Gjest Arveen Skrevet 29. november 2007 Rapporter Del Skrevet 29. november 2007 Community Update – Crysis Patch #1! Greetings beloved Community! Today we have got a little update on our upcoming patch #1 for Crysis for you. Even though there is no final change log available at the moment since the patch is still work in progress we would like to give you a rough overview what kind of issues are being addressed. Crysis Patch #1 – General Content First of all we don’t have set a release date for the patch yet. We are still working on it, but we are very confident that the patch will be out right after it has been verified and checked for stability. We will let you know immediately once we have more specific information on this for you. As for the content it self, the patch is going to address following categories: * Overall Performance * Adjustments to LAW and Grenade balance in multiplayer Please keep in mind this is not a major patch to the game, but more an update on performance and some Multiplayer tweaks that have been requested by the community. Pre-Order/Special Edition Exclusive Vehicle (Amphibious APC) – Online Issues A few of the people who got access to the Amphibious APC wonder why they are not able to purchase that vehicle in one of the factories. This is related to the fact that the dedicated server need to be logged into Gamespy to allow people who purchased the pre-order/SE version of Crysis to buy the vehicle ingame. We already informed most of the server hosting companies about that and we recommend everyone who is setting up a dedicated server to read the Crysis Server Documentation. Weapon Sound loop – Workaround! Some committed community members found out a temporary workaround for the sound looping bug that occurs in some multiplayer sessions. In the case you experience this bug please follow this instructions: 1. Open console and type in “con_restricted 0” (without “”). 2. Type in “s_soundenable 0” (without “”) to disable sound completely. 3. Type in “s_soundenable 1” (without “”) to enable sound again. So whenever this bug occurs just follow the steps above and the bug should be gone. Crytek is also trying to solve that problem once we are able to reproduce it in-house. Thanks to these members for finding this workaround! -Crysis Dev Team Lenke til kommentar
krillee Skrevet 29. november 2007 Rapporter Del Skrevet 29. november 2007 så d dær på incrysis blir bra hvis patchen får spillet til å kjøre bedre på dagens hardware Lenke til kommentar
tharshan Skrevet 29. november 2007 Rapporter Del Skrevet 29. november 2007 Håpar at eg kan få meir enn 8-15 FPS med 8800 ultra det er dog med 1680x1050 og alt på very high. Lenke til kommentar
krillee Skrevet 29. november 2007 Rapporter Del Skrevet 29. november 2007 Håpar at eg kan få meir enn 8-15 FPS med 8800 ultra det er dog med 1680x1050 og alt på very high. er d alt av fps du får? Hva er specsa ellers da? Lenke til kommentar
tharshan Skrevet 29. november 2007 Rapporter Del Skrevet 29. november 2007 q6600, 2gb, ip35 pro .... Lenke til kommentar
krillee Skrevet 1. desember 2007 Rapporter Del Skrevet 1. desember 2007 hm...ja da håper jeg virkelig at i alle fall noe performance blir bedre, som det egentlig står da Lenke til kommentar
-=PuNkGuY=- Skrevet 1. desember 2007 Rapporter Del Skrevet 1. desember 2007 Det går faktisk ann å kjøre spill på high eller medium også da Viktigere at et spill går smooth enn at det ser bra ut. Husk uansett å sett "postprocessing" på HIGH, uansett hva alt annet står på. Lenke til kommentar
tharshan Skrevet 1. desember 2007 Rapporter Del Skrevet 1. desember 2007 spelet er litt rar. Hvis ikkje eg endra på nokon av innstillingane før eg begynne å spele ffår eg 15-25 FPS Lenke til kommentar
mafia-slayer Skrevet 2. desember 2007 Rapporter Del Skrevet 2. desember 2007 Hvor er kilden din? Noen som veit når denne kommer? Lenke til kommentar
MartinMyhre Skrevet 2. desember 2007 Rapporter Del Skrevet 2. desember 2007 Det går faktisk ann å kjøre spill på high eller medium også da Viktigere at et spill går smooth enn at det ser bra ut. Husk uansett å sett "postprocessing" på HIGH, uansett hva alt annet står på. Enig.. Jeg har allt på medium, men postprocessing på HIGH Lenke til kommentar
krillee Skrevet 2. desember 2007 Rapporter Del Skrevet 2. desember 2007 blir bra, n¨år jeg får PC-en og er klar til å spille crysis, så har patchen og kommet Lenke til kommentar
tharshan Skrevet 2. desember 2007 Rapporter Del Skrevet 2. desember 2007 Det går faktisk ann å kjøre spill på high eller medium også da Viktigere at et spill går smooth enn at det ser bra ut. Husk uansett å sett "postprocessing" på HIGH, uansett hva alt annet står på. Enig.. Jeg har allt på medium, men postprocessing på HIGH Hvis eg har dne på very high då? Lenke til kommentar
LostOblivion Skrevet 2. desember 2007 Rapporter Del Skrevet 2. desember 2007 Pleier å ha alt på High, bortsett fra Post Processing og Physics, som jeg har på Very High. Kjører 1280 by 1024 nonscale. Skal sies at selv GTX SLI ikke hjelper et gram i Crysis. Kanskje en eller to FPS. Skal også sies at jeg kjørte dette på single GTX og hadde mellom 25-30 FPS avg. Regner med at bedre støtte for SLI er et problem Crytek fikser i neste patch. De lovte nemlig minst 40 % mer ytelse i SLI når spillet ble lansert. Dårlig! Mine tweaks: Ellers kan man kjøre alt på Very High, og sette q_Renderer til 2 (og ikke 3) og r_MotionBlur til 1 (og ikke 3). Da får man parallax-mapping, som er nais. Selv tjente jeg rundt 10 FPS på dette, som er ganske god payoff for noe jeg mener ikke egentlig er så mye tap av bildekvalitet. Ca 20 FPS avg på denne måten. (Husk å sette con_restricted til 0 før dere prøver.) Lenke til kommentar
RamGuy Skrevet 20. desember 2007 Rapporter Del Skrevet 20. desember 2007 (endret) Pleier å ha alt på High, bortsett fra Post Processing og Physics, som jeg har på Very High. Kjører 1280 by 1024 nonscale. Skal sies at selv GTX SLI ikke hjelper et gram i Crysis. Kanskje en eller to FPS. Skal også sies at jeg kjørte dette på single GTX og hadde mellom 25-30 FPS avg. Regner med at bedre støtte for SLI er et problem Crytek fikser i neste patch. De lovte nemlig minst 40 % mer ytelse i SLI når spillet ble lansert. Dårlig! Mine tweaks: Ellers kan man kjøre alt på Very High, og sette q_Renderer til 2 (og ikke 3) og r_MotionBlur til 1 (og ikke 3). Da får man parallax-mapping, som er nais. Selv tjente jeg rundt 10 FPS på dette, som er ganske god payoff for noe jeg mener ikke egentlig er så mye tap av bildekvalitet. Ca 20 FPS avg på denne måten. (Husk å sette con_restricted til 0 før dere prøver.) Hvor finner jeg "con_restricted" ? Endret 20. desember 2007 av RamGuy Lenke til kommentar
lavizh Skrevet 20. desember 2007 Rapporter Del Skrevet 20. desember 2007 (endret) Finner? bare skriv "con_restricted=0" i begynnelsen av autoexec.cfg som skal ligge i crysis foldern. dette enabler console. Endret 20. desember 2007 av lavizh Lenke til kommentar
RamGuy Skrevet 20. desember 2007 Rapporter Del Skrevet 20. desember 2007 Finner? bare skriv "con_restricted=0" i begynnelsen av autoexec.cfg som skal ligge i crysis foldern.dette enabler console. Fant det ut nå. Så en sånn guide på nettet Lenke til kommentar
Moderat Bruker Skrevet 21. desember 2007 Rapporter Del Skrevet 21. desember 2007 Hvor er kilden din? Noen som veit når denne kommer? Noen som har noe mer info? Og kan vi forvente oss en raskere/bedre spillopplevelse paa mid/high utstyr enn det tilfellet er i dag? Lenke til kommentar
GeForcy Skrevet 21. desember 2007 Rapporter Del Skrevet 21. desember 2007 Hvor kan jeg laste ned pachten?? Lenke til kommentar
Gjest medlem-105082 Skrevet 21. desember 2007 Rapporter Del Skrevet 21. desember 2007 Hvor kan jeg laste ned pachten?? Den er ikke ute enda. Lenke til kommentar
Megnus Skrevet 21. desember 2007 Rapporter Del Skrevet 21. desember 2007 Når kommer denne patchen da? De sa jo den skulle være ute 2 uker etter lansering. Fler enn 2 uker nå kan man si ... Lenke til kommentar
