Xbox360 får divx / xvid støtte - fall update
Dr.Gonzo
Så nå kan en altså legge 1080p filmer i nesten hviket som helst format direkte på portabel HDD og spille av ved å plugge den i USB porten på 360n?
:dribble:
What are the different ways to play video content on Xbox 360?
You can play video from a USB 2.0 FAT32 removable drive, optical media, and by streaming from the Zune software, Windows Media Player 11, or Windows Home Server.
I've seen a few guides knocking around that serve the purpose of getting past the 4GB file size limit for playback on the Xbox 360 on external storage devices - other than streaming direct from PC...
They're all needlessly complicated so this will be short.
Problem : Xbox 360 doesn't recognise files over 4GB in size when the storage device is formatted as FAT32 (The only "windows" formatted type partitions it will read)
Solution : Format it with a Mac type file system (HFS+)
Here's how...
1. Windows cannot perform this task, so you will need some 3rd party software, namely a program called "Macdrive 7". Its a simply little program, you just install it - and use your common sense....
2. Once installed, Restart your computer.
3. Connect your external hard drive\storage device to your computer - make sure there's nothing useful on it right now cos you will be formatting it in a moment.
4. Start MacDrive 7, Start->Programs->MacDrive 7->Get Started With MacDrive 7.
5. Click "Format or Repair Mac Disks", then "Modify Mac Volumes"
6. Select your drive you want to use with the 360. Click "Initialize", Then click the refresh button (2 arrows next to the initialze button) then click the format button.
7. Chose the HFS+ file system
DONE!
Der der funker ikke bare så det er sakt.
:dribble:
AVI Support—The Xbox 360 can now play files in an AVI container (or .divx container) that uses the MPEG-4 Part 2, Simple & Advanced Simple Profile. The max bitrate for these files is 5 Mbps with resolutions up to 1280x720 up to 30fps.
Dette går vel da bare til 720p og ikke 1080p (som er 1920x1080).
Men ellers en spennende oppdatering. Tipper det blir en ekstern HDD på meg om ikke så alt for lenge.
Okay, da står jeg like langt.
Jeg liker ikke film igjennom dashboardet, liker det mer organisert igjennom MC.
Ligger i Mapper via Dashboard, burde holde i massevis. blir sikkert enda bedre organisert på neste update
Media Center er tregere å starte og navigere gjennom mapper med tumbnails
Endret av kewell79
Jo, du kan spille av 1920x1080 uten problemer. Microsoft kan bare ikke garantere at det går like smooth i den oppløsningen. 1Up testet svært mange varianter av formater og størrelser og alt gikk helt glatt, så jeg har stor tro på at denne updaten klarer det jeg hadde håpet på.
*snip*
Jeg synes ikke at det går så tregt, funker ypperlig til mitt bruk, derfor var dette skuffendes.
Den eneste grunnen til at jeg har Vista er pga. MC. :p
Endret av Bertelsen
Hvorfor virker det ikke? Takler ikke Windows HFS+, eller er det xboxen som ikke vil takle det? Eller er det noe annet?
Testet det i går selv, formaterte en ekstern harddisk som jeg har på 120GB til HFS+ plugga den i xboxen. Men den ville ikke en gang lese at den var plugget i. Så jeg antar at xbox ikke leser HFS+. Tviler på at Windows og gjør det..
Det FUNGERER med HFS+, får dere det ikke til er det bare en bruker feil
PS: Det fungerer ikke til 64 bit version av VISTA etter det jeg leser på nettet
En guide som garantert skal fungere for deg: http://www.devilsps3.centelia.net/HD-BYPASS/
Joda jeg får Windows å til og lese den. Men ikke søren om xboxn vil. Må jeg kansje legge noe inn på hardisken slik boxen vil lese den?
Tenkte jeg skulle gjøre klart for divx og alt det der med å share ting på PC-en gjennom Windows media player 11. Men når jeg går på library og velger share my media, trykker OK, så går den bare i tenke modus og så er jeg tilbake der jeg skal trykke ok. Noen som vet hva som kan gjøres? Vil ha dette til å funke!
Og linken til xbox.com/pcsetup for windows-based pc eksisterer jo ikke.. noen så vet hvor jeg finner den setup greia? Zune software fungerer heller ikke. fudged install. prøvd flere ganger.
Var et himla styr å få til dette her! :p
Endret av Sjokoladekake
