Kultom Skrevet 7. februar 2003 Del Skrevet 7. februar 2003 hvilken stepping er best til 2400? og high end low end, hva er forskjellen?? Lenke til kommentar
Vidder Skrevet 10. februar 2003 Del Skrevet 10. februar 2003 http://www.overclockers.com/tips00173/ Two Kinds of TBredBs There are high-end and low-end TBredBs. They aren't all the same. The high-end ones on average perform several hundred MHz better than the low-end ones. You can identify which type of TBredB it is by looking at code that begins the second line of coding on the processor. If you see a code like "AIUHB" that begins with the letter "A," that's a high-end TBredB. If you see a code like "JIUCB" that begins with the letter "J," that's a low-end TBredB. 2400+ Sorry, no exciting choices here (yet). They're all TBredBs, and they'll have an order code of AXDA2400DKV3C. Yes, the DKV part is the same as for the 2200+. That's because a TBredA runs at 1.65V (that's what the "K" stands for) at 2200+. A TBredB runs at 1.6V (that's what the "U" stands for) at 2200+ and 1.65V at 2400+ and above. As of now (1/15/03), all sightings of the 2400+ and faster CPUs have been high-end TBredBs. Lenke til kommentar
