dlink dir-635. Hva er usb porten til?
Det var jo bare å ta en kjapp kikk i manualen som ligger på dlinks hjemmeside (nesten så du skulle klart det selv ;) )
"Connect a USB 1.1 or 2.0 flash
drive to configure the wireless
settings using WCN."
Ja jeg leste det der jeg også. men det sa meg akkurat 0
Sakset fra wikipedia:
Windows Connect Now
Windows Connect Now (WCN) is the name of Windows Rally technologies aimed for simpler wireless device configuration. With Windows Connect Now, users running Windows Vista or Windows XP SP2 can create network configuration settings and transmit them to the access point. Alternatively, users can also print the configuration settings for reference for manually configuring the device. With Windows Connect Now, one of the following methods may be used for easier configuration:
* WCN-NET is Microsoft's implementation of the Wi-Fi Simple Config standard. It provides for configuration of devices using out-of-band Ethernet and in-band wireless networks. In Windows Vista, WCN-NET can discover an unconfigured router, access point, base station or a device such as a Media Center Extender by using UPnP, authenticate with the device by using a personal identification number (PIN), provide wireless settings that are based on user selection and set up a wireless network over a wired Ethernet connection. Windows XP and earlier Windows versions do not support WCN-NET.
* WCN-UFD uses an API and an XML format that works with a wizard to write configuration files to a USB Flash Drive for more secure wireless networks. Windows XP Service Pack 2 and later Windows operating systems supports WCN-UFD.
* WCN-MTP includes a Media Transfer Protocol (MTP) extension that enables an MTP initiator to provide an MTP responder with configuration parameters for joining a wireless network and supports more secure configuration of MTP-capable devices on wireless networks. In Windows Vista, a temporary USB cable connection can be used for MTP-class devices such as portable media, digital cameras etc.
