Får feilmelding i dxdiag. kan noen hjelpe?
når jeg kjører dxdiag får jeg feil under network. feilmeldingen består av:
Network Tab: The registry information for the service provider 'DirectPlay8 Modem Service Provider' is missing or damaged. You should reinstall DirectX.
The registry information for the service provider 'DirectPlay8 Serial Service Provider' is missing or damaged. You should reinstall DirectX.
The registry information for the service provider 'DirectPlay8 IPX Service Provider' is missing or damaged. You should reinstall DirectX.
The registry information for the service provider 'DirectPlay8 TCP/IP Service Provider' is missing or damaged. You should reinstall DirectX.
Jeg har prøvd og reinstallere til ingen nytte. Jeg kjører dx8.1. noen som har en løsning?
