Den nye Forumkaféen
Vil du ha hår på pungen kjører du Arch linux.
http://wiki.archlinux.org/index.php/Main_Page
"DON'T PANIC!
The Arch Linux system is assembled by the user, from the shell, using basic command line tools. This is The Arch Way. Unlike the more rigid structures of other distributions and installers, there are no default environments nor configurations chosen for you. From the command line, you will add packages from the Arch repositories using the pacman tool via your internet connection and manually configure your installation by editing text files until your system is customized to your requirements. This method allows for maximum flexibility, choice, and system resource control from the base up.
Arch Linux is aimed at competent GNU/Linux users who desire minimal 'code separation' from their machine."
Drit i om det står "competent gnu/linux users", du kan gjøre komplett install ved å følge beginner's guide.
<3 Arch
Flotters, satte vekkeklokka 05.00 for å lage meg spagetti før jobb. NÅ våkna jeg, og jeg skille liksom hatt vikartimer 10.00 >_<
Kanin: Om dere har MS Access har du min største sympati =]
Gjest
