest medlem-1432
Vel, du sover vel med hodet en eller annen retning, gjør du ikke? Prøv å gå rundt med hodet snudd 90 grader da, og se hvordan kroppen føler om det.
Det går helt fint. Hadde det vært dårlig tror jeg kroppen hadde protestert til nå. ;å du ikke kvervulere sånn. Hoho!
Kan jo være at det ikke er så heldig for andre, det veit jeg ikke noe om.
Jeg kverulerer ikke, jeg bare henviser til de så og si samtlige kiroprakter og leger sier om emnet. :)
sov selv på magen i flere år , fort at man legger seg oppå armene i søvne , slik at armene blir fullstendig lamme. Kan skrive under på at det er ubehagelig og måtte banke og klaske igang blodsirkulasjonen :(
Skjedd med meg også, helt jævelig.
Våknet og skulle flytte på meg litt da jeg kjente at armen bare hang etter og kunne ikke røre den... Ugh. Tok litt tid så kjente jeg blodet strømme til armen igjen :p Litt panikk.
Endret av Kakeshoma
Det er dårlig for ryggen og nakken.
Jeg sovner hvertfall på magen oftest, og merker ikke mere til det. Ligger jeg på rygg sovner jeg aldri. Ligger vel mest sånn halvveis på en av sidene, med ene foten rett ut og andre i "bøy". Armer under puta er garantert å våkne etter to timer med to kalde lik ved siden av seg. Men jeg klarte bare ikke å finne sovne-posisjonen, fikk ikke armene på rett plass. Alt jeg prøvde ble ubehagelig etter en stund. Og når man bare ligger i mørket i 4-5 timer og prøver å sovne, blir man sliten i armer og nakke uansett.
Gjest medlem-1432
Våkner jo fort opp i litt andre stillinger da. Men er så deilig å sovne sånn hvertfall synes nå jeg.
Skal ut å ri om en times tid. Det snør nesten sidelengs. :cry:
Endret av medlem-1432
Jeg er så misunnelig på dere som bor i storbyer, her i Stockholm kan jeg få sushi, mcdonalds, burgerking, restauranter, kinesiske restauranter, meksikanse restauranter, ica, ica stormarked, hoteller, taxi, billeie, klesbutikker, frisører, bowling, kino ++++ alt innenfor 10 minutter gåing.
Herregud så greit dere har det. Og en annen ting: Gratis wifi og 3g i hele byen.
Win.
Leste nettopp om maksimum tid du kan sove på armene før det begynner å bli kritisk . 4 timer , etter det så kan det utvikle seg nekrose :ph34r:
Gjest
