Den nye Forumkaféen
Fordi du har jobb?
Jeg ble vekket i natt. 03:30 ca fikk jeg telefon fra en nattevakt. Så da måtte jeg, på min første nattevakt, prøve å finne ut hva som var galt...
... ingenting var galt... Gah. Fikk ikke sovna før 5 igjen, og alarmen går 6...
File "Driver.py", line 256, in __load_project
project.init()
File "./WebTools.py", line 65, in init
HallResources.resources.changeCertFile( hall_data, market_area, brand, application )
File "/home/webtools/WebTools_bundle/hall/HallResources.py", line 686, in changeCertFile
application=application_textkey )
File "/home/webtools/WebTools_bundle/hall/config/Configurator.py", line 116, in __init__
default_namespace=default_namespace,)
File "/home/webtools/WebTools_bundle/hall/config/Configurator.py", line 259, in initialize
installation = ilf.getByFranchiseId( franchise_id, application_id=application_id )
File "/home/webtools/WebTools_bundle/hall/config/InstallationListFactory.py", line 126, in getByFranchiseId
where_clause = "%s = '%s'" % (
File "/home/webtools/WebTools_bundle/hall/HallSQLTemplate.py", line 607, in clean
db = HallResources.resources.getDB( "configdb" )
File "/home/webtools/WebTools_bundle/hall/HallResources.py", line 479, in getDB
raise HallResourceFailure( msg )
HallExceptions HallResourceFailure: ERROR: While making DB connection to configdb
dbdict {'user': 'webtools', 'db': 'configdb', 'password': 'Wam627HtJ.2bg', 'host': '10.10.12.38', 'dbtype': 'mysql'} . (hwmodules.db.DBExceptions.DBInitError : Unable to instantiate MySQLDataAccess:
File "/home/webtools/WebTools_bundle/hwmodules/db/DBFactory.py", line 144, in __loadDataAccess
exec("rval = module.%s(args)" % moduleName)
File "", line 1, in ?
File "/home/webtools/WebTools_bundle/hwmodules/db/MySQLDataAccess.py", line 45, in __init__
raise DBInitError("stacktrace:\n%s" % StackTrace())
db DBExceptions DBInitError: stacktrace:
File "/home/webtools/WebTools_bundle/hwmodules/db/MySQLDataAccess.py", line 42, in __init__
self.__db = apply(MySQLdb.connect,(),argdict)
File "/usr/local/python2.1/lib/python2.1/site-packages/MySQLdb/__init__.py", line 63, in Connect
return apply(Connection, args, kwargs)
File "/usr/local/python2.1/lib/python2.1/site-packages/MySQLdb/connections.py", line 58, in __init__
self._db = apply(connect, args, kwargs2)
OperationalError: (2003, "Can't connect to MySQL server on '10.10.12.38' (113)")
Og, eh, tabeller? :cry:
Har du noen gang jobba, smurf? :dontgetit:
Endret av bazukh
Ida1, ja, jøss. Jeg har mange år på baken innen arbeidslivet. :p
Jeg har til og med jobba som IT-support på tre forskjellige steder.
Har også jobba som vaskehjelp og fiksa mat til eldre og svake.
Samt at jeg har hospitert på Expert en gang i tiden, samt hospitert på IT-avdelinga til et sykehus.
Har også jobba for et oljeselskap. :p
Ikke Ida1, bare Ida.
Og: Unnskyld, men det har jeg vanskelig for å tro :p
Pff, du vil for evig og alltid være Ida1, akkurat som Aids er Ida2 og Kitty er Ida3.
Jeg har bevis, et eller annet sted.
Kan helt sikkert gi deg noen navn og telefonnummer du kan ringe for å få det bekreftet, siden jeg er for lat til å grave opp kvitteringer, kontrakter og lønnsslipper og slikt.
Mikkel, er det for sent å få deg til å fikse en kassettspiller til meg? :p
Om en av de kassetspillerne fortsatt lever etter den behandlinga vi ga dem så ... ja. Sier seg selv :p
Dæven. Tror jeg har kasta 40 pc-er, en haug med gamle kassetspillere og masse anna drit.
Kastet du kassettspiller som kan kobles opp til forsterker? Trenger en!
Kastet MANGE
Gjest
