Atheros AR5007EG Wireless
Har dette trådløsenettverkskortet og driverne vil ikke fungere.
Har prøvd enhetsbehandling, har avinstallert og prøvd flere forskjellige metoder.
Har forøvrig byttet til Windows XP. Noen som har noen tips å hjelpe meg med? Er flere komponenter i enhetsbehandling som har (!) forran seg.
Hjelp taes imot med takk!
The XP Drivers are on Acer PanAm website:
http://www.acerpanam.com/flex/acerdrivers/...FTOKEN=56207662
If you do a clean XP install from formatted hard drive, a standard XP install disk will not recognize the controller: you also need SATA drivers for F6 install from Intel download site.
Apart from that, all is straightforward: the proof is that I am writing this on an Aspire 5720 running XP! Good Luck.
Comment by jakey_too, posted on Nov 28, 2007
Eirikg,
What drivers do not work?
The only problem I had was with the webcam drivers: there are several on the Acer PanAm site but I did not use any of them; I ended up using generic Microsoft driver instead.
You can get the chipset drivers and SATA drivers for F6 Windows XP install from the Intel download site.
Although I did not need to on the Aspire 5720, I also use driver detective from http://www.drivershq.com. You can identify what drivers you have and what you need also source any missing ones..
Good Luck...
