nVidias kommende lanseringer, hva vet vi?
WheelMan
Da er 8800GTS 512Mb sendt fra multicom, på vei til meg.
Kommer med tilbakemelding etter jul. :p
Har ikke du sykt nok kort fra før av da? :ermm:
*misunnelig*
Du har jo samme kortet sjøl, da (bare mindre selektert ut chip).
Ja, men jeg lurte på hvorfor han gadd og bytte ut Ultra kortet, når han sitter på en 24"
Ultra er da en annen revisjon enn GTX... (om det var det du tenkte på)
Og derfor er kjernen til Ultra litt forskjellig fra GTX. (som gjør det mulig å klokke lengre)
Og Ultra har vel minne med litt lavere "responstid". (ns)
Og litt mere volt til kjernen :), er vel det som hjelper mest egentlig
Claims 20 °C lower temperature
Leadtek has announced a new Zalman cooled 8800GT card, branded WinFast® PX8800 GT ZL. According to Leadtek's press release, the temperature of the new card is 20 °C lower when compared to the Nvidia reference cooler.
The new card is based on Nvidia Geforce 65nm 8800GT GPU working at 650MHz which is 50MHz over the reference clock, and it comes with 512MB of GDDR3 memory clocked at reference 900MHz (1800MHz effective). The Shader clocked 1625MHz which is 125MHz over the reference 8800GT clock. These low factory overclock values might result in higher OC, but it will depend on how lucky you will be with your purchase.
Beside the lower GPU temperature, Leadtek claims that this new cooler also gets the lower memory and mosfet temperatures so overclocking potential might be greater then expected. As the entire 8800GT series this card also supports DirectX 10 and Shader Model 4.0. You can check out additional info at Leadtek's product page.
Kilde.
Noe Off-Topic, men...
Nvidia’s G100 comes in March :)
According to current plans, Nvidia plans to introduce its Geforce 9 series high end part codenamed G100 around march 2008.
We don’t know many details, but we do know that the chip should end up faster than two G92 D8E dual PCB card which is scheduled for launch in late January.
It will be on time to launch with G96 which is a mainstream part.
Har du en kilde. Kunne gjerne tenkt meg å lese mer dersom det stod noe mer der. :)
Skal du ha et eller to skjermkort neste gang Intern? :wee: Du kjøper jo rått utstyr heler tiden så :wee: *Misunnelig* (:p)
Savner forresten bildet av PCen din fremdeles. Du kunne ikke sendt meg det på en PM dersom det går. :wee: (Da slutter jeg å mase. Hadde ikke det vært deilig? :p )
Litt OT dette her da, men får håpe det går igjennom sensuren. :)
Endret av LockBreaker
