TF2 Clan - Quack_Attack [QA]
Da er det på tide å dele configen min:
// # ___
// # <_*_>
// # (o o)
//<=------8---(_)--Ooo-----=>
//<=--------Net&fps--------=>
rate "25000" // Max bytes/sec recieved from the server
net_graph "1" // Show net graph
net_graphpos "2" // Positions net graph
net_maxfragments "1280" // Max fragment bytes per packet
cl_resend "6" // Delay in seconds before the client will resend the 'connect' attempt
cl_cmdrate "101" // Max packets/sec sent to the server
cl_updaterate "101" // Number of packets requested by the server per sec
cl_allowdownload "0" // Client downloads customization files
cl_allowupload "0" // Client uploads customization files
cl_smooth "1" // Enable player position correction (Default=1)
cl_smoothtime "0.1" // Smooth client's view after prediction error over this many seconds
cl_lagcompensation "1" // Perform server side lag compensation of weapon firing events
cl_lagcomp_errorcheck "0" // Checks for position errors
cl_interpolate "1" // Smooths player positions
cl_interp_ratio "1" // Sets the interpolation amount (final amount is cl_interp_ratio / cl_updaterate) (Default=1)
cl_interp_all "0" // Disable all interpolate optimizations. When set to 0 the optimisation is run and only the set of entities that need interpolation are considered. When set to 1 (or any non zero value) the old behaviour is run, where every entity the client knows about is considered for interpolation
cl_predictweapons "1" // Perform client side prediction of weapon effects
cl_timeout "30" // After this many seconds without receiving a packet from the server, the client will disconnect itself
cl_pred_optimize "2" // Optimize for not copying data if didn't receive a network update (1), and also for not repredicting if there were no errors (2)
mat_queue_mode 1 // Dual Core
mat_picmip -10 // Textur settings
// ()_()
// (o o)
//<=-----ooO-->o<--Ooo-----=>
//<=---------Mouse---------=>
sensitivity "2" // Set mouse sensitivity
// _|_|_
// (o o)
//<=-----ooO--(_)--Ooo-----=>
//<=--------Console--------=>
con_enable "1" // Enable console
"bind""/""toggleconsole"
"bind""\""toggleconsole"
// {}o o{}
//<=---------Sound---------=>
volume "0.1" // Sets the volume
cl_downloadfilter "nosounds" // Disable downloading of sounds when connecting to a server
// ()_()
// (o o)
// ___
// /(o o)\
//<=-------Keyboard--------=>
bind "ESCAPE" "cancelselect"
bind "MOUSE5" "lastinv"
bind "SHIFT" "+duck"
// /(o o)\
//<=------Screenshots------=>
jpeg_quality "100" // jpeg screenshot quality
bind "F5" jpeg
clear
echo " __ _ "
echo " / _(_) "
echo " ___ ___ _ __ | |_ _ __ _ "
echo " / __/ _ \| '_ \| _| |/ _` |"
echo "| (_| (_) | | | | | | | (_| |"
echo " \___\___/|_| |_|_| |_|\__, |"
echo " __/ |"
echo " |___/ "
echo " _ _ _ "
echo "| | | | | |"
echo "| | ___ __ _ __| | ___ __| |"
echo "| |/ _ \ / _` |/ _` |/ _ \/ _` |"
echo "| | (_) | (_| | (_| | __/ (_| |"
echo "|_|\___/ \__,_|\__,_|\___|\__,_|"
echo
echo
echo
echo "Configuration made by JFM"
echo
echo "QA Public Server"
echo "ServerIP: 85.17.165.7:27029"
echo "connect 85.17.165.7:27029"
echo
echo
echo "QA War-Server:
echo "ServerIP: 92.48.107.151:27015"
echo "ServerPW: **********"
echo "connect 92.48.107.151:27015; password ********"
echo "Server Rcon: **************"
echo "rcon_password **************"
echo "SourceTV: 92.48.107.151:27020"
echo
echo "FTP IP: **********"
echo "FTP PW: *********"
echo
echo
echo "VT-info (v.3):"
echo "IP: eurovent1.gameservers.com"
echo "Port: 4226"
echo "PW: *******"
echo
Edit: ble noe rot når den kom inn i forumet.
Endret av JFM
  • 2 uker senere...
