free rider 2 har kommet
krassi
Dødelig fjellside:
-18 1i 18 1i,17 1h dm 60,fs 9j j8 d3 nk ee ql it vs ur,12k um 1a5 1b9,12h um ut 198,1a6 1b9 1e8 1h6,1cs 1ik 1gt 1o6,1en 1nm 1i5 1u3,1gk 1ul 1lm 25g,1k8 268 1rm 2cd,1r2 2ec 1po 2ii,1qa 2im 1t0 2fc,1t4 2du 21j 2je 1v3 2nk 22s 2ol 2dt 341,2es 2vf 2ot 38o,2e9 34p 2gm 3aq,2iu 34e 2p5 3gb,2gm 3bb 2gg 3kg##T 2ls 3h8,T 2ik 390
Tips: Fart må tilpasses perfekt.
Klarte den på 16 sekunder med etthjulssykkel. Tok tre forsøk, før jeg traff stjernene på slutten perfekt. Men det gikk!
Endret av Snorre
Lagde en rar bane jeg og :p
-18 1i 18 1i 6i 2l ba 2l,ba 2n fk 2i,fp 2i i1 1a,op 7t 14e c7,10s ar 15l aj,15i c0 2ai ij,2dn id 2ee id 2f6 i0,2f4 i0 2fh hp 2fq he 2ft hb,2ft hc 2ga go,2ga gn 2gi fu,2gk fu 2gm f9,2gm f5 2gk er,2gh ft 2gk fl,2gm f7 2gl f4,2gk eq 2gk em,2f5 e8 24k f4,2dm ic 2ad in,2i7 fq 2un h4,2ul h4 3h0 lq,3h1 lq 3jk lq,3js j4 3mj j6,3ml j4 3od jn,3ob jp 3oj l3,3oj l2 3os mi,3os mm 3os o4,3oq oa 3nu pm,3ns po 3ml qb,3c4 nn 3c4 t4,3c4 t2 3re 10e,3jg lq 3k2 li,3mk qb 3fc s4,3rd 10e 3ra 1al 3ss 12p 4h1 25b,51b 27t 51g 25q,51d 25q 51b 23a,51b 237 518 1tr,518 1tm 50d 1p2,508 1ot 4sv 1or,4st 1or 4mi 1sg,4mg 1sg 4m1 20d 4m1 23u,4h1 25d 4j2 28h,4j4 28h 4kc 29s,4kc 29u 4lp 2aq 4o2 2bo 4q3 2c2 4rq 2bv 4u2 2bt,4u5 2bt 4vi 2b6,4vf 2b4 50i 29s 519 28f,519 28c 519 27r,15m 9i 1d6 b9,1d5 b8 1en bo,4ul 23s 4lv 24b,4m0 23t 4m0 24b,4uj 23q 4vc 23o##T 4m5 238,T 4me 23l,T 4mf 23i,T 4mf 23i,T 4mm 23f,T 4nf 23f,T 4n7 23f,T 4n3 23g,T 4mf 23k,T 4mj 23l,T 4n2 23k,T 4nk 23p,T 4n7 23s,T 4mu 23u,T 4mo 23k,T ai 26,T 4a 1n,T hm 13,T vj a3,T u6 9c,T st 92,T 1fg ct,T 1ar b6,T 196 au,T 17u ai,T 2ef hh,T 2c6 hr,T 29j e7,T 2fp es,T 2tr g8,T 3nm oi,T 3jv kv,T 3cm sh,T 4d3 1sv,T 4ev 1ve,T 4gf 22b,T 4hs 24u,T 4j6 27b,T 4kj 29a,T 4m1 2a7,T 4o1 2b1,T 4ns 23o,T 4nj 23l,T 4mi 23q,T 4mf 23j,T 4o1 23e,T 4ns 23g,T 4ni 23o,T 4n9 23l,T 4n1 23l,T 4o4 23l,T 4ms 240,T 4mi 23m,T 4nl 23j,T 4nj 23o,T 4ne 23o,T 4n4 23m,T 4mi 23l,T 4ms 23m,T 4p4 239,T 4qu 239,T 4rl 239,T 4t1 239,T 4ue 239,T 4r5 2b6,T 4ot 2b6,T 505 22l,T 505 240,T 505 25f,T 4vr 27g,T 4v4 295,T 4u1 2an,T 4sl 2b3
Kommer ikke forbi den første rare tingen. Kun bilen og firkanten du kan ta den med?
Jeg tror det er lurt å si vilket kjøretøy som er lurest og bruke på banen.
Endret av krassi
på denne banen anbefaler jeg dere og bruke ett kjøretøy som kan fly. :p
OPP og NED
-18 1i 18 1i,84 -7e 84 bg,f0 -3n f5 -2jq,h2 -1uf go -3o,es -9 eo 1ad,gv 17v gr -5,hd 6 1fe fq,1fa fq nf -11d,ne -172 h6 -1ug,13k -106 17c -2gu fa -2jo,t2 -m6 11o -q8 12l -q3 13i -po 13q -oh 13m -n7 13b -lj 130 -k4 12p -ii 12r -h6 139 -fu 143 -ev 14t -dq 159 -cd 158 -bb 155 -ac 14u -9i 14m -8p 14k -81 14j -7e 14i -6t 158 -6f 160 -6f 16s -6p 17l -7h 188 -8i 18s -9h 19k -at 1ad -c7 1b7 -dg 1ch -f6 1dk -gi 1ek -hi 1fj -ig 1g7 -jeg 1g8 -km 1g2 -lp 1fu -mm 1fq -ng 1fm -oa 1fg -ov 1fc -pi 1f8 -q1,18k -q8 18a -q8 1f6 -q8 1ft -qj 1gj -r4 1h7 -rr 1hp -sh 1i9 -tb 1ii -u9 1io -v9 1it -106 1j5 -11e 1je -12k 1jp -13v 1k3 -15e 1k8 -16n 1ka -17o 1k9 -18q 1k1 -19o 1jl -1ag 1j4 -1b4 1id -1bg 1hh -1bl 1gl -1bj 1fr -1b9 1f7 -1aq 1ep -1a0 1ei -199 1ef -18e 1eh -17e 1em -16g 1f1 -15j 1fe -14q 1g0 -13t 1gj -134 1h6 -12d 1i0 -11m 1ir -113 1jk -10j 1kf -102 1l6 -vh 1lu -uo 1mm -tn 1nd -sk 1o1 -r9 1oe -pu 1om -os 1oe -o0 1o0 -n5 1n8 -mh 1mc -ma 1l4 -mg 1k4 -n0 1j7 -nf 1id -nv 1hk -of 1gu -ou 1gb -pc 1fs -po 1ff -q2,-3o -3e -9c u -7q 1i -bs 84,-3o -3e -4c 2q -5u 26 -9c 8o -bs 84,8e -i4 6i -ne 5k -mq k -tc -u -rq 42 -ls,8e -i4 34 -l8 42 -ls,bi 1s 92 4c 9m 4m 8o 68,bi 1s au 5a aa 50 9c 68 92 68 8o 5u,1f6 fk 130 7q 1ei e2 148 6i 1da bi 164 5a 1cc 9m 172 4c 1b4 76 180 3o 1a6 5a,ku -1aq ka -1fq jm -1f6 io -1hc,ku -1b4 i4 -1ei j2 -1es i4 -1h2 io -1hc,tm -16o ua -1cc so -1cc se -1kg,tm -16o pk -1c2 rq -1c2,rq -1cc rg -1k6 se -1kg,rq -1cc rq -1c2,1iu -114 1i3 -114 1h6 -114 1g3 -11e 1f0 -121 1dp -12p 1cf -13m 1ba -14g 1a7 -157 191 -14u 184 -14f 17a -13v 16j -13b 15t -12k 15b -120 14q -11e 14b -10v 13v -10i 13l -107#-18 -5u 34 -26 3o -6i 34 -5u 2q -5k 34 -5a 2g -50 34 -4m 26 -4m 2g -4m 1s -50 1i -50 u -4m u -50 1i -5a 1s -5a 2g -4m 26 -4m 2q -42 2q -4m,3o -6i -u -4m -u -5k,-u -4m -1i -4c -1i -5u -18 -5u,-1i -5u -1i -68 -18 -5u,3o -6i 76 -4c 34 -26,34 -5u 3e -5k 34 -5a 3e -50 2q -4c 3e -3o 2g -3e 1s -3e 2g -34,2g -3e 34 -34 2g -2q 34 -2g,2q -42 1s -42 1s -3o 26 -42 1s -4c 18 -4m,1s -42 2g -3e,2q -5u 26 -5k,26 -5u 2g -5a 1s -5a,1s -4m 1s -4c 18 -3o,1i -4m 26 -4m,1i -50 1s -4m 1s -4c,u -3e u -3o,26 -50 1i -5a 18 -5a,1i -5a 1s -5a,26 -5a 26 -5k,1s -5k 1s -5a,1i -5a 1i -50,18 -4c u -50 k -50 u -50 18 -50,1i -5a 1i -5k,u -5a 18 -5a,1i -4m 26 -4c 2g -42,2q -3o 2q -42,4c -5k 42 -5a 4c -50 4m -5a 4c -5k,5u -3o 5a -3o 4m -42,-1i -5k -u -5k,-k -5a -1i -5a,-1i -50 -a -50,-u -4m -1i -4m,-18 -4m -18 -5u,-u -5a -u -4m,-k -5a -k -50#T 84 -fk,T 84 -fa,T 84 -f0,T 84 -em,T 84 -ec,T 84 -e2,T 84 -do,T 84 -de,T 84 -d4,T fk -26,T fk -1i,T 84 -cq,T 84 -cg,T 84 -c6,T 84 -bs,T 84 -bi,T 84 -b8,T 84 -au,T 84 -aa,T 84 -ak,T 84 -a0,T 84 -9m,T 84 -9c,T 84 -92,T 84 -8o,T 84 -8e,T 84 -84,T 84 -7q,T 84 -7g,T fk -1s,T ne -122,T 1bo -qs
Endret av krassi
OPP og NED
23 sekunder med helikopteret etter 3 forsøk. :)
19 sek. etter 5 forsøk. :D
Endret av Gissan
Legger ved noen baner fra den forrige tråden, da banene derfra også kan brukes til FR2.
-1i,1i,1i,1i 1h,1i,59,3r 59,3r,78,37 78,37,7b,4f 7b,4f,bi,bb bi,bb,gc,bf gc,bf,ga,i1 ga,bg,na,eb ga,i1,ol,fd na,eb,rn,eh ol,fd,tk,ht om,fd,13o,ci sn,fv,pe,fj pe,fj,13q,ci sd,hc,qt,f4 qt,f4,tj,fh rn,eh,ug,dj tj,fh,11a,hd u7,f0,t6,f0 t3,f0,sn,f7 sn,f7,sh,fd sh,fd,se,fh se,fh,sf,g5 tu,gn,s9,g6 s9,g6,sd,hc sf,g5,sh,gn sh,gn,sk,gt sk,gt,td,hd tk,ht,12g,h0 td,hd,uj,hl vr,h9,ts,dt ts,dt,tu,gn ug,dj,ve,dl 105,f8,uv,f7 uu,f7,um,f6 um,f6,uf,f2 uj,hl,v4,he v4,he,106,h9 120,gv,101,du 101,du,vr,h9 11o,e1,10j,e8 10j,e8,107,f5 10s,g8,10d,fi 10d,fi,vv,f8 vv,f8,us,f1 106,h9,10r,gr 123,ei,11o,e1 11a,hd,123,ei 13o,ci,120,gv 10r,gr,111,gh 111,gh,10s,g8 12g,h0,13q,ci 13q,ci,16g,ja 16g,ja,13q,cl 13q,cl,16f,j7 16f,j7,1ir,j7 1ir,j7,169,j7 169,j7,1ir,j7 1ir,j7,16a,j7 16a,j7,1is,j7 1jj,jk,1hr,k9 1hr,k9,1gp,lp 1gp,lp,1gq,m9 1gq,m9,1hr,ni 1hr,ni,1it,ob 1is,j7,1jk,j5 1it,ob,1ko,or 1k4,iv,1l9,i6 1jk,j5,1k4,iv 1lj,ie,1l4,j8 1l4,j8,1kc,jeg 1kc,jeg,1jj,jk 1ko,or,1lp,og 1l9,i6,1m2,hd 1m2,hd,1lj,ie 1m2,ip,1m1,ie 1m1,ie,1lv,hq 1lv,hq,1lv,he 1mp,k2,1mk,jt 1mk,jt,1mg,jo 1mg,jo,1m7,j6 1m7,j6,1m2,ip 1lp,og,1md,o4 1md,o4,1mn,np 1n7,l9,1n1,k7 1n1,k7,1mp,k2 1n8,m3,1n7,l9 1mn,np,1ms,n8 1ms,n8,1mu,n1 1mu,n1,1n8,m3 1pu,ja,1vq,ja 1vq,ja,1vn,h0 #at,90 r4,dq 16r,im 1ap,io 1ji,ir 1jt,im 1ka,ih 1kr,i7 1l3,hv 1kj,ia 1ld,hj 1ln,h9 1qb,j1 1qo,j0 1re,j1 1sj,j0 1t8,j0 1ud,iu
Personlig rekord: 13 sekunder med firkanten.
-1i,1i,1i,1i -5,14c,ci,18f 1g,da,dj,h4 4,nk,c7,sp 1i,1i,1v,1j 1v,1j,2b,1l 2b,1l,2q,1q 2q,1q,35,25 35,25,39,2g 39,2g,3b,2v 3b,2v,3a,59 3b,6d,di,79 53,1hj,43,1ho 44,1hn,3q,1ht 3q,1ht,3h,1i5 cb,1h3,4g,1ib 3h,1i5,3d,1if 3d,1if,3c,1iq 3c,1iq,3d,1j7 3d,1j7,3i,1ji 3i,1ji,3t,1ju 3t,1ju,4j,1k8 4j,1k8,55,1kd 6j,1cg,5o,1cj 5o,1cj,5e,1cq 5e,1cq,59,1d7 59,1d7,59,1do 59,1do,5d,1e7 5d,1e7,5m,1ej 5l,1ej,62,1es 62,1es,6o,1f3 55,1kd,61,1kj 61,1kj,74,1kj cc,1c8,6b,1d7 6o,1f3,7e,1fa 7e,1fa,7s,1fc 74,1kj,f1,1kl 7s,1fc,di,1fh br,rr,ck,s8 cl,tn,c6,tt c6,tt,bk,u0 bk,u0,b5,u2 c6,17m,d3,181 d1,1bu,cc,1c8 do,1go,ca,1h3 d3,6k,dp,6n dp,6n,e5,6r e9,8e,ds,8j ds,8j,dc,8l da,ga,e3,gk e7,i3,dq,ib dq,ib,db,if db,if,cr,ie cj,s8,cr,se cr,se,cv,sl cu,sl,d1,su d1,su,d0,t5 d0,t5,cu,te cu,te,cl,tn d3,181,db,189 db,189,df,18j df,18j,df,18q df,18q,de,198 de,198,dc,1b6 dc,1b6,d9,1bj d9,1bj,d1,1bu d0,1es,dp,1et dp,1et,e5,1f1 e6,1gi,do,1go e8,1ge,dv,1gm e5,6r,ee,71 ee,71,ek,79 ek,79,em,7i em,7i,en,7t en,7t,ej,85 ej,85,e9,8e e3,gk,eb,gr eb,gr,ee,h3 ee,h3,ef,he ef,he,ec,hr ec,hr,e7,i3 e5,1f1,eb,1f7 eb,1f7,ef,1ff ef,1ff,eh,1fn eh,1fn,eg,1g2 eg,1g2,ec,1g9 ec,1g9,e8,1ge f1,1kl,r8,1kk r8,1kk,s4,1ke u0,1f2,te,1ek sq,1k3,tf,1jg tf,1jg,ts,1ip s4,1ke,sq,1k3 uc,1gl,u9,1fk u9,1fk,tv,1f4 ts,1ip,u7,1hr u7,1hr,uc,1gl #3d,1is 3t,1je 58,1dg 5p,1e8 50,1ju 6t,1eo d2,1bi eg,1fk rk,1ke tl,1fs td,1fa t0,1f4 sl,1f1 s5,1f1 t4,1je tj,1ik sg,1k0 tt,1hg tp,1gl
Personlig rekord: 19 sekunder med firkanten.
-1i,1i,1i,1i 1h,1j,7g,2h 7f,2g,gd,5j gd,5j,ro,74 ro,74,sb,75 vl,78,rm,7c rm,7c,vj,76 sb,75,sq,74 sq,74,t7,70 t7,70,tm,6s tm,6s,u1,6i ud,68,uo,5r uo,5r,v1,5e v1,5e,vd,4t v7,73,uu,5s uu,5s,uo,75 u1,6i,ud,68 vc,55,v7,73 uo,75,uf,6b vd,4t,vn,4e vn,4e,vl,78 vj,76,vc,55 136,74,15t,74 15t,74,1d6,74 1d6,74,1nd,96 1iv,aj,1hr,83 1hr,83,1kj,at 1kj,at,1jf,8g 1jf,8g,1l7,b0 1q7,c1,1iv,aj 1l7,b0,1kb,8k 1kb,8k,1ln,b0 1ln,b0,1l6,8q 1l6,8q,1mh,b6 1mh,b6,1lv,8u 1lv,8u,1nh,bi 1nd,96,1v2,8p 1nh,bi,1n8,97 1n8,97,1o8,bf 1o8,bf,1oi,9b 1oi,9b,1q0,bg 1tq,9a,1op,9h 1op,9h,1q0,9v 1q0,bg,1qi,9n 1qi,9n,1r3,b6 1r3,b6,1rn,9r 1v2,8p,1q7,c1 1sb,a5,1t4,91 1rn,9r,1sb,a5 1t4,91,1tq,9a 209,bl,22l,eb 20a,bl,25v,bl 22h,db,225,c3 225,c3,225,bi 225,bi,230,ce 230,ce,244,cu 23o,dd,233,dq 233,dq,22h,db 22l,eb,25u,eb 259,cc,23v,bv 23v,bv,23o,dd 25s,c9,24a,ct 24a,ct,23v,dp 23v,dp,279,dk 244,cu,25s,d5 25v,bl,2f5,bl 29c,bv,25s,c9 279,dk,259,cc 25s,d5,282,d5 25u,eb,25c,ea 25u,ea,2fk,ea 28e,cl,277,dg 277,dg,29c,bv 2c5,cj,28e,cl 282,d5,2au,cv 29g,do,289,dh 289,dh,2f5,bm 2ca,dm,2a7,ca 2a7,ca,2c5,cj 2au,cv,2bl,d4 2bl,d4,29g,do 2d0,bs,2ca,dm 2eb,e4,2d0,bs 2fk,ea,2e4,bm 2e4,bm,2eb,e4 2f5,bm,2nv,db 2nv,db,2q2,ej 2q2,ej,36s,oc 36s,oc,3at,ph 3at,ph,3dt,pm 3dt,pm,3l3,pm 3l3,pm,3lk,pk 3lk,pk,3m3,pf 3m3,pf,3mh,p7 3mh,p7,3n0,oq 3np,pl,3l8,pn 3l8,pn,3m9,pl 3m9,pl,3mi,p6 3mi,p6,3mn,pk 3n0,oq,3ni,o7 3ni,o7,3nt,nk 3nt,nk,3np,pl 3mn,pk,3mu,or 3mu,or,3n5,pg 3n5,pg,3nd,oh 3nd,oh,3nk,ph 3nk,ph,3nm,o9 3pl,pj,3tl,pj 3tl,pj,47m,pj 431,k0,43k,kd 43i,l2,42s,k2 42s,k2,43g,iu 42p,s4,42s,r2 42s,r2,45j,r2 44e,qs,430,r1 430,r1,42k,sa 43r,sb,42p,s4 42k,sa,431,t8 431,t8,42n,ta 42n,ta,43f,s2 466,im,44n,in 44n,in,43m,is 43g,iu,43h,la 43h,la,44i,j5 44i,j5,45c,k2 45l,j1,44i,kk 44i,kk,452,iu 44t,kj,43d,l9 43k,kd,43l,l1 46f,rj,43r,sb 47a,r0,44e,qs 43f,s2,462,s8 46j,te,44m,st 44m,st,450,ti 48t,j5,466,im 46l,k5,44t,kj 45c,k2,45l,j1 452,iu,445,j6 47m,pj,45u,n0 45u,n0,48n,o5 45j,r2,47a,r0 462,s8,46j,te 450,ti,48f,sq 47d,ic,49r,j8 498,kh,46l,k5 4ae,lp,47d,ks 47d,ks,474,m7 48n,o5,46e,nd 46e,nd,47r,ol 48t,np,47f,mv 47f,mv,48s,mo 474,m7,4b0,o6 47r,ol,46n,nq 46n,nq,47m,p2 47m,p2,488,o3 4bs,p9,47m,pp 47m,pp,46f,rj 47l,ql,489,ps 48u,r5,46s,rm 46s,rm,470,t7 49n,rn,47s,rh 47s,rh,46l,t0 470,t7,49j,sr 46l,t0,48m,sn 4b1,jt,48t,j5 4ad,l7,498,kh 48s,mo,49m,nn 488,o3,48q,op 48q,op,48t,np 489,ps,4a7,pj 4aj,q4,48u,r5 48f,sq,49n,rn 48m,sn,4ag,ra 49b,st,47l,ql 4al,qp,49b,st 49r,j8,4b8,k9 4dt,kl,4b1,jt 49m,nn,4ae,lp 4b6,mo,4ad,l7 4b0,o6,4bj,ov 4a7,pj,4bc,om 4bj,ov,4aj,q4 49j,sr,4cf,qo 4ag,ra,4bl,qk 4bl,qk,4al,qp 4b8,k9,4c7,lt 4bc,om,4b6,mo 4c7,lt,4cp,nr 4br,nq,4d4,mc 4cp,nr,4bv,op 4bv,op,4br,nq 4cf,qo,4bs,p9 4d4,mc,4dt,kl #7k,2a cb,3p si,6q td,6i v5,4k u3,5v ul,5c 1ru,8j 292,b6 2ov,di 34f,m5 3i8,p9 43l,p5
Personlig rekord: 11 sek med firkanten. 12 med trucken.
-1i,1i,1i,1i 1i,1i,er,1j 86,1i,es,16 90,1j,ep,q 9s,1i,eq,d ae,1j,ep,-2 b2,1i,ep,-f bm,1g,et,-13 c5,1h,et,-1l cr,1j,ev,-2n d7,1i,es,-3m dh,1i,ep,-4j ep,-4j,et,-26 eo,-4k,fs,-4l et,-26,eq,1e n7,1m,er,15 er,1i,rd,1l h9,1a,fp,-4p fs,-4l,fr,1d in,1i,fn,-39 hu,1g,fo,-3u jd,1j,fv,-1k j5,1i,fq,-2h kd,1i,fu,-1 jv,1k,fu,-n lp,1l,fv,m hu,7,jo,1a rc,1l,109,1m re,1n,134,1b tg,1m,13i,13 u7,1l,13p,t uq,1l,13r,k vf,1n,143,7 100,1n,148,-i 10i,1n,14a,-17 10t,1u,149,-1d 11e,1p,149,-1m 149,-1m,144,1k 147,-1k,152,-1k 152,-1k,14s,1f 150,1d,156,-1k 156,-1k,15t,-1j 15t,-1j,15q,1a 15t,19,161,-1j 161,-1j,170,-1i 170,-1i,16p,15 16o,17,170,17 170,17,175,-1h 175,-2p,1gg,-2q 175,-1h,17u,-1g 17u,-1g,17m,16 17q,16,180,-1h 180,-1h,18r,-1g 18r,-1g,18i,6l 1ch,6l,19b,-1b 18r,-1d,19d,-1d 18n,-1f,1dd,-1f 1hs,93,1cr,-16 1hc,8u,1d0,-1f 1j8,8v,1cr,1a 1j0,8t,1cq,m 1ie,8v,1cp,2 1ks,94,1co,30 1k3,93,1co,22 1l9,8v,1cu,3s 1mn,94,1cs,5i 1ls,91,1cq,4m 1ph,91,1cs,7o 1oq,92,1cq,6q 1pd,93,1cp,93 1qr,93,1cq,8d 1gq,92,1dd,-1g 1nj,92,1di,6i 1gg,-2p,1tl,-2r 1pb,92,1qr,93 1tj,-2q,21c,-2u 1up,-2r,2b3,-3l 1vl,-2r,2b9,-47 20d,-2q,2b6,-4t 21a,-2r,2bt,-5o 227,-2v,2bi,-64 236,-2q,2br,-6o 245,-2q,2cb,-7f 257,-2r,2cn,-89 2ch,-2v,2al,-2q 2cn,-89,2ch,-2v 2h1,-9l,2ok,-9n 2ok,-9n,34b,-9n 34b,-9n,3gr,-9p 37q,6r,38g,59 38e,59,38n,4k 398,5m,38l,73 38l,73,38a,8m 37d,8m,37k,7a 37m,7c,37j,7r 37e,8k,37q,6r 37e,8n,37d,a2 37k,7s,37g,91 37j,7r,37c,9q 389,8i,387,9m 37e,a2,37g,bl 387,9m,386,9r 37g,bl,37l,db 37l,db,385,f4 385,f4,39n,h8 3aa,4i,398,5m 39n,h8,3bn,i3 3bq,3u,3aa,4i 3bn,i3,3dn,i8 3ft,3k,3da,3l 3d9,3m,3bq,3u 3dn,i7,3is,ib 3j8,3h,3ft,3k 3gr,-9p,3hq,-9r 3hq,-9r,3j8,-9r 3j8,-9r,3ku,-9m 3lh,3e,3j8,3h 3is,ib,3lr,ib 3ku,-9m,3mo,-9c 3jo,ib,3t9,ha 3ks,ib,3td,gk 3oo,2e,3mm,3a 3mm,3a,3li,3e 3lr,ib,3mj,i7 3m3,ib,3t9,i8 3lv,i9,3tf,ft 3ml,ib,3td,fg 3mo,-9c,3oe,-8p 3ng,ia,3te,en 3oe,-8p,3pr,-7p 3pr,-7p,3qv,-6g 3q6,1d,3oo,2e 3og,ib,3te,e1 3p5,ib,3tf,d3 3qg,-83,3r3,-7d 3r3,-7d,3ri,-6q 3qt,-6i,3r3,-61 3s1,-1g,3rc,3 3rc,3,3q6,1d 3pr,i9,3tf,c9 3qg,ia,3ti,b2 3r7,ia,3t9,ai 3ri,-6q,3rq,-68 3rq,-68,3s6,-55 3s5,-58,3s9,-4k 3se,-3k,3sa,-2i 3s9,-4k,3sb,-3j 3se,-30,3s1,-1g 3rl,i7,3t6,ad 3t6,ad,3tt,ac 3ts,ad,3v3,ad 42u,p0,3tj,fr 3tt,i1,3u2,p2 439,ou,3tu,jl 44u,p1,3u2,lc 442,p1,3u2,kk 48l,p3,3u2,n6 47g,p2,3u0,mi 46c,p5,3u4,lu 4b7,p2,3u5,oe 49o,p2,3u1,nq 3u2,p3,4b9,p1 403,gf,3uv,ah 43d,p0,3v8,gq 42o,ov,3vm,g7 425,p0,403,gf 444,p3,3vf,ii 457,p1,3vd,k9 44k,p3,3v6,j3 46f,p0,3um,l7 478,p2,40h,mq 492,p0,41a,nv 4as,p3,41t,ok 47t,gf,47r,jd 47p,gi,4ad,gc 47r,hr,49b,hl 49n,gn,49o,h3 49o,h3,4a1,h3 4a1,h3,4a1,gp 4a1,gp,49l,gl 49o,ha,49p,jc 4ab,jb,4a5,ha 4a5,ha,49l,ha 4ak,ha,4al,j0 4an,hc,4b3,j6 49p,jc,4ab,jb 4a6,kl,4dn,kj 4c9,j5,4c5,h5 4c5,h5,4bh,h5 4bj,g4,4bj,gn 4bj,gn,4c1,gn 4c1,gn,4c0,g8 4c0,g8,4bi,g6 4b8,hk,4b4,j5 4bl,h8,4bo,j7 4bo,j7,4c9,j5 4b6,p3,4jv,p4 4dh,ha,4d0,hb 4d0,hb,4co,hk 4co,hk,4co,hu 4co,hu,4ct,i5 4ct,i5,4d8,i6 4d8,i6,4dm,i9 4dm,i9,4dn,ih 4dn,ih,4dn,iq 4dn,iq,4df,is 4df,is,4d5,j3 4d5,j3,4cs,j3 4dl,ka,4dh,k7 4dh,k7,4dl,kn 4df,k5,4e3,kl 4dn,kj,4dn,l3 4e3,kl,4dk,l5 4eb,hb,4eb,j4 4ec,i4,4f1,i4 4f1,hj,4f0,iu 4jv,p4,4k4,lm 4k4,ln,4ke,lm 4k8,le,4ke,l1 4kp,kg,4lb,kr 4l8,l5,4l0,lm 4l0,lm,4kn,lm 4kr,lb,4l1,li 4lq,ml,4ll,mj #23,9 e5,-4n gl,-4b 132,-1u 387,6q 37v,c4 38s,f2 3i8,hd 3kb,44 3mb,gs 3pn,-8f 3po,27 3s3,a4 41e,i6 436,m1 473,o0 4aq,o9 4f1,ob 4f0,ob 4f0,ob
Personlig rekord: 22 sekunder med firkanten.
OPP og NED
Fin bane. Litt for kort bare :p
8.849 med firkant
OPP og NED
Tenket jeg skulle gjøre den lenger :p syntes den var litt kort selv :p
OPP og NED
Har forlenget den nå:p PRØV DEN!!!
Kjørtøy: Helikopter
-18 1i 18 1i,84 -7e 84 bg,f0 -3n f5 -2jq,h2 -1uf go -3o,es -9 eo 1ad,gv 17v gr -5,hd 6 1fe fq,1fa fq nf -11d,ne -172 h6 -1ug,13k -106 17c -2gu fa -2jo,t2 -m6 11o -q8 12l -q3 13i -po 13q -oh 13m -n7 13b -lj 130 -k4 12p -ii 12r -h6 139 -fu 143 -ev 14t -dq 159 -cd 158 -bb 155 -ac 14u -9i 14m -8p 14k -81 14j -7e 14i -6t 158 -6f 160 -6f 16s -6p 17l -7h 188 -8i 18s -9h 19k -at 1ad -c7 1b7 -dg 1ch -f6 1dk -gi 1ek -hi 1fj -ig,1g8 -km 1g2 -lp 1fu -mm 1fq -ng 1fm -oa 1fg -ov 1fc -pi 1f8 -q1,18k -q8 18a -q8 1f6 -q8,1j5 -11e 1je -12k 1jp -13v 1k3 -15e 1k8 -16n 1ka -17o 1k9 -18q 1k1 -19o 1jl -1ag 1j4 -1b4 1id -1bg 1hh -1bl 1gl -1bj 1fr -1b9 1f7 -1aq 1ep -1a0 1ei -199 1ef -18e 1eh -17e 1em -16g 1f1 -15j 1fe -14q 1g0 -13t 1gj -134 1h6 -12d 1i0 -11m 1ir -113,1nd -sk 1o1 -r9 1oe -pu 1om -os 1oe -o0 1o0 -n5 1n8 -mh 1mc -ma 1l4 -mg 1k4 -n0 1j7 -nf 1id -nv 1hk -of 1gu -ou 1gb -pc 1fs -po 1ff -q2,-3o -3e -9c u -7q 1i -bs 84,-3o -3e -4c 2q -5u 26 -9c 8o -bs 84,8e -i4 6i -ne 5k -mq k -tc -u -rq 42 -ls,8e -i4 34 -l8 42 -ls,bi 1s 92 4c 9m 4m 8o 68,bi 1s au 5a aa 50 9c 68 92 68 8o 5u,1f6 fk 130 7q 1ei e2 148 6i 1da bi 164 5a 1cc 9m 172 4c 1b4 76 180 3o 1a6 5a,ku -1aq ka -1fq jm -1f6 io -1hc,ku -1b4 i4 -1ei j2 -1es i4 -1h2 io -1hc,tm -16o ua -1cc so -1cc se -1kg,tm -16o pk -1c2 rq -1c2,rq -1cc rg -1k6 se -1kg,rq -1cc rq -1c2,1iu -114 1i3 -114 1h6 -114 1g3 -11e 1f0 -121 1dp -12p 1cf -13m 1ba -14g 1a7 -157 191 -14u 184 -14f 17a -13v 16j -13b 15t -12k 15b -120 14q -11e 14b -10v 13v -10i 13l -107,1nc -sn 1ur -ui,1j4 -11l 1io -119,1uk -ui 1ul -to 1uq -sf 1v0 -rc 1v6 -qa 1vf -p4 1vo -nv 202 -mv 20m -lp 21c -kp 22c -jo 23j -ii 24q -hf 261 -gf 27b -fl 28g -f0 29s -ef 2b2 -e5 2c6 -e5 2db -eb 2e8 -et 2eu -fn 2ff -gl 2fs -hf 2fu -io 2ft -ju 2fq -l0 2ff -m5 2f3 -n5 2ej -o9 2e1 -pd 2df -qf 2ct -rd 2c9 -sd 2bj -te 2b1 -ua 2ah -v3 2a3 -vo 29n -10a 29d -10q,29b -10s 2ai -11c 2bj -11o 2cj -123 2dl -12l 2el -13c 2fp -149 2h0 -15c 2i1 -16b,2i0 -16c 2ht -1ct,2ht -1d5 2ha -1su,2qc -1de 3cf -1d3 3cc -1e2 3c8 -1et 3c5 -1fq 3c0 -1gp 3bn -1hn 3bd -1if 3b3 -1j9 3ao -1k0,37r -1n8 375 -1nn 36d -1o2 35h -1o9 34m -1of 33u -1oi 336 -1ok 32g -1ol 31p -1ol 311 -1om 308 -1om 2vj -1om 2v1 -1om 2ua -1ol 2tk -1oj 2su -1oi 2sc -1oi 2rl -1og 2r0 -1oe 2qa -1oc 2pm -1oa 2ov -1o7 2o8 -1o6 2ni -1o4,352 -1m7 33t -1n4,34v -1m9 33g -1m9 33i -1ml 32n -1mq,33s -1n4 33n -1mr 32n -1n0 32l -1mr,3fu -1fs 3gk -1fr 3ha -1fq 3hu -1fn 3id -1f6 3ip -1eg 3j4 -1dm 3jd -1co 3jk -1bq,3jk -1bq 3jo -1as 3jq -19v 3jq -18q 3jp -17f 3jj -165 3j9 -14o 3ip -13i 3i2 -12n 3hc -122 3gj -11e 3fs -10h 3f8 -vf 3eo -u5 3eh -sr 3ec -rc 3ei -pq 3er -o5 3fd -mh 3g5 -kt 3h5 -jd 3ib -i2 3jo -gp 3l8 -fi 3mq -ef 3oe -di 3q0 -cq 3rd -ca 3sn -c2 3u2 -bv 3vk -bv 41a -c0 431 -c1 44p -c2 46g -c5 488 -c7 4a1 -c9 4br -cc 4dl -ce 4fe -ch 4gq -d3 4hu -dl 4ip -ed 4is -fb 4ie -g6 4hq -gs 4h5 -hh 4gb -i6 4fi -it 4ev -jq 4eh -kv 4e2 -m6 4dk -n6 4ct -o5 4cg -pa 4c6 -qo 4bm -rt 4b5 -sv 4ak -u2 49s -va 490 -10j 48a -11p 47j -133 472 -14d 46i -15p 46j -16u 472 -17u 47n -18r 48m -199 49t -19d 4b2 -19d 4c3 -19c 4d5 -19c 4e6 -19b 4f7 -19f 4gi -19p 4hs -1a5 4ja -1ak 4kr -1b4 4m4 -1bj 4nf -1c3 4oo -1cd 4q0 -1cg 4r5 -1ck 4rs -1cl,3fs -1fs 3c6 -1g0,3cg -1g1 3g3 -1fs,5ao -1db 5gc -1dc,3hi -1i7 3gk -1kr,3hg -1i4 3f7 -1k2,3f8 -1k2 3fm -1kd,3fm -1kh 3er -1lg 3fk -1m4 3g5 -1kn 3gg -1ks,4bq -d3 4cp -dg 4c0 -f6 4cj -fh 4ag -hn 4a9 -es 4b1 -f7 4bq -d5,483 -1ee 466 -1ee 466 -1d1 480 -1d1 480 -1c3 49g -1d2 482 -1fp 485 -1ec,5ga -1de 5io -1de,58b -1dh 52u -1de,52s -1dg 51d -1dg,589 -1dh 597 -1dj#-18 -5u 34 -26 3o -6i 76 -4c 34 -26,3o -6i 34 -5u 3e -5k 34 -5a 3e -50 2q -4c 3e -3o 2g -3e 34 -34 2g -2q 34 -2g,34 -5u 2q -5k 34 -5a 2g -50 34 -4m 26 -4m 2q -42 1s -42 2g -3e 1s -3e 2g -34,26 -4m 2g -4m 26 -4m,2g -4m 1s -50 1i -50 1s -4m 1s -4c 18 -3o,1i -50 u -4m u -50 18 -50,u -50 1i -5a 1i -5k,1i -5a 1s -5a 2g -4m,2q -42 2q -4m,3o -6i -u -4m -1i -4m,-u -4m -u -5k,-u -4m -1i -4c -1i -5u -1i -68 -18 -5u,-1i -5u -18 -5u,1s -42 1s -3o 26 -42 1s -4c 18 -4m,2q -5u 26 -5k,26 -5u 2g -5a 1s -5a,1s -4m 1s -4c,1i -4m 26 -4m,u -3e u -3o,26 -50 1i -5a 1i -50,1i -5a 18 -5a,1i -5a 1s -5a,26 -5a 26 -5k,1s -5k 1s -5a,18 -4c u -50 k -50 u -50,u -5a 18 -5a,1i -4m 26 -4c 2g -42,2q -3o 2q -42,4c -5k 42 -5a 4c -50 4m -5a 4c -5k,5u -3o 5a -3o 4m -42,-1i -5k -u -5k,-k -5a -1i -5a,-1i -50 -a -50,-18 -4m -18 -5u,-u -5a -u -4m,-k -5a -k -50#T 586 -1f3,T 58j -1g3,T 58j -1e8,T 587 -1e7,T 58c -1e7,T 58b -1e7,T 57v -1e7,T 57q -1e7,T 584 -1f1,T 584 -1f1,T 57s -1f5,T 57q -1f1,T 57g -1f0,T 57e -1e2,T 58e -1fv,T 58e -1g1,T 587 -1fv,T 581 -1g3,T 57q -1fu,T 57q -1fu,T 57i -1fv,T 57e -1ec,T 57e -1ei,T 57d -1ec,T 57d -1es,T 57d -1f5,T 57b -1fa,T 57b -1fk,T 57b -1fi,T 579 -1fq,T 579 -1fv,T 579 -1g1,T 561 -1fv,T 561 -1fq,T 561 -1fn,T 563 -1fb,T 563 -1f0,T 563 -1en,T 565 -1e7,T 565 -1e3,T 565 -1ed,T 565 -1em,T 565 -1em,T 563 -1f3,T 563 -1f8,T 561 -1fk,T 561 -1fl,T 560 -1g3,T 55u -1f6,T 55k -1f6,T 55d -1f6,T 558 -1f8,T 550 -1ea,T 550 -1e3,T 54u -1ea,T 54t -1ep,T 54p -1ff,T 54r -1fp,T 54u -1fn,T 54t -1f0,T 54t -1f5,T 54r -1fi,T 54r -1g1,T 52v -1dr,T 52v -1e7,T 52t -1ed,T 52t -1ek,T 52s -1ep,T 52s -1f1,T 52s -1f6,T 52s -1fg,T 52q -1fp,T 52q -1g1,T 542 -1g4,T 53r -1g4,T 53g -1g6,T 53b -1g6,T 532 -1g8,T 52s -1g8,T 52g -1g8,T 52e -1g8,T 523 -1gb,T 51n -1g8,T 536 -1dm,T 53r -1dm,T 54r -1do,T 55f -1do,T 55u -1dm,T 579 -1dp,T 586 -1dp,T 58v -1dp,T 58t -1dp,T 58o -1dp,T 58h -1dp,T 58c -1dm,T 57s -1do,T 57o -1dp,T 57j -1dp,T 56v -1dp,T 56n -1dr,T 56b -1do,T 55n -1do,T 558 -1do,T 553 -1do,T 54h -1dk,T 544 -1do,T 53h -1do,T 53e -1do,T 52s -1dp,T 52j -1dr,T 52g -1dr,T 523 -1dr,T 51s -1dr,T 51k -1dr,T 51d -1dt,T 5f2 -1gb,T 5f2 -1gj,T 5g3 -1eh,T 5g0 -1ed,T 5g6 -1ea,T 5gd -1e7,T 5gf -1e7,T 5gp -1e7,T 5gp -1ec,T 5gs -1ef,T 5gs -1em,T 5gv -1em,T 5gv -1er,T 5gv -1f0,T 5gv -1f3,T 5gu -1fa,T 5gu -1fb,T 5gu -1fd,T 5gs -1fk,T 5h3 -1fn,T 5h6 -1g4,T 5h4 -1gd,T 5h3 -1gg,T 5gq -1go,T 5gk -1gs,T 5gg -1gv,T 5gd -1gv,T 5g3 -1gt,T 5g6 -1gv,T 5g6 -1gt,T 5g5 -1go,T 5g5 -1gj,T 5g5 -1gj,T 5g3 -1gb,T 5g3 -1g8,T 5g8 -1g8,T 5g6 -1g3,T 5g5 -1fs,T 5g3 -1fp,T 5g3 -1fl,T 5g3 -1fl,T 5g3 -1fg,T 5fu -1f5,T 5fu -1f1,T 5fu -1eu,T 5fs -1er,T 5fr -1ek,T 5fr -1ek,T 5fr -1ei,T 5fr -1ef,T 5fn -1ec,T 5fn -1ec,T 5gg -1dr,T 5gk -1do,T 5h6 -1dk,T 5h8 -1dm,T 5hd -1do,T 5hv -1do,T 5ij -1dm,T 5ij -1dm,T 5ic -1dm,T 5i6 -1dm,T 5i4 -1dm,T 5hn -1do,T 5hl -1do,T 5he -1do,T 5h9 -1do,T 5h1 -1dk,T 5h1 -1dk,T 5gv -1dm,T 5gi -1dm,T 5gk -1dm,T 5gg -1dm,T 5f3 -1h2,T 5f2 -1gv,T 5f0 -1gq,T 5f0 -1gj,T 5f0 -1g3,T 5f0 -1fv,T 5et -1ff,T 5er -1f8,T 5ep -1f1,T 5ek -1ei,T 5ej -1e8,T 5ee -1ec,T 5ee -1ec,T 5ee -1ed,T 5ec -1ek,T 5ea -1eu,T 5e9 -1f5,T 5e7 -1fg,T 5e5 -1fs,T 5e4 -1g6,T 5e2 -1gd,T 5e2 -1gn,T 5e2 -1gt,T 5dj -1f1,T 5de -1f0,T 5dl -1fa,T 5dr -1gv,T 5dr -1gn,T 5dq -1gb,T 5dq -1gb,T 5dq -1g6,T 5do -1fl,T 5do -1fg,T 5do -1fg,T 5dh -1ek,T 5dg -1eh,T 5de -1ed,T 5db -1e3,T 5cj -1ed,T 5cd -1ed,T 5c8 -1ea,T 5c3 -1ea,T 5bu -1ea,T 5bq -1ea,T 5bp -1ea,T 5ba -1ea,T 5cd -1fp,T 5c9 -1fp,T 5bu -1fp,T 5bq -1fp,T 5bn -1fl,T 5b8 -1fl,T 5b6 -1fl,T 5c6 -1gt,T 5c3 -1gt,T 5bv -1gt,T 5bs -1gt,T 5bp -1gq,T 5bf -1gn,T 5b5 -1gn,T 5b3 -1gn,T 5ar -1gj,T 5au -1go,T 5au -1gg,T 5b0 -1g9,T 5au -1g4,T 5au -1g3,T 5au -1g3,T 5as -1fv,T 5as -1fn,T 5b3 -1du,T 5b3 -1du,T 5b1 -1e7,T 5b0 -1ec,T 5b0 -1ed,T 5b0 -1ef,T 5b0 -1ei,T 5b0 -1ek,T 5b0 -1er,T 5b0 -1f0,T 5b0 -1f1,T 5b1 -1fa,T 5b1 -1fd,T 5b1 -1fi,T 5fa -1dp,T 5fa -1dp,T 5fr -1dp,T 5fr -1dp,T 5fm -1dp,T 5fc -1dp,T 5f2 -1dr,T 5eh -1dr,T 5dv -1dr,T 5d1 -1dk,T 5d1 -1dk,T 5c4 -1do,T 5c3 -1do,T 5cb -1do,T 5cg -1do,T 5ct -1do,T 5d4 -1do,T 5d7 -1do,T 5d9 -1do,T 5dh -1do,T 5dq -1do,T 5e2 -1do,T 5e5 -1do,T 5ef -1do,T 5er -1dp,T 5f0 -1dp,T 5f5 -1dp,T 5fn -1dm,T 5g1 -1dm,T 5ga -1dm,T 5g8 -1dm,T 5fu -1do,T 5fu -1do,T 5ff -1dt,T 5fa -1dt,T 5eu -1dp,T 5er -1dp,T 5eh -1dp,T 5e7 -1dj,T 5e0 -1dj,T 5dq -1dk,T 5d4 -1do,T 5d2 -1do,T 5cn -1do,T 5ce -1do,T 5c8 -1do,T 5bn -1do,T 5bk -1dk,T 5ba -1dk,T 5au -1dk,T 5au -1dk,T 5au -1dk,T 5b1 -1dk,T 5b5 -1dk,T 5b5 -1dk,T 5b8 -1dm,T 5b8 -1dm,T 5b8 -1dm,T 5ba -1dm,T 5bk -1dm,T 5bn -1dm,T 5bu -1dm,T 5c3 -1dm,T 5c8 -1dm,T 5cg -1dm,T 5cq -1do,T 5d9 -1do,T 5dm -1do,T 5e0 -1do,T 5ea -1do,T 5ej -1do,T 5f0 -1do,T 5fc -1do,T 5fm -1dp,T 5fs -1do,T 5g6 -1dm,T 3os -sn,T 3p6 -o9,T 3ne -nd,T 3n2 -pp,T 3kq -uc,T 3pk -14s,T 3ls -13r,T 40o -16g,T 3tf -14u,T 3p1 -12e,T 3un -12v,T 3ql -17c,T 3o7 -17e,T 3rv -ra,T 3vj -mf,T 47a -cu,T 3ul -cp,T 3l3 -h0,T 32j -1jq,T 38o -1dq,T 30j -1fe,T 2ug -1fn,T 2sj -1g8,T 2qe -1gh,T 2n0 -1h8,T 2ke -1i8,T 2ke -1kv,T 2ke -1ob,T 2ke -1qd,T 256 -po,T 26c -pr,T 273 -pr,T 256 -ou,T 263 -p1,T 26o -od,T 25i -qc,T 1jp -pb,T 1jp -pj,T 1jr -pq,T 1jt -pv,T 1jt -q4,T 1bo -qs,T ne -122,T fk -1s,T 84 -7g,T 84 -7q,T 84 -84,T 84 -8e,T 84 -8o,T 84 -92,T 84 -9c,T 84 -9m,T 84 -a0,T 84 -ak,T 84 -aa,T 84 -au,T 84 -b8,T 84 -bi,T 84 -bs,T 84 -c6,T 84 -cg,T 84 -cq,T fk -1i,T fk -26,T 84 -d4,T 84 -de,T 84 -do,T 84 -e2,T 84 -ec,T 84 -em,T 84 -f0,T 84 -fa,T 84 -fk
Endret av krassi
-18 1i 18 1i,16 1k 29 1m 3e 20 4k 2g 5l 33 6k 3o 7j 4e 8c 50 98 5j 9s 5s ag 64 b6 6a bv 6g cp 6k dm 6o ej 6p fi 6o ge 6l ha 6f i4 66 is 5u jn 5m ks 5k m1 5i,j1 6b ke 68 lv 6d n9 6r oo 7b q8 7s,2u 2g 1t 2b,jn 5j kb 5a kv 4n lh 41 m0 3e,hr 69 j5 5k kj 4o lk 3q m9 2v nl 2v,lk 3r m5 3p,nl 30 o8 39 p0 3q ps 4g qr 53,qr 52 u5 59 us 57 131 bh,us 57 u6 3s,vu 6q uq 3l,11i 96 10i 7u,1av 9f 1aq 9e,1at b7 1ng fo,1rs gc 1uk g3,1ug fv 1uk g1,1uk g4 209 fm 222 f0 23e dm 249 c3 24l ab,29s g5 2bb gi 2d6 gp 2i1 gp 2k8 gn,24k aa 257 aa 25i bp 26d df 282 f5,281 f5 29t g5,s8 47 s9 5r,sl 43 t8 5k,qv 3v r5 55,re 41 ri 5g,ri 47 rv 5b,sc 4d sv 67,t3 3q tp 6j,u8 4r v3 75,va 3u 10p 6r,10e 49 125 63,111 41 13g 69,v8 4s 107 7d,ve 4h 10t 7a,10v 4p 11s 70,10l 4q 11k 91,10f 57 10e 7e,su 3e r7 8g,qh 3q qk 50,qa 3f q5 62,q0 4g qe 6j,s8 4u t5 5e,t6 4v ui 4n v4 6v,ua 4b uc 5f,u1 4e u1 5g,tk 4f uh 8f,ud 4h 10b 76,10t 5d 11d 7f,vr 43 12j 5u,10t 3r 13a 5v,u5 41 v9 8a,ua 41 vm 67,vn 42 10l 5u,106 3e 10i 75,q6 3c pm 55,ra 4c sl 5j,sn 47 tj 74,th 3p ul 6b,uj 51 vg 77,ve 5h v5 8g,t8 68 sh 85,sf 5i 103 73,11g 68 11f 6b,11t 36 12h 35 139 38 142 3e 14r 3m 15j 3u 16a 47 171 4i 17p 4u 18f 59 193 5l 19n 61 1a9 6b 1b2 6o 1c2 73 1d7 7e 1ek 81 1fs 8n 1h8 9f 1in aa 1k9 b6 1lt c5 1nj d5 1pg e4 1r3 en 1sq f9 1uk fo 20h g6,2k4 go 2kq gm 2lk gk 2md gg 2n6 g9 2ns fv 2ol fi 2pj f4 2qo em 2sb e8 2tu e0 2vp dv 31s e5 33j ed 35f eo 37l f5 39u fg 3cc fn 3es fq 3he fm 3k1 fe 3mm f0 3pf eh 3sb e1 3vc dj 42h da 45n d8 48u dd 4c7 dp 4fh eb,4fg eb 4ge ee 4hc eb 4i7 e2 4j1 dl 4jm d5 4k7 cb 4kk ba 4kv a5 4lb 8r 4lo 7c#54 h 5p 6v,57 48 77 2p,71 d 7b 6d,7c v 8a 6j,8a 6j 9d 2u,8q 32 9e 6s,9e 6s as 4#
Hele 434 stjerner, kun for å få forbedret helikopter-kontroll. Banen er ikke vanskelig, og typiske "hull" er av rimelig størrelse i forhold til helikopteret. Hadde en "tettere" versjon med mindre hull og enda flere stjerner, men jeg fant ut at den ble litt for vanskelig egentlig. Man kom seg gjennom alle hullene, men ikke mer enn én gang per runde. He-he. Klarte aldri den banen, selv om jeg fikk tak i alle stjernene i løpet av flere runder.
Her er banen:
-18 1i 18 1i,16 1g 18 -db,16 -db 1h -1v1,-16 1i -3dv f,-sr 16 -te o -u6 3 -ul -n -uh -1h -tr -26 -ss -2b -ro -26 -qi -23 -pf -24 -oa -2i -ng -39 -n0 -44 -mu -53 -ni -5v -oi -6g -pk -6o -qn -71 -s3 -7d -tk -81 -us -8p -vn -9l -vl -ao -ur -bj -ts -c7 -so -ci -rf -cn -qd -ct -p8 -d6 -o7 -dl -nf -en -ms -g3 -mk -hl -mp -iv -nd -k9 -o8 -la -p6 -m7 -q9 -nf -r7 -om -s2 -q4 -si -rn -sr -td -t0 -v5 -sv -110,-so -12s -sb -14p -rq -16o -r7 -18p -qp -1ac -qb -1c0 -q0 -1dm -pn -1fe -ph -1h6 -pe -1iu -pf -1kn -pj -1mg -pq -1o9 -q4 -1q3 -qj -1ru -r2 -1tq -ri -1vn -s2 -21k,-s2 -21k -si -23i -t0 -25i -t7 -27i -ta -29i -tb -2bj -t8 -2dj -sv -2fh -si -2hd -s2 -2j7 -rf -2kv -qn -2ml -pt -2od -p1 -2q5 -o6 -2rv -na -2ts -mh -2vq -lu -31r -li -33t -lb -35u -l9 -380 -la -3a2 -lf -3c4 -lp -3e6 -m8 -3g8 -ms -3ia -nj -3kc -oc -3mf -p5 -3ok -ps -3qt -qg -3t8 -r2 -3vm -rh -424 -rt -44j -s4 -473 -s4 -49h -ru -4bu -rk -4ea -r6 -4gj -qm -4iq -q3 -4kt -pe -4ms -on -4ok -nv -4q8 -n5 -4rp -m9 -4t9 -lc -4un -kc -503 -jb -51e -i9 -52n -h7 -53u -fp -55g -eb -56v -cr -58d -bb -59o -9p -5b2 -86 -5cb -6i -5dj -4v -5eq -3b -5g2 -1o -5h9 -4 -5id 1l -5j6 3h -5jo 5d -5k7 7c -5kl 9b -5l1 bb -5lc db -5lj fc -5ln he -5lr ji -5lv ln -5m2 nr -5m5 q0 -5m7 s4 -5ma ua -5mc vv -5md 11m -5me 13d -5me 153 -5me 16q -5mf 18h -5mf 1a8 -5me 1c0 -5me 1do -5md 1fg -5mc 1h9 -5mb 1j1 -5ma 1kp -5m9 1mi -5m8 1oa -5m6 1q3 -5m5 1rt -5m4 1tm -5m4 1vg -5m4 21a -5m4 233 -5m4 24t -5m4 26n -5m4 28h -5m4 2ab -5m4 2c5 -5m3,-o2 -dq -la -dp,-hd -dq 15 -dn,18 -q2 -4u -i6,-cj -qf -83 -123,17 -q3 -1u -123,-89 -13m -cn -1ef,-cn -1eg 17 -29g,1e -1v1 1g -2ae v -28u,-8a -13m -83 -139,-sp -12v -sr -129 -st -11l -sv -112,-ci -qh -8h -ib,-5h -11v -4v -11v,-55 -11v -89 -11t,-cn -1ej -hf -1em,-ks -1en -pt -1el,-op -22g -of -21r -o7 -214 -o0 -20c -np -1vl -ni -1uu -nb -1u6 -n6 -1tf -n0 -1sn -mo -1rt -mh -1r3 -m9 -1q5 -m1 -1p6 -lq -1oa -lk -1nd -ld -1mi -l7 -1lk -l0 -1ko -kr -1jt -km -1it,-f9 -1l2 -fd -1lt -fh -1mq -fl -1no -fo -1oo -fr -1pn -fs -1qn -fm -1s2 -fd -1te -f1 -1v2 -em -20g -e9 -21v -dr -23h##T 3i o,T 4j 6,T 54 4,T 6k b,T 7k 1r,T 7f 41,T 5e 54,T 3n 5l,T 2n 85,T 2p 98,T 4q bh,T 8s ao,T b0 8p,T br 5o,T c8 1h,T ca -2e,T c5 -4m,T bm -61,T ao -7g,T 8q -9h,T 75 -bl,T 6f -f3,T 6f -gl,T 9e -jc,T d1 -mg,T ds -pa,T e6 -rl,T ci -us,T ao -10q,T 9j -14n,T 94 -177,T 94 -198,T aj -1aj,T e9 -1br,T gm -1cu,T hn -1el,T hi -1gh,T h3 -1if,T f4 -1kg,T bu -1mm,T 9l -1os,T 8v -1s5,T ao -1ue,T bk -20f,T c3 -22g,T bu -24m,T b5 -268,T 8q -28j,T 4g -2b0,T 3v -2db,T 6p -2hg,T 86 -2j2,T 96 -2jc,T et -2i4,T h5 -2h1,T ke -2fr,T o6 -2f0,T sd -2er,T 11g -2f5,T 13t -2fc,T 15k -2fc,T 18r -2fa,T 1dm -2fa,T 1g3 -2fa,T 1i7 -2fa,T 1ln -2eo,T 1pp -2em,T 1up -2fa,T 21t -2fh,T 24g -2k7,T 22u -2oc,T 1vl -2or,T 1pu -2pk,T 1n7 -2qa,T 1li -2qi,T 1gs -2qs,T 1c1 -2r1,T 168 -2r1,T 113 -2r3,T ss -2rd,T qp -2rs,T mk -2s6,T jl -2t4,T hk -2uf,T g0 -31e,T fo -32r,T je -343,T pr -34p,T 10f -35d,T 140 -369,T 171 -37t,T 176 -3a6,T 15p -3df,T 121 -3gg,T tt -3i2,T og -3iu,T jb -3kn,T f9 -3mr,T bk -3op,T 9h -3qe,T 6n -3rr,T 3l -3vb,T 1d -431,T -10 -47a,T -3i -4c5,T -6c -4ga,T -j2 -4kn,T -hu -4kp,T -ef -4nq,T -de -4oc,T -de -4n2,T -c4 -4i4,T -ge -4gd,T -e3 -4jf,T -8a -4jn,T -3n -4ir,T -9k -4mu,T -be -4o0,T -du -4kf,T -g5 -4kk,T -h2 -4mr,T -gi -4q6,T -dn -4s6,T -93 -4qe,T -7t -4ok,T -64 -4pp,T -74 -4rs,T -8c -4ta,T -an -4uc,T -ek -4u6,T -h9 -4t4,T -j5 -4r8,T -kh -4oi,T -lv -4md,T -f3 -28u,T -f8 -28u,T -fg -28t,T -fp -28t,T -g1 -28t,T -g7 -28t,T -gp -28t,T -h6 -28r,T -ho -29c,T -h6 -29c,T -gm -296,T -gm -28u,T -gl -28r,T -gl -28a,T -gl -27u,T -gl -27f,T -gl -277,T -gl -26u,T -gj -26p,T -gj -26l,T -gj -26e,T -gj -26a,T -gj -264,T -gj -25s,T -gi -25p,T -gi -25k,T -gi -25h,T -gi -25b,T -gi -256,T -gi -256,T -gi -258,T -gj -25a,T -gj -25e,T -gj -25k,T -gj -25q,T -gj -261,T -gj -268,T -gj -26m,T -gj -26s,T -gj -272,T -gj -279,T -gj -27d,T -gj -27i,T -gj -27m,T -gl -27r,T -gl -27u,T -gl -284,T -gl -287,T -gl -289,T -gl -28c,T -gl -28h,T -gl -28n,T -gd -29i,T -g8 -29i,T -g7 -29c,T -ga -29e,T -ga -29v,T -g8 -2a2,T -g4 -29p,T -g2 -29b,T -g1 -29b,T -fn -299,T -fg -299,T -fg -29c,T -fj -29f,T -fq -29p,T -g1 -2a0,T -gd -2aa,T -gd -2aa,T -gm -29n,T -go -29k,T -gv -29c,T -gi -29e,T -gj -29e,T -h7 -29b,T -hf -299,T -hd -29e,T -h9 -29m,T -gs -2a2,T -gj -2a8,T -gj -2a6,T -go -2a0,T -h4 -299,T -h4 -296,T -ha -296,T -hr -292,T -i3 -299,T -hr -29m,T -hi -2a0,T -h6 -2ad,T -gs -2aj,T -gg -2ap,T -g8 -2aj,T -g1 -2ad,T -fq -2a5,T -fj -29s,T -f8 -29e,T -f0 -293,T -fg -290,T -g5 -292,T -gr -292,T -hi -28t,T -i4 -292,T -ho -29f,T -h9 -2a3,T -gl -2ap,T -gl -29t,T -gl -293,T -gj -284,T -gj -27d,T -gj -26p,T -gj -264,T -gj -25a,T -c7 -22o,T -d4 -224,T -dc -214,T -dq -1vu,T -dq -1uh,T -dq -1ta,T -dq -1rv,T -dq -1qd,T -di -1of,T -df -1n6,T -d7 -1le,T -hm -1kv,T -i1 -1lk,T -if -1ml,T -io -1nf,T -j6 -1on,T -jh -1pm,T -jv -1qp,T -ke -1ru,T -kp -1sr,T -lb -1u5,T -lo -1vj,T -ma -20v,T -mg -223,T -pv -21i,T -pj -207,T -p9 -1v3,T -p5 -1u0,T -ot -1t4,T -ol -1s1,T -oe -1qs,T -o8 -1pp,T -nu -1o7,T -nn -1n1,T -ng -1lp,T -nc -1kn,T -n4 -1jo,T -n0 -1id,T -i7 -1ir,T -ga -1i9,T -i7 -1hm,G -j8 -1el 5k,T -f0 -1jg,T -ge -1jl,T -jq -1hk,T -hm -1ge,T -km -1ge,T -jh -1fi,T -c3 -1im,T -e9 -1i0,T -gk -1h9,T -r1 -12g,T -q3 -12g,T -ou -12g,T -mv -12e,T -nq -12e,T -m6 -12g,T -ku -12h,T -jm -12h,T -ij -12j,T -hg -12j,T -ga -12m,T -fd -12m,T -e9 -12m,T -d9 -12m,T -c4 -12m,T -b3 -12m,T -a2 -12r,T -94 -12q,T -86 -180,T -6a -180,T -3l -182,T -1b -182,T b -1a8,T -2b -1ab,T -53 -1af,T -7l -1af,T -9h -1ai,T 7 -127,T -u -124,T -7s -12o,T -4u -oh,T -4k -ol,T -5i -ol,T -6l -om,T -7e -oq,T -6e -ob,T -63 -oe,T -6s -oq,T -5p -mq,T -4a -ms,T -51 -mk,T -4f -mk,T -3p -mi,T -3r -kr,T -53 -kr,T -72 -l7,T -79 -ln,T -7e -lp,T -58 -kr,T -6e -l7,T -7j -ma,T -89 -ne,T -7l -n8,T -79 -mb,T -6v -m3,T -53 -lm,T -5u -ls,T -6b -ls,T -4f -lr,T -55 -lp,T -56 -lu,T -5b -lr,T -6o -ms,T -72 -n9,T -5g -n8,T -3p -ms,T -3c -n9,T -39 -nt,T -3h -o4,T -4a -o4,T -5g -o4,T -7m -o2,T -89 -o1,T -92 -nv,T -90 -nn,T -8t -n8,T -8h -mk,T -8a -m6,T -84 -lf,T -7q -l3,T -7c -kj,T -72 -kc,T -69 -ka,T -5l -kc,T -4r -ke,T -45 -kj,T -3k -ku,T -34 -lh,T -2q -m1,T -2g -mk,T -24 -nd,T -1o -o4,T -1e -oo,T -35 -oq,T -4m -oq,T -66 -oq,T -90 -oo,T -7j -oo,T -if -dn,T -ih -dn,T -ja -do,T -jh -dn,T -ik -di,T -ja -dj,T -k1 -dj,T -jf -dj,T -jr -dl,T -ka -dl,T -j2 -dl,T -j3 -dn,T -jc -dn,T -ki -dn,T -kb -dl,T -ji -dl,T -j3 -dl,T -it -dl,T -ie -dl,T -i0 -dl,T -i2 -dl,T -ie -dn,T -j3 -dn,T -ji -do,T -jr -do,T -k5 -ds,T -ju -dt,T -j5 -do,T -ht -dj,T -im -dl,T -jm -dq,T -kf -do,T -uu -a9,T -nc -78,T -mc -62,T -m7 -4j,T -mq -34,T -no -2d,T -tu -12
Er vel for det meste bil :p
Endret av MrUrge
