nVidias kommende lanseringer, hva vet vi?
WheelMan
Så 9600gt vil være noe svakere enn dagens 8800gt men enda billigere?
Mens 9800gx2 vil være mye bedre en dagens beste kort og sikkert koste deretter...
Savner på en måte et kort midt i mellom der jeg da. En 9800"gt" til rundt 2000kr kanskje? Hadde passet meg ypperlig nå som AoC snart slippes. Jeg tviler ikke på at noe slikt dukker opp men er redd for at de tradisjonen tro venter med å slippe slike kort til storebror gtx har fått solgt fra seg. Surt for sånne som meg som gjerne vil ha et ordentlig mellomklasse kort. Bang for the buck ikke sant :)
edit: Oi jeg arresterer meg selv;
"The GeForce 9800 GT should appear in the March / April timeframe. We have limited information on this card currently."
Kilde: http://enthusiast.hardocp.com/article.html...W50aHVzaWFzdA==
Endret av panzerBert
Det vil være litt bedre, da den kun består av to litt nedklokkede 8800GT i SLI.
GTS i SLi ;)
Ytelsen vil ligge ca 30% over dagens 8800 GTX, og da ca 15-20 over dagens Ultra :)
The same chip with 64 stream processors
Nvidia plans to launch its Geforce 9600 series, and we can tell you that it is the same old G92 chip. The specification of the card won't be that much different from 8800 GT, but we can tell you that the stream processor number will be cut in half.
The chip will have 64 stream processors and it should fit in the sub-$150 market and fight the Radeon 3850.
It should launch by the middle of next month.
Kilde.
En liten test av 9600GT:
First GeForce 9 series card to hit the market in February is NVIDIA’s GeForce 9600GT. Do not be fooled by the 8800GT-like cooler! It is only to replace 8600GT, not 8800GT.
The card’s frequency is 650/1625/1800MHz(core/shader/mem), using PCB design P545, GPU codename is “G94-300″, made by TSMC’s 65nm process technology. Like 8800GT, the black cooler also made by CoolerMaster.
The internal driver for 9600GT is out today(deep inside the industry), we will get it later, so we have to mod the Device ID into 169.25WHQL’s NV_disp.inf. And the driver fully support the card. After the mod we managed to run a comparison test between G94 and two G92:
Testbed:
CPU: Intel Core 2 QX9650 Retail (333MzX9)
Mobo: Asustek Maximus Formula ROG X38 DDR2
Memory: Geil 1GBX2 DDR2-800 4-4-4-10-1T
HDD: WD 3200YS 7200RPM
OS: Windows Vista Ultimate 32bit SP1 Beta V.668
Driver: 169.25WHQL (Moded with 8800GS and 9600GT info)
The card’s performance is similar to 8800GS. But 8800GS is only a temporarily NVIDIA weapon fighting with ATI’s HD3850. 9600GT is a long term product for replacing the 8600GT family. So how did you think about the incoming war between HD 3850\HD 3670 and 9600GT?
Kilde.
I løpet av årets første kvartal kommer en ny midlertidig toppmodell fra Nvidia - GeForce 9800 GX2. Denne løsniningen er basert på to D9P-brikker på ett og samme kort.
Nærmeste konkurrent blir AMDs R680, som er et kort med doble R670-brikker.
1 milliard transistorer
En ny og mer arkitekturmessig oppgradert toppmodell ventes imidlertid noe senere i år. Kodenavnet er GT200 og brikken får ikke mindre enn over 1 milliard transistorer.
Trolig skal GT200 produseres med 55 nm-teknologi, eller i verste fall 65 nm. Ytterligere spesifikasjoner er foreløpig ikke kjent.
Lansering blir tidlig i årets 2. halvdel. Nærmeste AMD-konkurrent blir R700.
Kilde.
Endret av Sindre Aleksander
9800GX2 kommer til og koste mer enn Ultra:
We've heard that Geforce 9800 GX2 dual G92 dual chip sandwich design will end up as expensive as 8800 Ultra, if not even more.
The price is not final, but it looks like an expensive piece of marchitecture. You are talking about two 8800 GTS boards glued together, along with an expensive cooler, and of course, Nvidia wants to get some profits out of it.
You should be looking at $600 and probably even more for such a card; when we do the math it ends up it will likely be $700+ product in retail stores; but this depends on the territory.
Kilde.
Jeg la også merke til at Alienware har introdusert 8800 GTX 512MB i sine maskiner :hmm:
Ta en titt :)
Litt info jeg fant:
Klikk for å se/fjerne innholdet nedenfor
The new NVIDIA® GeForce® 8M graphics processing units (GPUs) deliver the performance needed for Windows Vista and GPU-enabled applications. Featuring NVIDIA® PureVideo™ HD technology for the ultimate notebook video experience, the GeForce 8M Series is also the first to support Microsoft® DirectX® 10, delivering high performance for not only the latest generation of games, but for applications that demand powerful multimedia capabilities.
Second generation NVIDIA® PureVideo HD™ Technology
Provides the essential processing power for the ultimate Blu-ray and HD DVD movie experience on a PC. It is the world’s first video processor to offload 100% of Blu-ray and HD DVD H.264 video decoding from the CPU. PureVideo HD technology delivers outstanding picture clarity, ultra-smooth video, vivid color, and precise image scaling for movies and video.
Full Microsoft® DirectX® 10 Support
World’s first DirectX 10 GPU with full Shader Model 4.0 support delivers unparalleled levels of graphics realism and film-quality effects.
The NVIDIA Lumenex™ Engine
Provides superior image quality for notebook PCs, delivering ultra-smooth images at astounding frame-rates. What you get are images that are crisp and bright without impacting performance of the PC.
512MB Nvidia® GeForce™ Go 8800M GTX Specifications:
Stream Processors 96
Core Clock (MHz) 500
Shader Clock (MHz) 1250
Memory Clock (MHz) 800
Maximum Memory 512MB
Memory Interface 256-bit
Dedicated Graphics Memory 512MB
Endret av WheelMan
  • 2 uker senere...
nVidias 9800 GX2 testet av kinesere:
Core 2 Quad Q9550
3DMark06 Default : 14180
3DMark06 4AA/16AF : 11516
Kilde.
Score var vist med 1280x1024, altså stock...
Det ser ikke ut som de har fått aktivert SLi, eller hatt store driverproblemer, for jeg får ca det samme med Q6600 og 8800GTX. Og siden det er nesten samme kort så virker det litt logisk.
Ja,jeg likte også mye bedre denne løsningen.
Men blir 9800GX2 verdt pengene? jeg er usikker!
Isåfall så må det ikke bli dyere enn 4000/4500kr.
Jeg venter på 9800GTX(G100), som kommer i mars tror jeg.
Jeg tipper at prisen vil bli rundt 5000/5500kr ved lansering.
GX2 kommer til og koste hakket mer enn Ultra i dag.
Det er GX2 som kommer i Mars, GTX kommer til jul :)
Siden det blir så lite forskell fra 8800 serien til 9 serien så tror jeg står over og venter på dette kortet :innocent:
9800GX2 har strengt tatt ingenting med 9-serien å gjøre.
Det er bare to nedklokkede 8-serie kort satt sammen. (G92)
Det er også ment å konkurrere med HD 3870 X2, ikke mot R700...
Mens skjermkort som 9800GTX (GT200)er forventet å bygge på G100, og skal (ifølge ryktet til spesifikasjonene) være langt raskere.
Hvorfor Nvidia valgte å kalle det 9800GX2 vet jeg ikke noe om, da det ville passet mye bedre å kalle det 8950GX2. Kanskje fordi ATI plutselig begynnte på sin HD 3000 serie. (som ikke er så veldig mye mer enn en krympet 2000 serie med DX10.1 støtte)
Endret av andrull
