Æ, ø og å i X-chat
Står på hjemmesiden dems.
9. Why can't I see accented-letters/umlauts/upper-ascii-chars in X-Chat?
Version 1.8:
  Firstly, you should disable fontsets. The setting is in Settings ->
  Setup -> Channel Windows -> Use a FontSet. There is no reason to have
  this setting ON, unless you know you need it. Some versions of X-Chat
  require a restart for this setting to take affect.
  If that doesn't fix the problem, try using a different font, some
  fonts simply don't have the characters you want.
