rocknrolf77 Skrevet 8. desember 2007 Del Skrevet 8. desember 2007 (endret) Har fglrx 7-11 (Nyeste installert) men får ikke direct rendering. Har nvidia kort selv, så jeg har ikke peiling på å få ati til å virke. Noen som finner noen feil i xorg.conf. Ubuntu 7.10 er distroen og jeg installerte den nyeste ati driveren med envy. Kortet er ett radeon 9800 pro. # xorg.conf (xorg X Window System server configuration file) # # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the xorg.conf manual page. # (Type "man xorg.conf" at the shell prompt.) # # This file is automatically updated on xserver-xorg package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xorg # package. # # If you have edited this file but would like it to be automatically updated # again, run the following command: # sudo dpkg-reconfigure -phigh xserver-xorg Section "Files" EndSection Section "InputDevice" Identifier "Generic Keyboard" Driver "kbd" Option "CoreKeyboard" Option "XkbRules" "xorg" Option "XkbModel" "pc105" Option "XkbLayout" "no" Option "XkbOptions" "lv3:ralt_switch" EndSection Section "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" Option "Device" "/dev/input/mice" Option "Protocol" "ImPS/2" Option "ZAxisMapping" "4 5" Option "Emulate3Buttons" "true" EndSection Section "InputDevice" Driver "wacom" Identifier "stylus" Option "Device" "/dev/input/wacom" Option "Type" "stylus" Option "ForceDevice" "ISDV4"# Tablet PC ONLY EndSection Section "InputDevice" Driver "wacom" Identifier "eraser" Option "Device" "/dev/input/wacom" Option "Type" "eraser" Option "ForceDevice" "ISDV4"# Tablet PC ONLY EndSection Section "InputDevice" Driver "wacom" Identifier "cursor" Option "Device" "/dev/input/wacom" Option "Type" "cursor" Option "ForceDevice" "ISDV4"# Tablet PC ONLY EndSection Section "Device" Identifier "ATI Technologies Inc Radeon R350 [Radeon 9800 Pro]" Driver "fglrx" Busid "PCI:1:0:0" Option "VideoOverlay" "on" Option "OpenGLOverlay" "off" EndSection Section "Monitor" Identifier "HU196D" Option "DPMS" Horizsync 30-70 Vertrefresh 50-160 EndSection Section "Screen" Identifier "Default Screen" Device "ATI Technologies Inc Radeon R350 [Radeon 9800 Pro]" Monitor "HU196D" Defaultdepth 24 SubSection "Display" Modes "1280x1024" "1024x768" "800x600" "640x480" EndSubSection EndSection Section "ServerLayout" Identifier "Default Layout" screen "Default Screen" Inputdevice "Generic Keyboard" Inputdevice "Configured Mouse" # Uncomment if you have a wacom tablet # InputDevice "stylus" "SendCoreEvents" # InputDevice "cursor" "SendCoreEvents" # InputDevice "eraser" "SendCoreEvents" EndSection Section "Module" Load "glx" EndSection Section "Extensions" Option "Composite" "Enable" EndSection Edit : Output fra fglrxinfo display: :0.0 screen: 0 OpenGL vendor string: Mesa project: www.mesa3d.org OpenGL renderer string: Mesa GLX Indirect OpenGL version string: 1.4 (2.1 Mesa 7.0.1) Endret 8. desember 2007 av rocknrolf77 Lenke til kommentar
humbuq Skrevet 8. desember 2007 Del Skrevet 8. desember 2007 (endret) Du må laste dri-modulen dersom du vil ha dri. Legg til Load "dri" i Module-seksjonen din. Endret 8. desember 2007 av humbuq Lenke til kommentar
rocknrolf77 Skrevet 8. desember 2007 Forfatter Del Skrevet 8. desember 2007 Fortsatt ingen direct rendering med dri i modules Noe annet som kan være feil..... Aner ikke hva som mangler her. Lenke til kommentar
Sokkalf™ Skrevet 8. desember 2007 Del Skrevet 8. desember 2007 Hmm, prøv å legge til dette i bånn av xorg.conf : Section "DRI" Mode 0666 EndSection Lenke til kommentar
BarteBaluba Skrevet 8. desember 2007 Del Skrevet 8. desember 2007 Section "Extensions" Option "Composite" "Enable" EndSection Gjør du om til Section "Extensions" Option "Composite" "Disable" EndSection Lenke til kommentar
NevroMance Skrevet 9. desember 2007 Del Skrevet 9. desember 2007 (endret) Glem det, tenkte aiglx, ikke vanlig direct rendering Endret 9. desember 2007 av NevroMance Lenke til kommentar
Teroedni Skrevet 9. desember 2007 Del Skrevet 9. desember 2007 Last ned driverene fra Amd.com og prøv å instaler dem. Viss ikkje det funker kan du bruke den samme driverfila til å lage deb pakker som du kan prøve med, og det bør funke viss du instalerer dem i rett rekkefølge Men prøv den vanlege installasjonen først og se om det funker. http://ati.amd.com/support/drivers/linux/linux-radeon.html Lenke til kommentar
rocknrolf77 Skrevet 9. desember 2007 Forfatter Del Skrevet 9. desember 2007 Glem det, tenkte aiglx, ikke vanlig direct rendering Skulle gjerne hatt aiglx å, siden de 2 siste ati driver'ne "støtter" det. Envy laster driveren ned fra ati/amd's sider og installerer den. Får ikke testa noe av dette før jeg skal dit hvor den maskina er igjen. Men takk for svar, skal prøve når jeg stikker dit igjen. Lenke til kommentar
NevroMance Skrevet 10. desember 2007 Del Skrevet 10. desember 2007 Ok. Nå skal AIGLX støtten i de nye driverne være elendige da, så hvor mye nytte du får ut av de vet jeg ikke. Men for å få AIGLX må du vel ha Composite "Enable" så vidt jeg vet(?) Lenke til kommentar
olear Skrevet 10. desember 2007 Del Skrevet 10. desember 2007 AIGLX startes automatisk hvis man har DRI. Lenke til kommentar
